My Blob's Coding issue.
Postby Allan » Tue Jan 03, 06 10:14 pm
// Blob.
class Blob expands ThrownProjectile;
var vector SurfaceNormal;
var int numBio;
var float mpDamage;
var   float time;
var() float WallTime;
var   bool  exploded;
simulated function Tick(float deltaTime)
    local ScriptedPawn P;
   local DeusExPlayer Player;
   local Vector dist, HitLocation, HitNormal;
   local float blinkRate, mult, skillDiff;
   local float proxRelevance;
   local Pawn curPawn;
   local bool pass;
   local Actor HitActor;
  if ( Role == ROLE_Authority )
    Super.Tick(deltaTime);
    if(bStuck)
   time += deltaTime;
        if (time % 0.3 > 0.25)
        if(time > WallTime && !exploded)
            DrawExplosionEffects(Location, Location);
            exploded=true;
            HurtRadius(damage * Drawscale, FMin(100, DrawScale * 75), 'Poison', MomentumTransfer * Drawscale, Location);
            GotoState('Exploding');
       return;
   time += deltaTime;
      if (bDisabled)
         return;
      if ( (Owner == None) && ((Level.NetMode == NM_DedicatedServer) || (Level.NetMode == NM_ListenServer)) )
         // Owner has logged out
         bDisabled = False;
         team = -1;
      if (( Owner != None ) && (DeusExPlayer(Owner) != None ))
         if ( TeamDMGame(DeusExPlayer(Owner).DXGame) != None )
            // If they switched sides disable the grenade
            if ( DeusExPlayer(Owner).PlayerReplicationInfo.team != team )
               bDisabled = False;
               team = -1;
      // check for proximity
      if (bProximityTriggered)
         if (bArmed)
            proxCheckTime += deltaTime;
            // beep based on skill
            if (skillTime != 0)
            // if we have been triggered, count down based on skill
            if (skillTime > 0)
               skillTime -= deltaTime;
            // explode if time < 0
            if (skillTime < 0)
               bDoExplode = True;
               bArmed = False;
            // DC - new ugly way of doing it - old way was "if (proxCheckTime > 0.25)"
            // new way: weight the check frequency based on distance from player
            proxRelevance=DistanceFromPlayer/2000.0;  // at 500 units it behaves as it did before
            if (proxRelevance<0.25)
               proxRelevance=0.25;               // low bound 1/4
            else if (proxRelevance>10.0)
               proxRelevance=20.0;               // high bound 30
               proxRelevance=proxRelevance*2;    // out past 1.0s, double the timing
            if (proxCheckTime>proxRelevance)
               proxCheckTime = 0;
               // pre-placed explosives are only prox triggered by the player
               if (Owner == None)
                  foreach RadiusActors(class'DeusExPlayer', Player, proxRadius*4)
                     // the owner won't set it off, either
                     if (Player != Owner)
                        dist = Player.Location - Location;
                        if (VSize(dist) < proxRadius)
                           if (skillTime == 0)
                              skillTime = FClamp(-20.0 * Player.SkillSystem.GetSkillLevelValue(class'SkillDemolition'), 1.0, 10.0);
                  // If in multiplayer, check other players
                  if (( Level.NetMode == NM_DedicatedServer) || ( Level.NetMode == NM_ListenServer))
                     curPawn = Level.PawnList;
                     while ( curPawn != None )
                        pass = False;
                        if ( curPawn.IsA('DeusExPlayer') )
                           Player = DeusExPlayer( curPawn );
                           // Pass on owner
                           if ( Player == Owner )
                              pass = True;
                           // Pass on team member
                           else if ( (TeamDMGame(Player.DXGame) != None) && (team == player.PlayerReplicationInfo.team) )
                              pass = True;
                           // Pass if radar transparency on
                           else if ( Player.AugmentationSystem.GetClassLevel( class'AugRadarTrans' ) == 3 )
                              pass = False;
                           // Finally, make sure we can see them (no exploding through thin walls)
                           if ( !pass )
                              // Only players we can see : changed this to Trace from FastTrace so doors are included
                              HitActor = Trace( HitLocation, HitNormal, Player.Location, Location, True );
                              if (( HitActor == None ) || (DeusExPlayer(HitActor) == Player))
                                 pass = True;
                           if ( !pass )
                              if ( VSize(dist) < proxRadius )
                                 if (skillTime == 0)
