Change player's collision during gameplay
Postby Kalman11 » Mon Aug 22, 11 2:49 pm
Is that possible?
The SetCollisionSize() doesn't work.
Kalman11
Postby Kalman11 » Thu Aug 25, 11 1:04 pm
Can anyone help me?
Kalman11
Postby Dae » Thu Aug 25, 11 1:16 pm
Singleplayer or multiplayer?
How exactly did you use SetCollisionSize()?
I don't know but I think I could change player's collision height in multiplayer using only command-line.
Postby Kalman11 » Thu Aug 25, 11 3:35 pm
I can change the player's height, only the radius is the problem
I've got an another problem. It doesn't work properly in MP. I can't use the GetOut as exec function, and the behinder doesn't follow the player
This is the full code (don't laught on it, it's my first bigger code)
// Vehicle. By [FGS]Kalman
class Vehicle expands DeusExPickup;
var(Vehicle) LodMesh vehiclemesh;
var(Vehicle) string vehiclename;
var(Vehicle) string entermessage;
var(Vehicle) float DScale;
var(Vehicle) bool bArmored;
var(Vehicle) float StepHeight; //Max Step Height, in metres
var(Vehicle) class<Inventory> VehicleInventory;
var(Vehicle) Texture VehicleSkins[8];
var(Vehicle) float VehicleLength;
var(Vehicle) float VehicleHeight;
var(Vehicle) Sound EngineSound;
var Texture defaultskins[8];
var DeusExPlayer Driver;
var View behinder; // Our behindview target
var vector x;
var vehicle newvehicle;
replication
reliable if( Role <ROLE_Authority)
Driver, behinder, newvehicle;
unreliable if(Role <ROLE_Authority)
GetIn,GetOut,DisableStrafe,EnableStrafe,Explode;
function PreBeginPlay()
local int i;
Super.PreBeginPlay();
Mesh = Vehiclemesh;
DrawScale = DScale;
SetCollisionSize(VehicleLength, VehicleHeight);
PickupViewMesh=vehiclemesh;
PickupViewScale=DScale;
ItemName=vehiclename;
PickupMessage=entermessage;
   for (i=0; i<8; i++)
   MultiSkins[i] = VehicleSkins[i];
auto state pickup // Activate it, when it picked up
simulated function Frob(actor frobber, inventory frobwith)
Super.Frob(Frobber, frobWith);
    GetIn(Frobber);
function GetIn( actor Other)
    local int i;
    local Inventory item, nextitem;
   local int i2;
   Driver = DeusExPlayer(Other);
   Driver.AddInventory(Self);
   Driver.ConsoleCommand("SET INPUT ENTER GETOUT"); // We need to set a key for the leaving
    Driver.AmbientSound = EngineSound;
    Driver.Mesh=Vehiclemesh;
   Driver.DrawScale = DScale;
   Driver.SetLocation(Location);
   Driver.SetCollisionSize(VehicleLength, VehicleHeight);
   Driver.JumpZ=0; // A vehicle can't jump man
   Driver.FamiliarName = vehiclename;// I need to store somewhere these properties.
   Driver.UnFamiliarName = entermessage;// These settings are unused in multiplayer, so it's great for me.
    Driver.bBehindView = True;
    Driver.AccelRate = 100;// Change the player's speed, a player can't be faster than a vehicle
    Driver.GroundSpeed = 20000;
    Driver.Prepivot.Z = Prepivot.Z;
    DisableStrafe();
    behinder = spawn(Class'view',,,); // Spawn our behindview target
        behinder.SetLocation( Driver.Location  + Normal(Driver.Velocity*2*VehicleLength) *128 + vect(0,0,128));
    behinder.setowner(Driver);
    Driver.ViewTarget= behinder;
   Driver.Mass = Mass; // Make the player heavier
   Driver.Bob = 0; // Disable the bob
   Driver.MaxStepHeight = StepHeight*52;
   Driver.bCanStrafe =  False;
   Driver.setcollision(false,true,true);
      for (i=0; i<8; i++) // Store the player's skin, then change to the vehicle's skin
      defaultskins[i] = Driver.MultiSkins[i];
   Driver.MultiSkins[i] = VehicleSkins[i];
         while((item != None) && (item.IsA('NanoKeyRing') || (!item.bDisplayableInv))) //Destroy player's inventory, except NanoKeyRing
                  item = item.Inventory;
               if (item != None)
                  nextItem = item.Inventory;
                  Driver.DeleteInventory(item);
   if (bArmored)
   Driver.Health = 200; // If armored, increase player's health
   Driver.HealthHead = 250;
   Driver.HealthTorso = 200;
   Driver.ReducedDamagePct = 25;
   Driver.ReducedDamageType = 'Shoot';// And reduce the damage of shots
