texture help
texture help
Postby CvendaCZ » Thu Oct 02, 08 1:09 pm
How do I set up the transparency of texture?
CvendaCZ
Postby Snakey » Thu Oct 02, 08 7:11 pm
Right click the texture, go to texture properties and check the "Transparency" box.
Postby ~SaSQuAtCH~ » Thu Oct 02, 08 7:34 pm
I suggest you use a single topic called "Help Kakashi" instead of opening new topics every time you need help.
Postby ~DJ~ » Fri Oct 03, 08 1:12 am
DeathMaster wrote:I suggest you use a single topic called "Help Kakashi" instead of opening new topics every time you need help.
Agreed, You might try that..
Postby CvendaCZ » Fri Oct 03, 08 1:45 pm
Snakey wrote:Right click the texture, go to texture properties and check the "Transparency" box.
where is Transparency box?i cant find it in texture properties... :?
CvendaCZ
Postby ~DJ~ » Fri Oct 03, 08 2:05 pm
Transparent texture:- while your making the texture.... add black color where you want transparency.. when you import press tick on (check on) :- Masked
Here is a picture :- Image
Hope i helped :)
Huh?
Are you talking about Photoshop? Because hes not :o
Postby ~SaSQuAtCH~ » Fri Oct 03, 08 2:36 pm
DX SDK if you know that thing.
Postby CvendaCZ » Fri Oct 03, 08 2:46 pm
thx,and i need know how i can add LHKINS in deus ex,i add it"Editpackage=LHKINS"but i have got error in editor maps
CvendaCZ
Postby Dex » Fri Oct 03, 08 3:08 pm
what is LHKINS?
Postby Snakey » Fri Oct 03, 08 3:55 pm
Huh?
I was talking about UnrealEd.
Postby CvendaCZ » Sat Oct 04, 08 7:47 am
LHKINS is pogram in unrealed,and i can add god zone in map....
CvendaCZ
Postby Dex » Sat Oct 04, 08 8:39 am
LHKIPS is a package made for the Unreal Engine and for the game Deus Ex.
It is protected, therefore you can't work with it in UEd.
