SphereEffect
SphereEffect
Postby Leenuks » Wed May 21, 08 8:43 am
Hi all.
In my competition map Ive decided to put a SphereEffect where the teleports are located. Only problem is I place it and it will not show up in my map. It shows in the editor only.
I have messed with many settings of this Effect but cant work out how to make it visible to everyone.
In the Editor you can see what I want to do.
In-game what I get.
Leenuks
Leenuks
Postby Dae » Wed May 21, 08 8:51 am
If you summon a SphereEffect in the game with a command, it disappears in a couple of seconds. Same here.
This is because of:
simulated function Tick(float deltaTime)
   DrawScale = 3.0 * size * (Default.LifeSpan - LifeSpan) / Default.LifeSpan;
   ScaleGlow = 2.0 * (LifeSpan / Default.LifeSpan);
in the class "SphereEffects".
Make your own SphereEffect child and override this function.
Postby Leenuks » Wed May 21, 08 9:34 am
Thanks.
I made a new actor from that class and then edited it to this
class TP-SphereEffect expands SphereEffect;
var float size;
   DrawScale = 4.0 * size;
   ScaleGlow = 2.0;
I then set in the properties of the actor under Advanced, Lifespan and changed the 0.500000 to 0.
So far it hasnt vanished so hopefully during a match it will stay put.
Leenuks
