Binds (repost)
Postby Gishank » Fri Aug 25, 06 1:56 pm
I have soldout, and i only changed the DX ini not default and it work for me.
As i said earlier is there any way of having a random name bind?
Postby Mastakilla » Fri Aug 25, 06 2:37 pm
Sh¤gån wrote:I have soldout, and i only changed the DX ini not default and it work for me.
I don't think so, editing your .ini is something else then coding you know :)
Re: Binds (repost)
Postby {17}Ales » Fri Oct 20, 06 5:41 pm
~[A]Daedalus~ wrote:I don't know the author of this article (it wasn't me). If anyone knows who made that, please let me know. BBCode by General Joey.
How do I do keybinds?
Open User.INI in your C:\DeusEx\System directory(May differ if you have installed the game in another directory, this is default.). You will notice that all keys are in there twice. The first section is for single player, and the second is for multiplayer. You can put each bind in twice if you want to, but if you only play MP then you just have to put them in the bottom section.
Near the bottom. You will see a list of your key 'bindings' that you have set in game. Just copy and paste any of the below binds to whichever key you want to action that particular bind. Blue is mainly for augs binds,Red is for both gametypes.
For example:
E=ActivateBelt 9|onrelease ParseLeftClick|ActivateBelt 2
Pressing 'E' brings out a med, releasing it brings out fully loaded weapon in slot 2.
About Aliasses
An alias is used to mainly make things easier. It saves you the trouble of having to type/copy-paste the bind over and over again, and just lets you use a name for it, like TurnAround or MedKit. :) You use the next unused number for the [number] bit. Like
Aliasses[22]=(Command="YourBind",Alias=NameYouWantToUse)
In this guide 22 is used as default number, however you should change the number to what the next unused number is. After doing that, type the bit after Alias= behind the key you want to use.
Binds
LeftMouse=ActivateAugmentation 3|Fire|on release ActivateAugmentation 3
This bind enables Targetting/Ballistic Protection, then fires, and when you let go of the mouse button, it disables Targetting/Ballistic Protection. Great if you want to conserve bio.
yourkey=ActivateBelt 0|onrelease ParseleftClick
This bind is for grabbing your MedKit or Biocell.
Aliases[22]=(Command="Axis aBaseX Speed=+2900.0",Alias=TurnAround)
A tap turns you around so you can face behind you instantly.
Uses a med then pulls out weapon in belt 2.
ActivateBelt 1|BuySkills|ActivateBelt 1|BuySkills|ActivateBelt 1
ActivateBelt 2|BuySkills|ActivateBelt 2|BuySkills|ActivateBelt 2
ActivateBelt 3|BuySkills|ActivateBelt 3|BuySkills|ActivateBelt 3
ActivateBelt 4|BuySkills|ActivateBelt 4|BuySkills|ActivateBelt 4
ActivateBelt 5|BuySkills|ActivateBelt 5|BuySkills|ActivateBelt 5
ActivateBelt 6|BuySkills|ActivateBelt 6|BuySkills|ActivateBelt 6
ActivateBelt 7|BuySkills|ActivateBelt 7|BuySkills|ActivateBelt 7
ActivateBelt 8|BuySkills|ActivateBelt 8|BuySkills|ActivateBelt 8
ActivateBelt 9|BuySkills|ActivateBelt 9|BuySkills|ActivateBelt 9
ActivateBelt 0|BuySkills|ActivateBelt 0|BuySkills|ActivateBelt 0
Updates skills and equips the relevent belt item. Can be used on anything. 1 is Heavy, 2 is Pistols, 3 is Rifles, 4 is Melee, 5 is Grenades, 6 is Enviro, 7 is Lockpicks, 8 is Multitools, 9 is Medicine, 0 is Hacking.
Aliases[22]=(Command="Axis aBaseY Speed=+300.0|Axis aStrafe Speed=-300.0",Alias=ForwardLeft)
Strafes Diagonally (forward left)
Aliases[22]=(Command="Axis aBaseY Speed=+300.0|Axis aStrafe Speed=+300.0",Alias=ForwardRight)
Strafes Diagonally (forward right)
Aliases[22]=(Command="ActivateAugmentation 6|onrelease ActivateAugmentation 6",Alias=ADS)
Just keeps on ADS as long as you hold down the key; useful in fights when low on bio or if you want to conserve bio.
