Greetings. I just want to let you know, I am creating a map called DXBC_Sentinel_Underground, and I can't do it by myself, too much work :\ so can you help me with it? Benefits and cons:
Benefits
If you are a texturer in this map... You only need to do one thing: texture some textures that I assign you:
If you are a mapper in this map... You only need to complete at least 20%, I will create the rest. Mainly, you would want to create the atmosphere, I'll handle the rest.
If you are a coder/modding in this map... You only need to mod at least one thing, I'll handle the rest.
Cons
If you are a texturer.. you have probably not enough time to work, most people here are busy with either FLCity or Novocon :\
If you are a mapper.. same as up ^
If you are a coder .. this may involve some advanced coding
Please fill in the form:
Name
DX Name
Position
Active/Non-Active Times
