Alrighty's poolparty badnameindex
Postby {17}KnightMare » Thu Sep 18, 08 8:47 pm
I tried to open up Alrighty's poolpartynewb3, but it came up blank (yno, when you havent loaded the .u files it needs) so i tried to load in alightygamev3, assuming that's what i needed, but it came up with a badnameindex error. I tried with alrightygamev2 but same thing. What mod do I need to open alrighty maps, and if it is alrightygame (I don't think so) how an i get it open?
{17}KnightMare
Postby Kaiden » Fri Sep 19, 08 1:25 am
Uh can you post your Editor.log and Server.log (I think they are, out of practice lol). Found in C:DeusEx/System.
Although his maps might be protected so you can't open them in the Map Editor (SDK).
Postby Dae » Fri Sep 19, 08 7:45 am
Possibly he's protected them.
Postby {17}KnightMare » Sat Sep 27, 08 6:43 pm
probably protected yeah
found it! I think
Warning: Failed to load 'poolparty': Can't find file for package 'poolparty'
Warning: Failed to load 'C:\DeusEx\alrightys_poolparty_newb3\alrightys_poolparty_newb3.dx': Can't find file for package 'poolparty'
Warning: Failed loading package: Can't find file for package 'poolparty'
So I'm missing the 'poolparty.u' file?
EDIT: Checked the FA, can't find the file
{17}KnightMare
Postby Crusader » Sat Sep 27, 08 7:51 pm
See attachment..
poolparty.u
poolparty.u
(747.78 KiB) Downloaded 309 times
Crusader
Postby {17}KnightMare » Thu Oct 09, 08 8:17 pm
I have another problem, it nows says it cant find the 'Arbb' file?
Any help?
{17}KnightMare
Postby .:::WhyJustSmile » Fri Oct 10, 08 4:37 am
hey arbb is here :
http://deusex.ca/archive/index.php?dir=Deus%20Ex%201/
and arbb money not needed just dedicated and work and have a nice day 8) 8)
.:::WhyJustSmile
Postby Jon » Fri Oct 10, 08 10:57 am
Dae wrote:Possibly he's protected them.
The map wouldn't even register a missing package error if it was protected.
Postby Dae » Fri Oct 10, 08 11:12 am
Jon wrote:The map wouldn't even register a missing package error if it was protected.
initially {17}KnightMare mentioned only "badname index" error
Postby Jon » Fri Oct 10, 08 11:13 am
Yes, but surely it wouldn't be protected if he had seen said error?
Postby .:::WhyJustSmile » Tue Oct 14, 08 3:44 am
hey me i got no problem why i dont know but i can run all alrighty map !!!!! ??????
.:::WhyJustSmile
Postby ~ô¿ô~Nobody~ » Fri Oct 24, 08 5:26 pm
Bad nameindex comes from MTL.
When the map gets loaded, it loads alrightygame, which needs MTL. Then boom.
Postby {17}KnightMare » Mon Dec 08, 08 6:28 pm
WjS, i click the link and it says 404 Page Not Found? i got onto deusex.ca
and go into archive and that looks all wierd too, it has a page (deusex.ca/archive) with 2 links, one to parent directory (deusex.ca) and one to a page called Deus Ex 1, so I click deus ex 1 and a new page with 3 links, Parent directory (leads to deusex.ca/archive) DXMP.zip which is a zip file called DXMP.zip, and Maps. I click maps and nothing is in there, just a link named parent directory. Problem :S. Nobody, I have alrightygame and MTL 15211b (i think) so should I delete them or something?
{17}KnightMare
Postby ~ô¿ô~Nobody~ » Tue Dec 23, 08 1:00 am
You can download my modified DXMTL152b1 version, that works as normal in game but also for the SDK.