   else // Else just increase the health
   Driver.Health = 115;
   Driver.HealthHead = 130;
   Driver.HealthTorso = 115;
function Explode()
    local ExplosionLight light;
   local float explosionDamage;
   local float explosionRadius;
   explosionDamage = Driver.Health*10;
   explosionRadius = 256;
   light = Spawn(class'ExplosionLight',,, Location);
   if (light != None)
      light.size = 4;
   Spawn(class'ExplosionSmall',,, Location + 2*VRand()*CollisionRadius); // Draw some explosion
   Spawn(class'ExplosionMedium',,, Location + 2*VRand()*CollisionRadius);
   Spawn(class'ExplosionLarge',,, Location + 2*VRand()*CollisionRadius);
   HurtRadius(explosionDamage, explosionRadius, 'Exploded', explosionDamage*100, Location);// And hurt the player
simulated function Tick( float DeltaTime )
       local float MomentumTransfer;
       local SmokeTrail st;
       local actor p;
       local int i;
if(driver != None)
                 if(Driver.Health < 10)
                 { GetOut(); // Take out the player
                   Driver.Health = 100; // Heal the player, so he will thinks the vehicle was damaged, not himself
                   Explode(); //Explode the vehicle
                behinder.SetLocation( Driver.Location - 1.5*Normal(Driver.Velocity) *128 + vect(0,0,128) );
                  if(st !=none && Driver.Health < 50){
   st = spawn(class'SmokeTrail',,,); // If the player's health is less than 50, spawn some smoke
   st.SetLocation(Driver.Location + vect(0,0,128));
   st.drawscale=4.0;}
foreach visiblecollidingactors(class'actor', p, collisionradius,, true)
                  if(P.IsA('Pawn') ||P.IsA('DeusExDecoration') && P != Driver) {
PlaySound(Sound'Fleshhit2', SLOT_Interface, 2.0);
         p.velocity.z = 500;
         p.TakeDamage( (Driver.Velocity.X*Driver.Velocity.Y*0.3), instigator, p.Location, MomentumTransfer * Normal(driver.Velocity), 'Shoot');
exec function GetOut()
local vector loc;
local rotator rot;
local int i;
loc = Driver.Location + vect(0,0,64); // A bit higher than the player's location
rot = Driver.Rotation;
newvehicle= Spawn(Class'vehicle',Self,,loc,rot);
newvehicle.Prepivot.Z = Driver.Prepivot.Z;
newvehicle.PICKUPVIEWmesh = Driver.Mesh; // Can't set as vehiclemesh, I don't know why
newvehicle.vehiclelength = Driver.CollisionRadius;
newvehicle.vehicleheight = Driver.CollisionHeight;
newvehicle.SetCollision(true,true,true);
newvehicle.vehiclename = Driver.FamiliarName;
newvehicle.entermessage = Driver.UnFamiliarName;
newvehicle.SetCollision(true, true, true);
behinder.Destroy(); // Destroy our behindview target
PlaySound(Sound'KeysRattling', SLOT_Interface, 2.0);
   for (i=0; i<8; i++)
   Driver.MultiSkins[i] = defaultskins[i];
   Driver.Prepivot.Z = Driver.default.Prepivot.Z;
    Driver.Mesh=Driver.default.mesh;
   Driver.DrawScale = Driver.Default.DrawScale;
   Driver.SetCollisionSize(Driver.Default.CollisionRadius,Driver.Default.CollisionHeight);
   Driver.BaseEyeHeight = CollisionHeight*0.85;
   Driver.JumpZ=Driver.Default.JumpZ;
   Driver.bBehindView = False;
   Driver.ViewTarget= Driver;
   EnableStrafe();
   Driver.Mass = Driver.Default.Mass;
   Driver.Bob = 0.016000; // It's the default value, the Driver.Default.Bob doesn't work
   Driver.MaxStepHeight = Driver.Default.MaxStepHeight;
   Driver.bCanStrafe =  Driver.Default.bCanStrafe;
   Driver.SetPhysics(PHYS_Walking);
   Driver.gotostate('playerwalking');
   Driver.AccelRate = Driver.Default.AccelRate;
   Driver.GroundSpeed = Driver.Default.GroundSpeed;
   Driver.ViewTarget= None;
   Driver.AmbientSound = None;
   Driver.Tag = Driver.Default.Tag;
   Driver.SetLocation(newvehicle.Location + Normal(Vect(128,128,0)));
   Driver = None;
   Destroy(); // Destroy the player's vehicle
function DisableStrafe()
         driver.ConsoleCommand("SET INPUT Right TurnRight");
         driver.ConsoleCommand("SET INPUT Left TurnLeft");
function EnableStrafe()
driver.ConsoleCommand("SET INPUT Left StrafeLeft");
driver.ConsoleCommand("SET INPUT Right StrafeRight");
Kalman11
