Weird Problem.
Weird Problem.
Postby Cozmo » Thu Feb 01, 07 10:33 pm
Well, until today, from last Friday, my internet didn't work. So I coded alot. :)
One thing I made was a dodgy mod that lets you 'talk' to NPC's. It compiled and it's all ok, but there's weird bugs. Example, instead of taking the players name it just says MTLPRI. And it uses the pawn chess piece instead of a mesh. And it doesn't use its name. :shock:
Big, untidy code here. :D If anyone feels like going through it.
// MPConvoPawn
// Cozmo
Class MPConvoPawn2 extends ScriptedPawn;
Var DeusExPlayer ConvoPlayer;
Var() class<Pawn> AppearAsClass;
Var bool bHasWarned;
Var() String PawnsName;
// ConvoInfo
Var(Convo) int ConvoMessages;
Var(Convo) String BusyMessage;
Var(Convo) int TalkTurn;
Var(Convo) String TheWaitMessage;
Var int OnMessage;
Var int PreviousSpeed;
Var String Message;
Var bool bWasSpeaking;
Var bool IsSpeaking;
Var Float deltaTime2;
Var(Messages) String aMessage1;
Var(Messages) String bMessage2;
Var(Messages) String cMessage3;
Var(Messages) String dMessage4;
Var(Messages) String eMessage5;
Var(Messages) String fMessage6;
Var(Messages) String gMessage7;
Var(Messages) String hMessage8;
Var(Messages) String iMessage9;
Var(Messages) String jMessage10;
Var(Messages) String kMessage11;
Var(Messages) String lMessage12;
Var(Messages) String mMessage13;
Var(Messages) String nMessage14;
Var(Messages) String oMessage15;
Var(Messages) String pMessage16;
Var(Messages) String qMessage17;
Var(Messages) String rMessage18;
Var(Messages) String sMessage19;
Var(Messages) String tMessage20;
function BeginPlay()
   if(AppearAsClass != None)
      UnfamiliarName=AppearAsClass.PawnsName;
      FamiliarName=AppearAsClass.PawnsName;
           BindName=AppearAsClass.PawnsName;
      Mesh=AppearAsClass.default.Mesh;
      MultiSkins[0]=AppearAsClass.default.MultiSkins[0];
      MultiSkins[1]=AppearAsClass.default.MultiSkins[1];
      MultiSkins[2]=AppearAsClass.default.MultiSkins[2];
      MultiSkins[3]=AppearAsClass.default.MultiSkins[3];
      MultiSkins[4]=AppearAsClass.default.MultiSkins[4];
      MultiSkins[5]=AppearAsClass.default.MultiSkins[5];
      MultiSkins[6]=AppearAsClass.default.MultiSkins[6];
      MultiSkins[7]=AppearAsClass.default.MultiSkins[7];
      Texture=AppearAsClass.default.Texture;
      SetCollisionSize(AppearAsClass.default.CollisionRadius,AppearAsClass.default.CollisionHeight);
      BaseEyeHeight=AppearAsClass.default.BaseEyeHeight;
      AmbientSound=AppearAsClass.default.AmbientSound;
      SoundRadius=AppearAsClass.default.SoundRadius;
      SoundVolume=AppearAsClass.default.SoundVolume;
      Destroy();
// THIS SECTION IS TAKEN FROM THE  PAWN.UC
   local name animseq;
   local float rnd;
   local float tweentime;
   // update the animation timers that we are using
   animTimer[0] += deltaTime2;
   animTimer[1] += deltaTime2;
   animTimer[2] += deltaTime2;
   if (bIsSpeaking)
      // if our framerate is high enough (>20fps), tween the lips smoothly
      if (Level.TimeSeconds - animTimer[3]  < 0.05)
         tweentime = 0.1;
         tweentime = 0.0;
      // the last animTimer slot is used to check framerate
      animTimer[3] = Level.TimeSeconds;
      if (nextPhoneme == "A")
         animseq = 'MouthA';
      else if (nextPhoneme == "E")
         animseq = 'MouthE';
      else if (nextPhoneme == "F")
         animseq = 'MouthF';
      else if (nextPhoneme == "M")
         animseq = 'MouthM';
      else if (nextPhoneme == "O")
         animseq = 'MouthO';
      else if (nextPhoneme == "T")
         animseq = 'MouthT';
      else if (nextPhoneme == "U")
         animseq = 'MouthU';
      else if (nextPhoneme == "X")
         animseq = 'MouthClosed';
      if (animseq != '')
         if (lastPhoneme != nextPhoneme)
            lastPhoneme = nextPhoneme;
            TweenBlendAnim(animseq, tweentime);
   else if (bWasSpeaking)
      bWasSpeaking = False;
      TweenBlendAnim('MouthClosed', tweentime);
   // blink randomly
   if (animTimer[0] > 2.0)
      animTimer[0] = 0;
      if (FRand() < 0.4)
         PlayBlendAnim('Blink', 1.0, 0.1, 1);
// BACK TO MY OWN WORK.