Aliases[22]=(Command="Axis aBaseX Speed=-180.0|Axis aBaseY Speed=+050.0",Alias=CircleLeft)
Circles left
Aliases[22]=(Command="Axis aBaseX Speed=+180.0|Axis aBaseY Speed=+050.0",Alias=CircleRight)
Circles right
Aliases[22]=(Command="ActivateBelt 9 | ActivateAugmentation 1"
Pulls out a med and turns on Regen at the same time. This is useful when in combat, and you are getting your ass whooped.
Aliases[22]=(Command="ShowScores|onRelease ShowScores",Alias=Scores)
This shows the score as long as you keep the Scores button pressed.
Aliases[23]=(Command="stat net|stat fps",Alias=stats)
This shows your netstats(ping, packetloss etc.), and your current FPS.
How to play dx with out using the cd
In your DeusEx.INI file look for the [Engine.Engine] section and change the line CdPath= to read CdPath=..\
+More info on binds:
http://www.planetdeusex.com/dxmp/advanced/bindings.html
for the med bind ive just tried it and it only brings out the wep in invetorybelt 2.
{17}Ales
Re: Binds (repost)
Postby Cozmo » Fri Oct 20, 06 6:50 pm
For example:
About Aliasses
Binds
Circles left
Circles right
Did you hold it down? :wink:
Postby Kaiden » Fri Oct 20, 06 7:09 pm
Lol, mine only brings out the medkit and doesn't get the gun out again :) I expect you did it wrong ÅLËš :?
Postby Toxicelfman » Mon Feb 12, 07 6:35 pm
Umm i got problem the bind that uses medikit and pulls out wep on belt 2 all it does for me is uses med :? lol can u help me?
Toxicelfman
Postby ~ô¿ô~Nobody~ » Mon Feb 12, 07 9:39 pm
BINDS R HAX!
Postby Dae » Mon Feb 12, 07 10:10 pm
Toxicelfman wrote:all it does for me is uses med :?
Err and what you expect it to do?
Postby MainMan » Mon Feb 12, 07 10:38 pm
To pull out a weapon afterwards.
Here, you can use mine:
SingleQuote=Med | Onrelease ActivateBelt 1
Aliases[19]=(Command="ActivateBelt 9 | OnRelease ParseLeftClick",Alias=Med)
Hold it down, until med is drawn, and then let go - you will get the feel of it soon, and it will take you a split-second.
Postby Kaiden » Mon Feb 12, 07 10:38 pm
Heh, it's supposed to get the weapon in slot 2 out after using the medkit. It doesn't work with anyone as far as I know.
Postby MainMan » Mon Feb 12, 07 10:42 pm
[Å]Kaiden wrote:Heh, it's supposed to get the weapon in slot 2 out after using the medkit. It doesn't work with anyone as far as I know.
My one works fine.
Postby Kaiden » Mon Feb 12, 07 10:46 pm
Erm.. ok. Ok then, anyone that I have spoken to about the bind apart from you now.
Postby MainMan » Mon Feb 12, 07 10:49 pm
Look, basic info here: mouse binds are called faster than keyboard-binds, so something like this would have to be on the keyboard (as it needs time to complete the process). Something like a Zoom-shoot-switch to weapon 1 bind would need to be done quickly, so that would work best on a mouse button.
Also, if you put an OnRelease in an alias, it will be called before an OnRelease outside of an alias.
Hopefully you can see how my med-bind up there works.
Postby Kaiden » Mon Feb 12, 07 11:39 pm
Oh I see, so that bind would should be placed on the mouse. Hmm ok.
Postby MainMan » Mon Feb 12, 07 11:40 pm
No, the med bind that I posted should be on the keyboard - it needs time to get out the med, and use it.
Postby Toxicelfman » Wed Feb 14, 07 10:57 pm
Hey can anyone post me a setname bind plz ty :D :?:
Toxicelfman
Postby clyzm » Wed Feb 14, 07 10:58 pm
N=setname Player
Where N is the button you want to press.
Postby Dae » Wed Feb 14, 07 10:59 pm
Toxicelfman wrote:Hey can anyone post me a setname bind plz ty :D :?:
Is it supposed to be a joke?
Postby ~ô¿ô~Nobody~ » Thu Feb 15, 07 5:54 pm
B=setName I R TEH B00N
Postby Dae » Thu Feb 15, 07 6:26 pm
Well, there is also a "Name" command. You'd be able to save 3 bytes!
Postby Professor Layton » Thu Feb 15, 07 6:53 pm
Lol, I remember I had setname played binded to crouch once xD
Ctrl = Duck | Setname Player
1000 aliases, and you change em in fight :D
And yes, there are binds that automatically do the whole medding process.
