SDK INSTALL PROBLEM
SDK INSTALL PROBLEM
Postby ~s0ap~ » Wed Nov 18, 09 2:33 am
k this is fucking worse than a john queer tractor or combine. i got dx to install and it appears in add/remove programs and now sdk wont install because it says deus ex needs to be installed in the folder wtf is this bs
~s0ap~
Postby Allan » Wed Nov 18, 09 5:47 am
Which DX version do you have? Because the widely avaliable SDK pack only works with version 1.12fm.
(Basically, if you can play DX online, you've got the right version.)
Postby Dae » Wed Nov 18, 09 6:00 am
You may bypass the check by installing SDK manually. Right click on the .exe, open it with your favorite unarchiver, drag and drop the contents onto your Deus Ex folder which you would have to find manually on your drive. After doing that, find ConEdit folder and install ConEdit.