// It's always best to avoid the Engine.u It confuses me.
   if(ConvoPlayer == None)
      ConvoPlayer = DeusExPlayer(Frobber);
      SetTimer(2.5, true);
      ConvoPlayer.ConsoleCommand("DeactivateAllAugs");
      ConvoPlayer.SetRotation(Rotation+rot(0,0,32808));
      //PreviousSpeed = ConvoPlayer.mpGroundSpeed;
      //ConvoPlayer.mpGroundSpeed = 0;
      DeusExPlayer(Frobber).ClientMessage("|p1"@BindName@": "@BusyMessage);
function Timer()
   if(OnMessage == 0)
      Message = TheWaitMessage;
   if(OnMessage == 1)
      Message = aMessage1;
   if(OnMessage == 2)
      Message = bMessage2;
   if(OnMessage == 3)
      Message = cMessage3;
   if(OnMessage == 4)
      Message = dMessage4;
   if(OnMessage == 5)
      Message = eMessage5;
   if(OnMessage == 6)
      Message = fMessage6;
   if(OnMessage == 7)
      Message = gMessage7;
   if(OnMessage == 8)
      Message = hMessage8;
   if(OnMessage == 9)
      Message = iMessage9;
   if(OnMessage == 10)
      Message = jMessage10;
   if(OnMessage == 11)
      Message = kMessage11;
   if(OnMessage == 12)
      Message = lMessage12;
   if(OnMessage == 13)
      Message = mMessage13;
   if(OnMessage == 14)
      Message = nMessage14;
   if(OnMessage == 15)
      Message = oMessage15;
   if(OnMessage == 16)
      Message = pMessage16;
   if(OnMessage == 17)
      Message = qMessage17;
   if(OnMessage == 18)
      Message = rMessage18;
   if(OnMessage == 19)
      Message = sMessage19;
   if(OnMessage == 20)
      Message = tMessage20;
   if(ConvoPlayer != None)
      if(TalkTurn == 0)
         if(OnMessage <= ConvoMessages)
            ConvoPlayer.ClientMessage("|p1"@BindName@": "@Message);
            TalkTurn = 1;
            OnMessage += 1;
            //ConvoPlayer.mpGroundSpeed = PreviousSpeed;
            ConvoPlayer = None;
            TalkTurn = default.TalkTurn;
            OnMessage = 0;
            SetTimer(0.0, false);
         ConvoPlayer.ClientMessage("|p1"@ConvoPlayer.PlayerReplicationInfo.Name@": "@Message);
         TalkTurn = 0;
         OnMessage += 1;
      LoopAnim('BreatheLight',, 0.4);
   if(OnMessage == 0)
     PawnsName="Warning, no name set!"
     GroundSpeed=0
     TheWaitMessage="(Please wait...)"
     TalkTurn=0
     ConvoMessages=0
     BusyMessage="I'm already talking to someone... Wait a minute."
Postby MainMan » Thu Feb 01, 07 11:07 pm
To make it have a mesh, set DrawType=DT_Mesh (or alternatively make it extend HumanCivilian or HumanMilitary, etc).
For the problem of the Player's name, change
to
ConvoPlayer.PlayerReplicationInfo.PlayerName
Wow, i'm surprised how similar this is to the conversation system in my mod. Great minds think alike eh?
Postby Cozmo » Fri Feb 02, 07 9:09 pm
Thanks MainMan. :D
I actually thought I'd done it really weirdly. :D
Postby Allan » Sat Feb 03, 07 6:52 pm
Wow, nice work Cozmo :D
Postby Spiderbot01 » Sat Feb 03, 07 10:07 pm
I have no idea why I asked for access to this section.
I just don't like being left out :(
Postby Cozmo » Sat Feb 03, 07 10:58 pm
Thanks Allan. :D
Re: Weird Problem.
