Can't open my map after re-installing windows
Postby ~[ß]Lost~ » Sun Aug 23, 09 5:13 pm
Yeah, I never had problems with my new map before I re-installed Windows last night. I use Unreal Ed 2 with 64-bit Vista.
Here's the editor log
Log: Log file open, 08/23/09 19:05:17
Init: Detected: Microsoft Windows NT 6.0 (Build: 6001)
Init: Version: 432
Init: Compiled: Oct  4 2000 21:31:15
Init: Command line:
Init: Base directory: D:\Pelit\DeusExMini\UEd2\
Init: Character set: Unicode
Log: Bound to Editor.dll
Log: Bound to Core.dll
Log: Bound to Engine.dll
Log: Bound to Window.dll
Init: Computer: SIKEPC
Init: User: sike
Init: Memory total: Phys=4194303K Pagef=4194303K Virt=2097024K
Init: CPU Speed=3005.551877 MHz
Init: CPU Page size=4096, Processors=2
Init: CPU Detected: PentiumPro-class processor (GenuineIntel)
Log: Bound to Galaxy.dll
Init: Galaxy is using WinMM
Init: Galaxy initialized
Init: Transaction tracking system initialized
Log: Bound to Fire.dll
Log: Bound to IpDrv.dll
Log: Bound to WinDrv.dll
Init: Mouse info: 6 10 1
Init: Initializing DirectDraw
Log: DirectDraw drivers:
Log:    display (Primary Display Driver)
Init: DirectDraw initialized successfully
Init: Client initialized
Log: Bound to Render.dll
Init: Lighting subsystem initialized
Init: Rendering initialized
Init: Editor engine initialized
Log: Startup time: 0.645639 seconds
Init: Input system initialized for U2Viewport0
Log: Opened viewport
Log: Bound to SoftDrv.dll
Init: Input system initialized for U2Viewport1
Init: Input system initialized for U2Viewport2
Init: Input system initialized for U2Viewport3
Log: 4.00 314.00 219.00 153.00
Init: Input system initialized for MeshViewer
Init: Input system initialized for TextureBrowser
Log: New File, Existing Package (Package MyLevel, Package DXMP_VS34)
Critical: appError called:
Critical: Ran out of virtual memory. To prevent this condition, you must free up more space on your primary hard disk.
Critical: Windows GetLastError: Not enough storage is available to process this command. (8)
Exit: UGalaxyAudioSubsystem::ShutdownAfterError
Warning: glxStopOutput() failed: 6
Exit: Executing UWindowsClient::ShutdownAfterError
Log: DirectDraw End Mode
Critical: FMallocWindows::Malloc
Critical: FMallocWindows::Realloc
Critical: 00000000 -229348 FArray
Critical: FArray::Realloc
Critical: -8191*28
Critical: TArray<<
Critical: UModel::Serialize
Critical: LoadObject
Critical: (Model MyLevel.Model1 3761537==3761537/7128569 1374573 4039499)
Critical: ULinkerLoad::Preload
Critical: PreLoadObjects
Critical: UObject::EndLoad
Critical: UObject::LoadPackage
Critical: UEditorEngine::Exec
Critical: (MAP LOAD FILE="D:\Pelit\DeusExMini\Maps\DXMP_VS34.dx")
Critical: WEditorFrame::OnCommand
Critical: WM_HSCROLL
Critical: WWindow::WndProc
Critical: WWindow::StaticProc
Critical: DispatchMessage
Critical: 00040560 273
Critical: MessagePump
Critical: MainLoop
Exit: Exiting.
Uninitialized: Log file closed, 08/23/09 19:05:24
Could it really be virtual memory? I have 6GB of 800MHz DDR2.
Sike
clanb.deus-ex.net
~[ß]Lost~
Postby Mr. Tastix » Sun Aug 23, 09 8:04 pm
I blame Vista. Have you done all the usual shit you'd do in Vista when something doesn't work (admin mode, compatibility options that pretty much don't do jack shit anyway)?
Postby ~[ß]Lost~ » Sun Aug 23, 09 9:01 pm
Every other map works fine and so did this one before I re-installed, which is strange.
Waiting for some tech pro to reply...
Sike
clanb.deus-ex.net
~[ß]Lost~
Postby MainMan » Sun Aug 23, 09 9:16 pm
Can you get it to load in UEd 1?
Postby ~[ß]Lost~ » Sun Aug 23, 09 9:25 pm
I don't have UEd 1. Where can I download it, just can't be fucked searching.