Mine:
Aliases[23]=(Command="ActivateBelt 9|onrelease ParseLeftClick",Alias=MedKit)
NumPad0=ParseRightClick|ParseRightClick|MedKit|OnRelease ActivateBelt 1
(It's practically the same as mainman's, I just decided to put 2 parserightclicks in front, to speed up the time it takes to take out med, making it nearly instant medding at good ping and good fps.)
Although, mainman, where did you get that bind? Did you make it yourself or did you get it off someone? I made it with some other guy 2-3 years ago, and although I tried telling people to use this bind, they ended up leaving the bind behind, as they didnt put in the aliases part properly, or just didnt see the need of one.
Postby VodunLoas » Fri Feb 16, 07 1:52 am
One thing that really hurts binds... lag. Especially if you use 56k. :wink:
I can do the lockpick / multitool lag hax that lets you juggle them. Muhahahaha... erm.. yea. Not helpful for gameplay, but amusing.
Postby MainMan » Fri Feb 16, 07 12:39 pm
Clix­ wrote:Lol, I remember I had setname played binded to crouch once xD
Mine:
I thought of it myself, after I kept trying to make a decent medbind, this was the one that succeeded.
Postby Professor Layton » Fri Feb 16, 07 3:25 pm
Yeah, it might take some practice using the bind properly first, but after a while it's just very good. Also if you press the button very shortly you just reloadbug, which is handy for those who dont have a properly working scroll button xD
Postby Jeoh » Wed Feb 21, 07 3:05 am
I formatted it, DCSB created it. Good to see that people still find this useful :)
- Jeoh
Jeoh
Postby [FGS]ShadowRunner » Mon Mar 12, 07 4:10 pm
Sorry if this drives anyone insane... but:
When I hold down/tap/press this button, there is no medding, only activation of belt 2. I have no idea why...
Z=TurnLeft
Y=TeamTalk
X=
W=MoveForward
V=DualMapF9
U=FeignDeath
t=Talk
S=MoveBackward
R=ActivateBelt 9|onrelease ParseLeftClick|ActivateBelt 2
Q=Aliases[22]=(Command="Axis aBaseX Speed=+2900.0",Alias=TurnAround)
P=
o=
N=DualMapF8
M=Look
L=DualMapF11
k=KillerProfile
j=
i=DualMapF5
H=DualMapF7
G=DualMapF4
F=DualMapF6
E=ParseRightClick
D=StrafeRight
C=DualMapF3
B=BuySkills
A=StrafeLeft
Also I don't turn round when I press Q.
Everything else works. I checked both lines in my user to make sure they were the same, I copied and pasted the medbind and turnround bind straight from the Knowledge base... so I can't think what I have done wrong...
Obviously part of it works, the weapon in slot 2 gets activated, just no medkit activates or heals at all, just wep 2...
Mainman's looks pretty groovy:
Code:
So if I want "R" to heal me and activate a fully loaded wep, I would change my user to say this?
R=Med | Onrelease ActivateBelt 2 Aliases[19]=(Command="ActivateBelt 9 | OnRelease ParseLeftClick",Alias=Med)
oh wait a minute... Aliases goes in a different section?
*checks user.ini again *
[FGS]ShadowRunner
Postby Professor Layton » Mon Mar 12, 07 4:43 pm
The aliases part is somewhere close to the bottom of your user.ini.
Postby [FGS]ShadowRunner » Mon Mar 12, 07 5:43 pm
Thx, put in both Aliases sections, Still activating belt 2 without anything else... with mainman's too I get the same thing... still its better than nothing
I can see now why DX is so attractive to hackers and coders. Binds really do change your character and gameplay beyond the normal game and I can see why [A]Nobody said BINDS R HAX, but then it's really fascinating and rewarding to explore...
I'll try every medbind in this sticky and tell you which, if any, work.
[FGS]ShadowRunner
Postby Karkian » Tue Mar 13, 07 1:41 am
Can Someone Tell Me a Bind Where you press a button say 7 on the numpad and it automatically says Cya! Or something like is this right??:
7Num(Or watever they call it)=Say Cya Bro!
Does that Work Guys?? And I want it to automatically Press Enter :lol: 8)
Karkian
Postby Eçheløn » Tue Mar 13, 07 11:11 am
Yes that works garman :)
And it will automatically press enter :wink:
Eçheløn