                                    skillDiff = -skillAtSet + Player.SkillSystem.GetSkillLevelValue(class'SkillDemolition');
                                    if ( skillDiff >= 0.0 ) // Scale goes 1.0, 1.6, 2.8, 4.0
                                       skillTime = FClamp( 1.0 + skillDiff * 6.0, 1.0, 2.5 );
                                    else   // Scale goes 1.0, 1.4, 2.2, 3.0
                                       skillTime = FClamp( 1.0   + (-Player.SkillSystem.GetSkillLevelValue(class'SkillDemolition') * 4.0), 1.0, 3.0 );
                        curPawn = curPawn.nextPawn;
                  else   // Only have scripted pawns set off promixity grenades in single player
                     foreach RadiusActors(class'ScriptedPawn', P, proxRadius*4)
                        // only "heavy" pawns will set this off
                        if ((P != None) && (P.Mass >= 20))
                           if (P != Owner)
                              dist = P.Location - Location;
                                 if (skillTime == 0)
                                    skillTime = 1.0;
simulated function DrawExplosionEffects(vector HitLocation, vector HitNormal)
   local TearGas f;
   local ParticleGenerator gen;
   local ExplosionLightGreen light;
        f = spawn(class'TearGas',,,Location + SurfaceNormal*8);
        if (f != None)
         f.RemoteRole = ROLE_None;
   gen = Spawn(class'ParticleGenerator',,, HitLocation, Rotator(HitNormal));
   if (gen != None)
      gen.RemoteRole = ROLE_None;
      gen.particleDrawScale = 0.5;
      gen.checkTime = 0.05;
      gen.frequency = 1.0;
      gen.ejectSpeed = 200.0;
      gen.bGravity = True;
      gen.bRandomEject = True;
      gen.particleTexture = Texture'Effects.Fire.proj_Prifle';
      gen.LifeSpan = 1.5;
   light = Spawn(class'ExplosionLightGreen',,, HitLocation);
   if (light != None)
      light.RemoteRole = ROLE_None;
      light.size = 6;
auto simulated state Flying
   simulated function ProcessTouch (Actor Other, Vector HitLocation)
      if (bStuck)
         return;
      if ((Other != instigator) && (DeusExProjectile(Other) == None) &&
         (Other != Owner))
         damagee = Other;
         Explode(HitLocation, Normal(HitLocation-damagee.Location));
         // DEUS_EX AMSD Spawn blood server side only
         if (Role == ROLE_Authority)
             if (damagee.IsA('Pawn') && bBlood)
               SpawnBlood(HitLocation, Normal(HitLocation-damagee.Location));
         else if
                (damagee.IsA('DeusExDecoration') && bBlood)
         else if
                (damagee.IsA('DeusExCarcass') && bBlood)
   simulated function HitWall(vector HitNormal, actor Wall)
           local vector TraceNorm, TraceLoc, Extent;
      local actor HitActor;
      if (bStickToWall)
      SetPhysics(PHYS_None);
      Velocity = vect(0,0,0);
      Acceleration = vect(0,0,0);
      PlayAnim('Hit');
           bStuck = True;
           SurfaceNormal = HitNormal;
           if ( Level.NetMode != NM_DedicatedServer )
      spawn(class'BlobPool',,,Location, rotator(SurfaceNormal));
         // MBCODE: Do this only on server side
            if (Level.NetMode != NM_Standalone)
               SetTimer(5.0,False);
            if (Wall.IsA('Mover'))
               SetBase(Wall);
               Wall.TakeDamage(Damage, Pawn(Owner), Wall.Location, MomentumTransfer*Normal(Velocity), damageType);
      if (Wall.IsA('BreakableGlass'))
         bDebris = False;
      SpawnEffects(Location, HitNormal, Wall);
      Super.HitWall(HitNormal, Wall);
     simulated function BeginState()
           local DeusExWeapon W;
         Velocity = Vector(Rotation) * Speed;
         if( Region.zone.bWaterZone )
            Velocity=Velocity*0.7;
         RandSpin(100000);
simulated function PreBeginPlay()
   // If this is a netgame, then override defaults
   if ( Level.NetMode != NM_StandAlone )
      DamageType='TearGas';
      blastRadius=192;
      bStickToWall=True;
   if ( Level.NetMode == NM_StandAlone )
      blastRadius=128;
      bStickToWall=True;
This monster of a code is my pride and joy mod weapon projectile :P
It sticks to walls, Explodes, and is Proximity triggered by enemies. (So it's basically a DX version of a Biorifle blob, using only DX stuff.)
The problem is, this code works a charm, except for when it's first launched, and when it's been proxy triggered. The problem is, it makes noises like a LAM, but i dont want these noises. So, if someone could help me, i would be most grateful :) (And there may even be a prerelease version of this, and the rest of the modpack in it for you :) )
Edit: There us nothing LAM noise related in the default properties.
Postby MainMan » Tue Jan 03, 06 10:22 pm
add the lines:
function PlayBeepSound( float Range, float Pitch, float volume )
Postby Allan » Tue Jan 03, 06 10:24 pm
Main Man wrote:add the lines:
Ok, i'll give it a try :)
Edit: Yay! it works! Thanks for that :D
