Datacube text vs. Note text?
Postby eeZee » Mon Oct 24, 11 6:59 am
Is there an easy way to have it so that a Datacube says one thing, but registers another thing in your notes?
Simple example: A datacube reads "Hey Jimmy, blah blah blah blah blah long weekend blah blah blah protocols blah blah blah security door blah blah code is 1234 blah blah blah have a good time." and the note in the UI registers as "The code to the security door is 1234"?
eeZee
Postby SimonDenton » Thu Dec 29, 11 12:41 pm
I do have one method, this is a first attempt:
1. Write your desired concise sentence as a text file.
2. Import a custom datacube in order to edit one simple property
[spoiler]
// DataCube2.
class DataCube2 extends DataCube;
    bAddToVault=False
[/spoiler]
2. Import the class of and place this custom NoteAddTrigger I got from TNM, in your level.
[spoiler]
// NoteAddTrigger.
class NoteAddTrigger expands Trigger;
// Set bCollideActors to False to make it triggered
var() name NoteTag;
var() string Textpackage;
var deusexplayer player;
var string vaultstring;
var bool bFirstParagraph;
function Trigger(Actor Other, Pawn Instigator)
   Super.Trigger(Other, Instigator);
   player = DeusExPlayer(Instigator);
   if (player != None)
      givenote();
function Touch(Actor Other)
   Super.Touch(Other);
   if (IsRelevant(Other))
      player = DeusExPlayer(Other);
      if (player != None)
         givenote();
function givenote()
   local DeusExTextParser parser;
   local DeusExNote note;
   // First check to see if we have a name
   if ( notetag != '' )
      // Create the text parser
      parser = new(None) Class'DeusExTextParser';
      // Attempt to find the text object
      if ((player != None) && (parser.OpenText(noteTag,TextPackage)))
         parser.SetPlayerName(player.TruePlayerName);
         vaultString = "";
         bFirstParagraph = True;
         while(parser.ProcessText())
            ProcessTag(parser);
         parser.CloseText();
         // Check to see if we need to save this string in the
         // DataVault
            note = player.GetNote(NoteTag);
            if (note == None)
               note = player.AddNote(vaultString,, True);
               note.SetTextTag(NoteTag);
            vaultString = "";
      CriticalDelete(parser);
// ProcessTag()
function ProcessTag(DeusExTextParser parser)
   local String text;
//   local EDeusExTextTags tag;
   local byte tag;
   local Name fontName;
   local String textPart;
   tag  = parser.GetTag();
   switch(tag)
      case 0:            // TT_Text:
      case 9:            // TT_PlayerName:
      case 10:         // TT_PlayerFirstName:
         text = parser.GetText();
         vaultString = vaultString $ text;
         break;
      // Create a new text window
      case 18:         // TT_NewParagraph:
         // Only add a return if this is not the *first*
         // paragraph.
         if (!bFirstParagraph)
            vaultString = vaultString $ CHR(10) $ CHR(13); //can't use CR()easily
         bFirstParagraph = False;
         break;
    TextPackage="MyPackage"
    bTriggerOnceOnly=True
[/spoiler]
3. In the note add trigger add the neccessary parameters for adding a note.
4. Do the trigger and events stuff with this trigger and Datacube 2.
5. Test it and let me know how it goes!
SimonDenton
Users browsing this forum: No registered users and 18 guests
