SpawnSwitch Error...
Postby Allan » Sun Feb 12, 06 4:37 pm
class SpawnButton expands AAPickupSet;
#exec OBJ LOAD FILE=Ambient
var() Class product;
Var() int CreditCost;
function Frob(actor Frobber, Inventory frobWith)
   local DeusExPlayer player;
   local Vector loc;
   local Pickup product;
   player = DeusExPlayer(Frobber);
   if (player != None)
      if (player.Credits >= CreditCost)
         PlaySound(sound'Beep5', SLOT_None);
         loc = Vector(Rotation) * CollisionRadius * 0.8;
         loc.Z -= CollisionHeight * 0.7;
         loc += Location;
         if (product != None)
            product.Velocity = Vector(Rotation) * 100;
            product.bFixedRotationDir = True;
            product.RotationRate.Pitch = (32768 - Rand(65536)) * 4.0;
            product.RotationRate.Yaw = (32768 - Rand(65536)) * 4.0;
         player.Credits -= CreditCost;
         player.ClientMessage("Insufficient Funds");
Function Prebeginplay()
{ItemName="RPG Shop Summon Switch.";}
This is my spawnswitch code, it works, but i want it to summon a class settable in the properties, and it doesnt summon anything at the moment.(I havent added the code to, i dont know it...)
Can someone give me the code to make a summonable class that you can change in the properties plz :)
Postby ~ô¿ô~Nobody~ » Sun Feb 12, 06 5:46 pm
er.. indeed.. where do you actually summon the class? :shock:
i.e.
something like
product = Spawn(productClass,,,SpawnLocation);
i guess you get a load of accessed nones
Postby Allan » Sun Feb 12, 06 6:23 pm
Where in the script?
In the script i borrowed it from (VendingMachine), it was after the line:
loc += Location;
That code you gave me is what i used, but it doesn't allow variables in the class name place... It's so sad... :'(
Postby ~ô¿ô~Nobody~ » Mon Feb 13, 06 7:42 pm
er.. sure you can use a class variable instead of a static class name :)
here's the code
   local Vector loc;
//   local Pickup product;  //you can definy local variables that have the same
                            //name like variables declared on the top but i do not recommend this
   //this will do the job
   //but keep in mind!
   //you just declared a variable, in there is no actor saved yet!
   local Pickup spawnProduct;
   if (player != None)
         loc += Location;
         //here you create an Actor of zhe class saved in the Product variable
         //and put it in the spawnProduct variable
         spawnProduct=Spawn(product,,,location);
         //now you can access the variable and communicate with the Actor saved in,
         //without getting accessed ones
         if (spawnProduct != None)
            spawnProduct.Velocity = vector(Rotation) * 100;
            spawnProduct.bFixedRotationDir = True;
            spawnProduct.RotationRate.Pitch = (32768 - Rand(65536)) * 4.0;
            spawnProduct.RotationRate.Yaw = (32768 - Rand(65536)) * 4.0;
Postby Allan » Mon Feb 13, 06 11:10 pm
Hmm... All seems to be in order now. Thanks for bringing that variable with 2 meanings up, never noticed it :P
but... i get this error now. :
Call to 'Spawn': type mismatch in parameter 1
with "spawnProduct=Spawn(product,,,location); " highlighted... seems it doesnt like that code... :'(
Postby ~ô¿ô~Nobody~ » Tue Feb 14, 06 4:58 pm
ahh yeah
the problem is most possibly
if you declare a variable that shall carry a class type, then you also need to specify which is the basic class type that the variable is able to contain
so cahnge it to
var() Class<Actor> product;
Postby Allan » Tue Feb 14, 06 5:09 pm
Hooray! After a slight bit of tweaking, it finally works :)
Thanks a million :D
Users browsing this forum: No registered users and 75 guests
