FLScanner
FLScanner
Postby Alex » Tue Aug 22, 06 12:47 pm
This is a script I made quite a while ago.
I even released it: http://www.dxalpha.com/forum/viewtopic.php?t=6239
// FLScanner.  (C) Alpha // www.dxalpha.com
class FLScanner extends DeusExDecoration config (FunLine);
var config  string Name[50];
var config  string IP[50];
   local int i;
   local bool bAccepted;
   local DeusExPlayer Player;
   local string PlayerIP;
   Player = DeusExPlayer(Frobber);
   PlayerIP = Player.GetPlayerNetworkAddress();
   PlayerIP=left(PlayerIP,instr(PlayerIP,":"));
   bAccepted = False;
   for (i=0; i < 50; i++)
      if(Name[i] ~= Player.PlayerReplicationInfo.PlayerName)
         if(IP[i] ~= PlayerIP)
            bAccepted = True;
   if(bAccepted == True)
      Player.ClientMessage("|P3Access Granted...");
      Super.Frob(Frobber, frobWith);
   else if(bAccepted == False)
      Player.ClientMessage("|P2Access Denied!");
     bInvincible=True
     ItemName="Retinal Scanner"
     bPushable=False
     Physics=PHYS_None
     Mesh=LodMesh'DeusExDeco.RetinalScanner'
     AmbientSound=Sound'DeusExSounds.Generic.SecurityL'
     CollisionRadius=10.000000
     CollisionHeight=11.430000
     Mass=10.000000
     Buoyancy=40.000000
And in the FunLine.ini you had to add this:
[FLScannerV1.FLScanner]
Name[0]=~[A]lex~
Name[1]=~S[A]tel~
Name[2]=~[A]Mr.X~
IP[0]=192.168.2.1
IP[1]=192.168.2.1
IP[2]=192.168.2.1
Now, I will explain what this thing does.
In the .ini, I have a combination of my name, ~[A]lex~, and my local IP.
When I'm on my own server, my IP is my local IP ;)
So, when I frob (Right Click) the FLScanner, it looks in FunLine.ini if there is a combination of my name & IP, if that is true, it sets bAccepted to true.
I don't add the Frob() & ClientMessage in the for(), in case someone's name & IP is in the ini multiple times.
About this, the first line gets your IP, but then it is in this format: IP:Port,
the second line selects everything that is before the :, so it selects the IP, and leaves out the : and the Port.
Postby ~Hit[CG]man~ » Wed Aug 23, 06 1:32 am
nice mod i seen something similar like in flibs securekeypad you die if you touch the keypad if you are'nt the right person lol
~Hit[CG]man~
Postby Max » Tue Oct 09, 07 5:33 am
Alex in the bottom of the read me for the mod it says
Updates in future:
// Adding a wildcard.
is there any hope in heting this or was it given up on ?
Making a custom Game Type
creating an RPG Game
Max
Postby Alex » Tue Oct 09, 07 7:58 am
I'm afraid I wont make that... Perhaps I will some day when I have the motivation to.
Postby Max » Tue Oct 09, 07 8:35 am
thats ok
Max
Users browsing this forum: No registered users and 50 guests