Postby Allan » Sun Feb 04, 07 1:01 am
I've just had a look at it again, as NTL's internet's being up and down like a very bouncy something.
Prehaps to save on eye-strain, If statements, and Global Variables, you should make all the parts like "Var(Messages) String aMessage1;" into one big array, then change the If's in Timer. I think it should work like this:
// MPConvoPawn
// Cozmo
// ConvoInfo
Var int OnMessage;
Var String Message;
Var(Messages) string ConvoMessage[19]; // This is 19 "Var String"s, compressed into one bit. I think.
      Destroy();
   local name animseq;
   local float rnd;
   if (bIsSpeaking)
         tweentime = 0.1;
         tweentime = 0.0;
         animseq = 'MouthA';
         animseq = 'MouthE';
         animseq = 'MouthF';
         animseq = 'MouthM';
         animseq = 'MouthO';
         animseq = 'MouthT';
         animseq = 'MouthU';
      if (animseq != '')
   // blink randomly
      animTimer[0] = 0;
      if (FRand() < 0.4)
function Timer()
   if(OnMessage <= 0) // Set to "Less than, or Equal to", as you never
know what prat's going to try and f**k with your pawns using admin.
      Message = ConvoMessage[OnMessage-1];
      // This is -1, because Arrays start from 0, and count up, not 1.
      //Sadly, it's how the language was made, and we can't make it make more sense... :(
      if(TalkTurn == 0)
            ConvoPlayer.ClientMessage("|p1"@BindName@": "@Message); // Hmm... This might give some weird results when it's put in a ClientMessage. Not sure though
            TalkTurn = 1;
            OnMessage += 1;
            ConvoPlayer = None;
            OnMessage = 0;
         ConvoPlayer.ClientMessage("|p1"@ConvoPlayer.PlayerReplicationInfo.PlayerName@": "@Message);
         TalkTurn = 0;
         OnMessage += 1;
   if(OnMessage == 0)
     GroundSpeed=0
     TalkTurn=0
     ConvoMessages=0
     DrawType=DT_Mesh
That makes it look more neat IMO :) (I've fixed what MainMan brought up in this too :)
Postby MainMan » Sun Feb 04, 07 1:05 am
True, but I've kinda given up on neatness in coding. For example, this is a real extract from some code in my mod:
if(bullshit != none)
klopisgay += 1;
bbq.destroy();
Postby Allan » Sun Feb 04, 07 1:14 am
ROFL. What class uses a variable called "KlopIsGay"? A ScrollingScriptedTexture with "Klop Is Gay!" as the message?
Postby Mastakilla » Sun Feb 04, 07 2:32 pm
Why are people still obsessed with Klop's sexual preference :(
Postby Dae » Sun Feb 04, 07 3:51 pm
[A]MastaKilla wrote:Why are people still obsessed with Klop's sexual preference :(
Doesn't "gay" in traditional English mean something like "happy"?
Postby Gishank » Sun Feb 04, 07 4:09 pm
Indeed it does.
And Mainman... I think you'll find i'm not gay in your terms of speech.
Postby Cozmo » Sun Feb 04, 07 9:12 pm
@ Allan, yeah, I should've used arrays, but I only asked Nobody about them yesterday. :)
Postby ~ô¿ô~Nobody~ » Sun Feb 04, 07 9:32 pm
I was about to give you an example, about loops, but you needed to go. :(
Postby Cozmo » Sun Feb 04, 07 9:33 pm
~[A]N00body~ wrote:I was about to give you an example, about loops, but you needed to go. :(
Then post it here please? :D
Postby ~ô¿ô~Nobody~ » Sun Feb 04, 07 10:00 pm
Umm.. now I don't have time, but I will when I have.
Postby ~ScArFaCe~ » Sun Feb 18, 07 11:05 pm
thnx for sendin this mod 2 me. i tried it earlier and its excellent. gd job mate.
could u add some more stuff to it like item transfers? if not fair enuff :D
ScArFaCe
Sig by Baleout
~ScArFaCe~
Postby Cozmo » Sun Feb 18, 07 11:10 pm
{DXC}ScArFaCe wrote:thnx for sendin this mod 2 me. i tried it earlier and its excellent. gd job mate.
I was planning to, but at the time I didn't have an idea how to change it without having LOADS of variables. I'll try when I got time. :)
Postby Andrievskaya Veronika » Thu Apr 19, 07 1:20 pm
I have problem with MissionScript.
here is fragment (used in Function Timer()):
   if (!flags.GetBool('Skills1_given')) // Если это еще не сделано...
