Deus Ex Fix - Multiprocessor fix, fast/flow/jitte, warp etc
Postby Hasharin » Sun Jan 31, 10 5:51 pm
Hey Alpha
This program is pretty simple, it allows one to apply various fixes to get Deus Ex to run well. Here's a feature list:
-Multiprocessor fix. Applies the fix that lets DX only use one processor/core. Fixes fast/slow/jittery gameplay.
-Processor throttling disabling. Disables CPU throttling (in the same way it's done from the Windows control panel). Again, fixes fast/flow/jitte
and much more
Download at: http://kentie.net/article/dxguide/
If you have friends that stoped playing deus ex due to that they had this problems, please let them know that theres a fix
(once you downlaoded it maybe you have to make a manual browse for locate deus ex folder unless you have bought deus ex on steam)
Hasharin
Postby -TheSpecialist- » Sun Jan 31, 10 6:06 pm
Or you could just install mtl on your server, since that is also part of the problem for some people.
- Tracer - Thief - Osborne -
-TheSpecialist-
Postby MainMan » Sun Jan 31, 10 6:34 pm
That has nothing to do with it..? And he can't because it's a server for foreign copies of DX which cannot properly support MTL. n00b down, you "specialist"
Postby Wasted. » Sun Jan 31, 10 8:59 pm
someone unban me from dios already
Wasted.
Postby -TheSpecialist- » Sun Jan 31, 10 9:57 pm
"for some people"
Like myself since playing in a non mtl server is less fluid experience than playing on an mtl server with the same ping.
-TheSpecialist-
Postby MainMan » Sun Jan 31, 10 10:19 pm
Why are you going on about MTL? This is a hardware/local fix you absolute n33b. Pipe down and get back in your briefcase
Postby synthetic » Sun Jan 31, 10 11:05 pm
I see little reason in playing dxmp nowadays since just about every second player has odd fire. I am no longer sure where the hax ends and my paranoia begins, but shits ridiculous. I recall certain friends of mine reporting faster belt switch times and scope times, but isnt that fixed in the game? And if those times increase so does the speed of other actions? It has been already proven that you can shoot faster with certain set up, and even move faster (consequently also taking fire from ie turrets faster). You can adjust to ping/lag somewhat, but what the fuck do you do when random blokes shoot faster than you? Its just ridiculous.
I saw some beginner stand still and go 6-0 the other day while both other teams, consisting of few decent players as well, strugged to get that score in such a small time. I myself got killed by that guy couple times. He didnt warp, he just shot faster, and theres nothing to complain about because the guy probably doesnt even understand that he does, or wont understand.
Postby TBD » Tue Feb 02, 10 6:12 pm
well thats a fail,
the program cant find my deus ex folder, and when i point it towards it, it says its an invalid install of deus ex..
and the other fix (for gui probs) also doesnt work..
i copied the 3 files to deus ex system folder:
changed res and color
got back to deus ex
starts up, goes to server and kicks me right back out.. any ideas??
edit: it only doenst work in multiplayer, singleplayer is fixed (1920*1080)
multiplayer i have to run on 1360*768 - >thats the highest it can take so far
TBD
Postby Alex » Tue Feb 02, 10 6:19 pm
TBD wrote:well thats a fail,
got back to deus ex
You got haxed by ze Spanish haxxers m8.
Postby Hasharin » Tue Feb 02, 10 6:45 pm
TBD when the program says it doesnt locate deus ex cant you make a manual browse for locate dx?
when you get kicked out the server what error message did you get?
Hasharin
Postby TBD » Tue Feb 02, 10 7:37 pm
k so now i got the program working,
and i changed the resolution to 1920*1080 and non-scaling GUI
but when i start up multiplayer this happens:
i enter the server
message comes in upper left corner:
invalid rootwindow class, disconnecting
goes back to main deus ex start up screen
what was good was that the res was indeed in 1920*1080
when i choose the option 1920*1080 and default gui, it gives me a 640*480 resolution ingame but doesnt crash
TBD
Postby Alex » Tue Feb 02, 10 8:54 pm
Guess what that is. Anti cheat. (i think) Changing rootwindow is not allowed, you got kicked by either my or Nobody's anti cheat program. No way to get around it.
Postby Professor Layton » Tue Feb 02, 10 8:56 pm
Isn't it just deusex itself or MTL?
Postby TBD » Tue Feb 02, 10 9:08 pm
so any other way to change res then? since hash's link works only half..
TBD
Postby Alex » Tue Feb 02, 10 10:13 pm
Clix wrote:Isn't it just deusex itself or MTL?
Also possible, no idea. I think my mod checked for rootwindow as well though, just like miniMTL.
Postby Hasharin » Wed Feb 03, 10 1:56 pm
Hey TBD
in deusex.ini
under [engine.engine], it says Root=DeusEx.DeusExRootWindow and not something else. Maybe something went wrong when you tried to mess with GUI scaling
Hasharin
Postby Dae » Wed Feb 03, 10 2:11 pm
Hasharin wrote:Maybe something went wrong when you tried to mess with GUI scaling
the entire GUI scaling fix is not possible without altering Root Window afaik
Postby ~ô¿ô~Nobody~ » Wed Feb 03, 10 6:19 pm
Then play in 800x600 already :!:
I would prefer to hast fast FPS bug than the silly slow FPS bug I'm having.. :x
Postby TBD » Thu Feb 04, 10 6:32 pm
Hasharin wrote:Hey TBD
in deusex.ini
when i try to change it to 1920*1080 it changes
to the Opt thing
TBD
Postby Hasharin » Tue Feb 09, 10 3:54 pm
TBD better you forget this program or will ruin your settings <.< the problem you had was warping and fastshot?
Hasharin
Postby TBD » Tue Feb 09, 10 8:09 pm
i used to have problems of fps - fastfiring
solved those a few months ago with tweaking some settings
the only reason i dlded your prog was to enhance my screen res
i got a new mon 1920*1080 so i wanted to try that out in dx
TBD
Postby [FGS]Fear » Thu Feb 11, 10 3:09 am
lol ive just got a new monitor to, 1920x1080, im getting problems too
[FGS]Fear
Postby ~ô¿ô~Nobody~ » Fri Feb 12, 10 1:37 pm
You CANNOT play DX with HD display, simply FACE IT!
use this instead:
Postby synthetic » Sat Feb 13, 10 1:04 am
Postby Hasharin » Sat Feb 13, 10 3:34 am
LOL that made me laugh XD
Hasharin
Postby -HDD21- » Sun Feb 14, 10 12:04 pm
Noticed that when i tried to connect... seems like the entire 86 pool is banned LOL
-HDD21-
Postby ~ô¿ô~Nobody~ » Mon Feb 15, 10 12:31 pm
Noob administration there. :lol:
Postby Kaiden » Mon Feb 15, 10 6:22 pm
Now I won't be able to play on it! :(((
Users browsing this forum: No registered users and 34 guests
