MultiDX Problem:
MultiDX Problem:
Postby {HK} » Thu Mar 25, 10 1:16 am
Hi Alpha,
I'm trying to host Alex's MultiDX. I followed the instructions exactly for the deusex.ini and installed all 4 files into the /system folder. However, nothing happens. Does anyone know how to get it to work?
Much appreciated,
[/b]
{HK}
Postby Dae » Thu Mar 25, 10 4:30 pm
How do you launch the server?
Postby {HK} » Thu Mar 25, 10 4:36 pm
I start dx normally and click multiplayer than click host game and then repeatedly press gametype in the desperate hope that multidx will show up...
it does not.
{HK}
Postby Dae » Thu Mar 25, 10 7:02 pm
I'm not sure if it should. Try launching using a batch file:
deusex.exe DXMP_Smuggler?Game=MultiDX.Manhunt
Postby {HK} » Thu Mar 25, 10 7:08 pm
I typed that code into command prompt and nothing happened. Only the game started. Alas, Alex where art thou?
{HK}
Postby MainMan » Thu Mar 25, 10 7:10 pm
Do it as a batch file which you place in your DeusEx\System directory.
Postby {HK} » Thu Mar 25, 10 7:13 pm
Ok. I made what I think is a .bat file. i just saved the code into the system directory. The same thing happened as well.
{HK}
Postby Dae » Thu Mar 25, 10 8:48 pm
{HK} wrote:Ok. I made what I think is a .bat file. i just saved the code into the system directory. The same thing happened as well.
Did it even execute? (Did you see the black window same as the command-line prompt?)
Postby {HK} » Thu Mar 25, 10 8:49 pm
Yes.
{HK}
Postby Dae » Thu Mar 25, 10 10:48 pm
Could you please open server.log and find an error?
Postby {HK} » Fri Mar 26, 10 4:55 am
Hey! I think I found something.
This command line works:
C:\deusex\system deusex.exe DXMP_Sile?Game=MultiDX.Manhunt?-server?log=server.log
Do you know how to change my deusex.ini so that it will run this server command instead of the default one?
Much appreciated,
{HK}
Postby Dae » Fri Mar 26, 10 10:20 am
{HK} wrote:Do you know how to change my deusex.ini so that it will run this server command instead of the default one?
I don't understand your question.
{HK} wrote:This command line works:
<s>It means that you created the .bat file outside DeusEx/System then.</s> < that's me, I forgot -server part
{HK} wrote:C:\deusex\system deusex.exe DXMP_Sile?Game=MultiDX.Manhunt?-server?log=server.log
maybe Silo?
Postby {HK} » Fri Mar 26, 10 2:04 pm
I mean is there a way to change the default start up script so that when I click deusex.exe it will have the multidx gametypes options and not the dxmtl ones?
{HK}
Postby MainMan » Fri Mar 26, 10 2:14 pm
No. You would never do that anyway. If you can't host it with a batch file then something is wrong, and you won't fix it by trying to host it in-game...
Postby Dae » Fri Mar 26, 10 2:41 pm
{HK} wrote:I mean is there a way to change the default start up script so that when I click deusex.exe it will have the multidx gametypes options and not the dxmtl ones?
maybe there is, but I don't know how to do that
don't want to sound snobbish, but I always used batch files to launch the servers. they're faster and more flexible (i.e. you can have several deusex.ini's with totally different server configurations and launch them using several bat files)
Postby {HK} » Fri Mar 26, 10 4:08 pm
Oh. I remember when I originally hosted MultiDX, you could actually select the gametype in the menu host screen.
Hey thanks though. Once again, Dae saves me hours of frustration.
Also, how can you use several different deusex.ini's? Please explain.
:twisted:
{HK}
Postby DxPlayer » Fri Mar 26, 10 4:12 pm
I think you didn't add MultiDx's [Engine.Engine]DefaultGame= to your DeusEx.ini :P . However bats are a great solution if you don't want to change your DeusEx default game for some reason.
DxPlayer
Postby {HK} » Fri Mar 26, 10 4:18 pm
What shoudl I add to deusex.ini??
{HK}
Postby Dae » Fri Mar 26, 10 7:47 pm
{HK} wrote:Also, how can you use several different deusex.ini's? Please explain.
as far as I can remember you need the -ini parameter, e.g.
deusex.exe DXMP_Silo?Game=MultiDX.Manhunt?-server?log=server.log?ini=MyNewDeusEx.ini
(make a new file like MyNewDeusEx.bat and paste that into it, also make MyNewDeusEx.ini as a copy of DeusEx.ini)
If you want to host multiple servers at the same time, make sure to change Port= variable in your MyNewDeusEx.ini (by default it goes on 7790, you may choose 7780).
If you want to change gameplay parameters, adjust the following part:
[DeusEx.DeusExMPGame]
SkillsTotal=2000
SkillsAvail=0
SkillsPerKill=0
InitialAugs=0
AugsPerKill=0
ScoreToWin=25
VictoryCondition=Time
MPSkillStartLevel=3
CurrentMap=DXMP_Cmd
fFriendlyFireMult=0.000000
I believe it's all self-explanatory.
If you do not want to host another MultiDX server with your new MyNewDeusEx.ini, make sure to revert changes the installation procedure asked you to do. Make sure you get rid of references in ServerPackages= and ServerActors= of mods you don't need on the new server.