      ForEach AllActors(class'Greasel',G)
      Count++;
      If (count==0)
      {   // то сделать это....
         DXP.ClientMessage("You killed all greasels! So get bonus: 2000 points of skillpoints ;)");
         DXP.SkillPointsAdd(2000);
         flags.SetBool('Skills1_given', true); // и защитить от повторного получения навыка...
When all greasels killed, player should get 2000 skillpoints only ONE TIME. But skillpoints are added infinitely. What wrong? :o
Postby Alex » Thu Apr 19, 07 2:05 pm
How is your Timer initiated? by SetTimer(TIME HERE, True);?
That True value, means it loops. The function syntax is like this:
SetTimer(Time, bLoop);
(With loop it is meant that it repeats itself.)
Postby Andrievskaya Veronika » Thu Apr 19, 07 5:23 pm
I never seen this in MissionScript.
function Timer()
local Switch2 P;
local Greasel G;
local int Count;
local DeusExPlayer DXP;
DXP=DeusExPlayer(GetPlayerPawn());
      Super.timer();
Anyway, i think timer in MissionScript should always loop, to check what happening on map, etc. :)
Postby Alex » Thu Apr 19, 07 5:28 pm
I see. And I also see you use flags, to check if the player already has the reward. I personally have no experience with flags, I usually just use a boolean in the script, and check if that is set to true or false.
Postby Andrievskaya Veronika » Fri Apr 20, 07 7:55 am
oh, i solved my problem :D
function Timer()
   local Switch2 P;
   local Greasel G;
   local int Count;
               Super.timer();
// Защита от повторного нажатия кнопки. Не самая лучшая, BTW.
   if (flags.GetBool('Generator_is_on'))
      foreach AllActors(class'Switch2', P)
         P.SetCollisionSize(0, 0);
// Бонус для любителей отстрела гризелов: если убили всех то дать 2000 очков навыка.
//   if (!K)
      Count++;
      log("Count greaSelS....");
      If (count==0)
   log("No greasels for now.......");
   log("Set K to true..........");
//         K=true;
i forgot about additional brackets (after // if (!K)) :)
Postby Andrievskaya Veronika » Mon Sep 24, 07 12:21 pm
I want to randomly change skins for Greasels, using MissionScript, but i don't have idea how i can do this. Of course, i can edit my map change tag for greasels, but i don't want to touch the map...
Any ideas? For example i have 100 greasels on map and i want to change TAG to something other only for 50 of them.
Postby Dae » Mon Sep 24, 07 12:33 pm
dunno if it's what you wanted, but each object has a name which consists of a class name + index, e.g Greasel1, or Greasel14. You could create an iteration, which would run through the indexes until it reaches 50.
Postby Alex » Mon Sep 24, 07 2:46 pm
  local Greasel graySeal;
  local int i;
  ForEach AllActors(Class'Greasel', greySeal)
    if(i < 50 && greySeal != None)
      i++;
      greySeal.Tag      = 'SomeTagName';
Perhaps that works? I haven't tested it, just wrote it in this quick-post-form.
Postby Andrievskaya Veronika » Tue Sep 25, 07 12:18 pm
Yes, it woks. Thanks :)
 If (!flags.GetBool('GreaelsMarkedRed'))
      ForEach AllActors(class'Greasel', G)
    if(i < 10 && G != None)
      i++;
      G.Tag = 'RedGreasel';
         G.Skin=texture'GreaselTex2'; // Red Greasels
         G.carcassType=class'RedGreaselCarcass'; // Red carcass
         RebuildRedGreasel();
         Flags.SetBool('GreaelsMarkedRed', true);
Postby Cozmo » Tue Sep 25, 07 4:59 pm
Just out of curiosity, what's ++? Is that the same as +=1?
Postby Dae » Tue Sep 25, 07 5:09 pm
yer
Postby Alex » Thu Sep 27, 07 7:45 pm
~Cozmo~ wrote:Just out of curiosity, what's ++? Is that the same as +=1?
Not sure if it's the same in UC, but in php you have this stuff:
for($i = 0; $i < 10; $i++) (Count $i+1)
but you can also have this:
for($i = 0; $i < 10; ++$i) (Count $i+1 AFTER this current loop)
I never use ++$i though. I think it's correct, as I wrote it in the previous line. Not 100% sure though.
Users browsing this forum: No registered users and 20 guests
