fast changing map
fast changing map
Postby CvendaCZ » Mon Nov 24, 08 12:55 pm
i have got launched server,and i have got 2 maps,i need change map but i dont will disconect server and launch server with my second map.
How i can change map on my server??
CvendaCZ
Postby MrBlackDX » Mon Nov 24, 08 1:39 pm
1)
if you are connected to your server as a player, you will need to login with the prompt
"adminlogin YOURPASSWORD"
And then you can use the following to change maps
"admin servertravel YOURMAP"
So I have two maps on my DXAG server, DXAG_UNATCOAG and DXAG_ELANIAAG
Once I have logged in as an admin, I then use the prompt
"admin servertravel DXAG_UNATCOAG" to switch from elania to unatco
2)
If you are running a dedicated server, you can simply change maps by typing in the UnrealServer command section with;
"servertravel YOURMAP"
Again the example would be
"servertravel DXAG_ELANIAAG"
Postby Kaiden » Mon Nov 24, 08 1:41 pm
admin servertravel DXMP_Area51Bunker, I think. Replace Area51 with the map you want.
Postby CvendaCZ » Mon Nov 24, 08 1:42 pm
thx,and....if i click on decidated,players can come on server but .....no map....there is black room and they cant move...
CvendaCZ
Postby Gishank » Mon Nov 24, 08 7:55 pm
That's most likely because the map you selected is missing (typo in the name when map changing) or, you're missing a specific package which the map requires to function.
