Problem of speed
Moderator: Ded
Problem of speed
Postby Logos757 » Tue Oct 04, 11 7:40 pm
Hello! french guy speaking ^^
I began to play this mod yesterday and it seems great.
But I have a problem of speed (not framerate) in the game.
I explain: the game runs normally but, randomly, it becomes slower during a few seconds, and then becomes normally again. I had the same problem with Deus Ex and it sometimes disapeared when I leaved and restarted the game... but this solution does not work with 2027 !
Help! Tell me if I'm not clear enough.
Thx
Logos757
Postby Ded » Tue Oct 04, 11 8:19 pm
Try to force vertical sync in your video card settings. Also make sure that the game is using only one CPU core.
Follow 2027 at Twitter
Ded
Project 2027
Postby Logos757 » Wed Oct 05, 11 7:55 am
Thanks for the answer, but I already tried these 2 solutions and nothing has changed...
Logos757
Postby galocza » Sun Oct 16, 11 5:27 pm
galocza
Postby Ded » Sun Oct 16, 11 5:42 pm
galocza wrote:changing renderer?
http://kentie.net/article/dxguide/index.htm
There are two additional renderers in 2027 v1.2.1, so there is no need to use Kentie's launcher.
Ded
Project 2027
Postby galocza » Sun Oct 16, 11 7:58 pm
sorry, i did not know what renderer 2027 is using. i didnt mean his launcher but the renderers a bit further down on the page. it was just a thought. a bad one...
galocza
Postby Ded » Sun Oct 16, 11 9:00 pm
The default renderer is DirectX 9. There is also a build-in support for DirectX 10 from kentie.net and OpenGL in version 1.2.1 (see "classic effects" in 2027 launcher).
Ded
Project 2027
Postby Logos757 » Mon Oct 17, 11 11:27 am
... and I still have the problem :(
the speed of the game is constantly changing :roll:
apparently i'm the only one in this case :lol:
Logos757
Postby galocza » Mon Oct 17, 11 2:38 pm
Ded has written that 2027 has dx9 and dx10 support. i guess all thats left is Chris Dohnals opengl renderer:
http://www.cwdohnal.com/utglr/
but trying this would include some ini file editing and im not familiar enough with unreal based games to be able to advise on this.
you might want to browse through this topic, maybe there is some useful advice:
http://forums.steampowered.com/forums/s ... p?t=808112
but keep in mind that all solutions there are for vanilla deus ex and 2027 has its own ini (configuration) files, so if you want to try one of those that involve ini file editing you should look for those in "yourdeusexfolder"\2027\system instead of "yourdeusexfolder"\system.
galocza
Postby Ded » Mon Oct 17, 11 3:23 pm
galocza wrote:Ded has written that 2027 has dx9 and dx10 support. i guess all thats left is Chris Dohnals opengl renderer:
This OpenGL renderer is included in version 1.2.1 too.
Ded
Project 2027
Postby galocza » Mon Oct 17, 11 5:06 pm
but how can we choose/change renderer? (i dont even know which one was i using through the playthrough.)
galocza
Postby Ded » Mon Oct 17, 11 5:24 pm
galocza wrote:but how can we choose/change renderer? (i dont even know which one was i using through the playthrough.)
You can select it in the game launcher with the latest 2027 patch.
Ded
Project 2027
Postby galocza » Mon Oct 17, 11 8:12 pm
thanks, i wasnt aware of the new patch (i was busy finishing the mod), although you wrote the new version number. i didnt get suspicious even of the mentioning of classic effects.
nice work i wasnt expecting it so soon.
anyway unfortunately i have no further ideas sorry Logos757...
galocza
Postby Logos757 » Mon Oct 24, 11 2:22 pm
Finally, I made it! ^^
Thanks for your answers, but I found the solution yesterday.
I just chose the "economic profile" instead of "performance profile" before the launch of the game.
Now, the game runs at a normal speed ! there is just sometimes a drop of the framerate because of the CPU (economic profile = lower performances...) but it's cool
Logos757
Postby galocza » Tue Oct 25, 11 4:43 pm
glad it works (though the solution is unexpected).
would you consider including here somewhere your system specifications in case anybody else have this problem - motherboard, cpu, gpu, ram, operating system?
editing your first post would be the best...
g
galocza
Postby EXetoC » Wed Oct 26, 11 6:38 pm
I had this problem, and it seemed to have been caused by Cool'n'Quiet, which is a technology for AMD processors that lowers the clock rate when the processor is idle. So if all else fails, and some kind of CPU throttling is active, disable it and see if it helps.
EXetoC
Return to Project 2027
Users browsing this forum: Yandex [Bot] and 24 guests