Sike
clanb.deus-ex.net
~[ß]Lost~
Postby MainMan » Sun Aug 23, 09 10:18 pm
try the dxalpha archives
Postby ~[ß]Lost~ » Sun Aug 23, 09 11:07 pm
Gives me the same error
Log: Log file open, 08/24/09 01:03:46
Init: Version: 1100
Init: Command line:
Init: Base directory: D:\Pelit\DeusExMini\System\
Init: User: sike
Init: CPU Speed=3004.347717 MHz
Log: Loading: Package Editor
Log: Loading: Package Core
Log: Loading: Package Engine
Log: Loading: Package Fire
Log: Loading: Package IpDrv
Log: Loading: Package UWindow
Log: Loading: Package UBrowser
Log: Bound to Extension.dll
Log: Loading: Package Extension
Log: Loading: Package DeusExUI
Log: Bound to ConSys.dll
Log: Loading: Package ConSys
Log: Loading: Package DeusExConversations
Log: Loading: Package DeusExSounds
Log: Loading: Package DeusExItems
Log: Loading: Package Effects
Log: Loading: Package DeusExDeco
Log: Loading: Package DeusExCharacters
Log: Loading: Package MPCharacters
Log: Bound to DeusExText.dll
Log: Loading: Package DeusExText
Log: Loading: Package IpServer
Log: Bound to DeusEx.dll
Log: Loading: Package Ambient
Log: Loading: Package MoverSFX
Log: Loading: Package Render
Log: Startup time: 1.757326 seconds
Cmd: HIDELOG
Cmd: APP SET ProgressBar=919054 ProgressText=919004
Cmd: APP HIDE
Cmd: MAP GRID X=16 Y=16 Z=16 BASE=ABSOLUTE SHOW2D=ON SHOW3D=OFF
Cmd: MAP ROTGRID PITCH=4 YAW=4 ROLL=4
Cmd: MODE CAMERAMOVE GRID=ON ROTGRID=ON SNAPTOPIVOT=ON SNAPDIST=10
Cmd: CAMERA OPEN HWND=984628 X=0 Y=0 XR=919 YR=473 FLAGS=1737 REN=13 NAME="Standard1V"
Init: Input system initialized for Standard1V
Cmd: SETPAUSE 0
Cmd: CAMERA OPEN HWND=984628 X=928 Y=0 XR=473 YR=473 FLAGS=1737 REN=14 NAME="Standard2V"
Init: Input system initialized for Standard2V
Cmd: SETPAUSE 1
Cmd: SETPAUSE 0
Cmd: CAMERA OPEN HWND=984628 X=0 Y=483 XR=919 YR=474 FLAGS=1993 REN=5 NAME="Standard3V"
Init: Input system initialized for Standard3V
Cmd: SETPAUSE 1
Cmd: SETPAUSE 0
DevAudio: Galaxy SetViewport: Standard3V
Cmd: CAMERA OPEN HWND=984628 X=928 Y=483 XR=473 YR=474 FLAGS=1737 REN=15 NAME="Standard4V"
Init: Input system initialized for Standard4V
Cmd: SETPAUSE 1
Cmd: SETPAUSE 0
Cmd: SETPAUSE 1
Cmd: CAMERA UPDATE X=10 Y=0 XR=144 YR=803 FLAGS=8777 HWND=67430 MISC1=64 MISC2=0 REN=17 NAME=BrowserCam PACKAGE="(All)" GROUP="(All)"
Init: Input system initialized for BrowserCam
Cmd: SETPAUSE 0
Cmd: SETPAUSE 1
Cmd: CAMERA OPEN X=10 Y=0 XR=144 YR=803 FLAGS=8777 HWND=67430 MISC1=64 MISC2=0 REN=17 NAME=BrowserCam PACKAGE="(All)" GROUP="(All)"
Cmd: SETPAUSE 0
Cmd: ParseLeftClick
Cmd: Fire
Cmd: ParseRightClick
Cmd: ParseLeftClick
Cmd: Fire
Cmd: SETPAUSE 1
Cmd: MAP LOAD FILE="D:\Pelit\DeusExMini\Maps\DXMP_VS34.dx" REDRAW=OFF
Log: Loading: Package MyLevel
Log: Loading: Package CoreTexMetal
Log: Loading: Package CoreTexDetail
Log: Loading: Package NewYorkCity
Log: Loading: Package CoreTexWood
Log: Loading: Package area51textures
Log: Loading: Package Catacombs
Log: Loading: Package Paris
Log: Loading: Package CoreTexEarth
Log: Loading: Package HK_BuildingExt
Log: Loading: Package CoreTexBrick
Log: Loading: Package CoreTexStone
Log: Loading: Package Rocket
Log: Loading: Package CoreTexGlass
Log: Loading: Package CoreTexSky
Log: Loading: Package Airfield
Log: Loading: Package CoreTexMisc
Log: Loading: Package CoreTexWater
Log: Loading: Package DetailTest
Log: Loading: Package ParisCathedral_Music
Critical: -8191*28
Critical: TArray<<Critical>=2 [File:..\..\Engine\Inc\UnLevel.h] [Line: 222]
Log: appRequestExit(1)
Log: Log file closed, 08/24/09 01:04:03
Is it possible that my map somehow got corrupted?
Sike
clanb.deus-ex.net
~[ß]Lost~
Postby Dae » Sun Aug 23, 09 11:32 pm
~[ß]Lost~ wrote:Is it possible that my map somehow got corrupted?
possible
try to open your map in any text editor and check the file for suspicious stuff, like dots filling the end of it
Postby ~[ß]Lost~ » Mon Aug 24, 09 9:30 am
Just remembered I saved a copy of this map to a USB stick. Not much was lost after all...
Sike
clanb.deus-ex.net
~[ß]Lost~
Users browsing this forum: No registered users and 43 guests
