[MUTATOR] MMShowMessage
Postby Alex » Sun Dec 17, 06 3:51 pm
<center>MMShowMessage</center>
Description
This small mutator enables you to place a message on everyone's screen.
This message can contain multiple lines, colors and of course text.
Example:
This is 1 showmessage.
The command for the example is:
Mutate Game.ShowMessage This is a showmessage|n|n|p2This is a showmessage|n|p5This is a showmessage
The |n indicates a new line. And the |p2 or any other number instead of 2, indicates a color. The | symbol can be found here:
Installation
The installation of this thing is quite easy.
You just place MMShowMessage100.u in your System folder, and then you open DeusEx.ini and you look for "[DeusEx.DeusExGameEngine]"
Below that, add the following:
ServerPackages=MMShowMessage100
ServerActors=MMShowMessage100.MessageMutator
Usage
To use this mutator, you need to be logged in as admin.
If you are, you just type:
Mutate Game.ShowMessage [Message]
And you can use |n as a new line, and |p0 to |p7 for colors.
You can also use HEX values, they are as following:
|c[HEX Value]
Do not add the # though, it's not HTML :)
Thanks
Thanks Nobody :) You helped me with a small thing, but without that, I would've given up, so many thanks!
MMShowMessage100.u
(4.41 KiB) Downloaded 1850 times
Postby Dae » Sun Dec 17, 06 4:14 pm
Good work :D
Only issue - methinks Game.ShowMessage as a command is too long. I'd suggest simply "mutate msg"
Postby ~ScArFaCe~ » Sun Dec 17, 06 6:03 pm
wow nice mod :D ill put tht in my server
ScArFaCe
Sig by Baleout
~ScArFaCe~
Postby ~ô¿ô~Nobody~ » Sun Dec 17, 06 6:09 pm
~[A]Daedalus~ wrote:Good work :D
Well, since it must look 1337, it must be Game.ShowMessage :P
Postby Dae » Sun Dec 17, 06 6:11 pm
it should have been "g4m3.sh0wm3ss4g3" then :P
Postby ~ô¿ô~Nobody~ » Sun Dec 17, 06 6:29 pm
OW.. You just animated him to change it :lol:
Postby Alex » Sun Dec 17, 06 6:57 pm
Wrong, it should've been g4/\/\3.5h0\/\//\/\3554g3
EDIT: Thanks supercrazy :)
Postby Cozmo » Sun Dec 17, 06 7:00 pm
Nice, don't you have to go through alot of HUD crap though? :shock:
Postby ~ô¿ô~Nobody~ » Sun Dec 17, 06 8:10 pm
You forgot he is 1337, thus it's irrelevant for him. :P
Postby Mastakilla » Sun Dec 17, 06 8:19 pm
And he also happens to be extremely sexy. Just like this mutator, nice work <3
Postby Kaiden » Sun Dec 17, 06 8:44 pm
Clever mod! Putting it on my server now. :)
Wow, this is your third released mod in like 10 minutes hehe, the other two arn't very useful to me but they look well made! Keep up the excellent mod making!!
Postby Kaiden » Mon Dec 18, 06 1:01 am
*Update*
Ok, now I'm getting this error whenever I try to host the server:
I have the .u file in my system folder and I added both the lines to my INI. Attached Server.log:
server.log
Server.log of error.
(4.76 KiB) Downloaded 2198 times
Postby Alex » Mon Dec 18, 06 9:24 am
As the error says, it cannot find the file :) Make 100% sure that you have the file in your System folder.
Postby ~ScArFaCe~ » Mon Dec 18, 06 6:34 pm
ahhh kaiden i had tht problem. u see after the mmshow100 there is a space. if u look at the failed part u can see a space between the '. so in ur ini u gtta delete the space it cuz it dont recognize the name?
ScArFaCe
Sig by Baleout
~ScArFaCe~
Postby Kaiden » Tue Dec 19, 06 12:41 am
Ha, so it does! Thanks Super. I copied the name directly from here so I must of included a space hehe. Cheers anyway!
Postby Alex » Tue Dec 19, 06 7:39 am
Can't help that phpBB placed the space... sorry for that ;)
Postby ~ScArFaCe~ » Tue Dec 19, 06 6:50 pm
hehe nps...still a great mod.. :D
ScArFaCe
Sig by Baleout
~ScArFaCe~
Postby Imperial » Mon Jan 29, 07 3:38 pm
Another one :) lol
Attached.
Just directing to link this time.
MMShowMessage100.zip
(1.68 KiB) Downloaded 1717 times
Return to alpha laboratories
