activate/deactivate trigger
Postby DOOMGUY » Sat Feb 28, 09 7:37 am
I want a trigger which opens a door to be inactive until a power generator is turned on.. I've set binitiallyactive to false but how do I activate it when the button on the power generator is pushed? Also, I would like it to be deactivated when the power generator button is pushed a second time, is that possible?
EDIT: Nevermind, I figured it out. In case anyone else comes here looking to ask the same question.. you have to go into Object and then change the InitialState to 'OtherTriggerToggles', so when something else triggers that trigger it will switch between active and inactive.
DOOMGUY
Postby Mastakilla » Sun Mar 01, 09 6:37 pm
No problem.
