player login
player login
Postby atrey65789 » Wed Jun 12, 13 5:37 pm
So, When making a gametype extending MTLDeathmatch, I am trying to make it to where my player class (SSPlayer) will be the default player class.
It works, however, it works ONLY if the player's nonteam model is set to JC Denton. I need to make it to where no matter what, You will always play as the SSPlayer class..
I know the function in gametypes that determine the player class is Login(), I tried changing things in it, but no luck.
Any help would be much appreciated! :D
-A
atrey65789
Postby ~DJ~ » Wed Jun 12, 13 7:28 pm
Create a custom GameInfo, put that in there:
class SSGameInfo extends GameInfo;
function bool ApproveClass (Class<PlayerPawn> S40)
   return True;
    DefaultPlayerClass=Class'SSPlayer'
    GameReplicationInfoClass=Class'SSGRI'
As you can see, GameReplicationInfoClass is on there, so create a custom one too.
class SSGRI extends GameReplicationInfo;
     NetPriority=1.100000
At your gametype, put this code on:
event PlayerPawn Login (string Portal, string Z56, out string Z57, Class<PlayerPawn> SpawnClass)
   local MTLPlayer Z5B;
   local int Z5C;
   local string Z5D;
   local int i;
   local int k;
   local string inputpass;
   local string checkpass;
   local int x;
   SpawnClass=Class'SSJCDenton';
   Z5B=MTLPlayer(Super(DeusExGameInfo).Login(Portal,Z56,Z57,SpawnClass));
   ChangeOption(Z56,"Class", string(SpawnClass));
   ChangeOption(Z56,"Team","TEAM_NSF");
   Z5B.bAutoActivate = true;
   if ( Z5B != None )
      //Z5B.PlayerReplicationInfo.Team = 1;
      Z5B.ResetPlayerToDefaults();
   SSPlayer(Z5B).Join = true;
   return Z5B;
    DefaultPlayerClass=Class'SSJCDenton'
    NetPriority=10.00
Needs SSJCDenton now, so..
class SSJCDenton extends SSPlayer
   Config(User);
     CarcassType=Class'DeusEx.JCDentonMaleCarcass'
     JumpSound=Sound'DeusExSounds.Player.MaleJump'
     HitSound1=Sound'DeusExSounds.Player.MalePainSmall'
     HitSound2=Sound'DeusExSounds.Player.MalePainMedium'
     Land=Sound'DeusExSounds.Player.MaleLand'
     Die=Sound'DeusExSounds.Player.MaleDeath'
     Mesh=LodMesh'DeusExCharacters.GM_Trench'
     MultiSkins(0)=Texture'DeusExCharacters.Skins.JCDentonTex0'
     MultiSkins(1)=Texture'DeusExCharacters.Skins.JCDentonTex2'
     MultiSkins(2)=Texture'DeusExCharacters.Skins.JCDentonTex3'
     MultiSkins(3)=Texture'DeusExCharacters.Skins.JCDentonTex0'
     MultiSkins(4)=Texture'DeusExCharacters.Skins.JCDentonTex1'
     MultiSkins(5)=Texture'DeusExCharacters.Skins.JCDentonTex2'
     MultiSkins(6)=Texture'DeusExCharacters.Skins.FramesTex4'
     MultiSkins(7)=Texture'DeusExCharacters.Skins.LensesTex5'
Create this too;
class SSPRI extends MTLPRI;
    NetPriority=1.20
    NetUpdateFrequency=2.00
And put this on your SSPlayer's defaultproperties:
     PlayerReplicationInfoClass=Class'SSPRI'
Hopefully that does the trick.
Postby atrey65789 » Wed Jun 12, 13 8:01 pm
Works DJ!!!! Thanks man!!!!!!!
-A
atrey65789
Postby bambi » Tue Jan 21, 14 6:06 pm
lol atrey, gametypes are so confusing, i will actually upload the code I borrowed, just specifiy your gametype, and from gametype specify your spawnclass to that playerclass.
bam!
bambi
Users browsing this forum: Yandex [Bot] and 3 guests
