Binds (repost)
Postby Karkian » Wed Mar 14, 07 4:25 am
Kool! The Med Bind Doesnt work it just takes out my weapon on no.2 hmm Why?
Karkian
Postby Kaiden » Wed Mar 14, 07 5:46 pm
Hm, perhaps you added it wrong?
Open User.ini, Copy this code:
E=ActivateBelt 9|onrelease ParseLeftClick|ActivateBelt 2
This example uses E, so find E= in your User.ini and put that code there instead. Everything is repeated twice in your .ini; once for Dx SinglePlayer, once for MultiPlayer. So add it to the second E= too!
Full info on binds:
http://www.dxalpha.com/kb/improvements/what-are-binds
Postby clyzm » Wed Mar 14, 07 9:22 pm
Garman wrote:Kool! The Med Bind Doesnt work it just takes out my weapon on no.2 hmm Why?
Put the alias thing on both alias lists in your user.ini.
Postby Karkian » Thu Mar 15, 07 1:34 am
Clix­ wrote:Lol, I remember I had setname played binded to crouch once xD
Ctrl = Duck | Setname Player
1000 aliases, and you change em in fight :D
And yes, there are binds that automatically do the whole medding process.
Mine:
Aliases[23]=(Command="ActivateBelt 9|onrelease ParseLeftClick",Alias=MedKit)
NumPad0=ParseRightClick|ParseRightClick|MedKit|OnRelease ActivateBelt 1
(It's practically the same as mainman's, I just decided to put 2 parserightclicks in front, to speed up the time it takes to take out med, making it nearly instant medding at good ping and good fps.)
Although, mainman, where did you get that bind? Did you make it yourself or did you get it off someone? I made it with some other guy 2-3 years ago, and although I tried telling people to use this bind, they ended up leaving the bind behind, as they didnt put in the aliases part properly, or just didnt see the need of one.
This one is pretty good but i dont like it how you hold it :?
Karkian
Postby Professor Layton » Thu Mar 15, 07 3:55 pm
You're referring to the binded key?
I use arrows instead of WSAD, Pretty small keyboard, with numpad 0 directly near arrows. Due to the keyboard being so small, i dont need to use WSAD, as i got more than enough keys close to the arrows.
Postby Karkian » Fri Mar 16, 07 1:30 am
But there are two sections of alias one is for Multiplayer & one is For Singleplayer do you mean to put one in the singleplayer one?? Or do i put 2 in 1 Section in this case In theis case Multiplayer?? :?
Karkian
Postby Kaiden » Fri Mar 16, 07 1:45 am
Put the line in Both Singleplayer and Multiplayer sections..
Erg, 12:45, night.
Postby Karkian » Fri Mar 16, 07 1:55 am
Hey Would this work:
Caps Lock(Find What Its Called If Locked/unlocked=ParseLeftClick | Fire| Duck
Would this shoot when i click caps once so it auto shoot and it will auto crouch and uncrouch for some time?? :D
EDIT: Im Talking about the how you Just click E:
I got the One how you hold it to work:
I Just dont like the holding it Part :?
Karkian
Postby Karkian » Fri Mar 16, 07 2:05 am
Can someone give me a site to show tutorials on how to make binds??
-Garman-
Karkian
Postby The RZA » Fri Mar 16, 07 3:32 am
i dont think you would really need a tutorial. this topic basicly tells you how to create one. it is the first post, you should check it out Garman :)
The RZA
Postby Kaiden » Fri Mar 16, 07 7:14 pm
Our KB (KnowledgeBase) covers binds. Look here:
http://www.dxalpha.com/kb/improvements/binding
Postby Josh_Stargunner » Wed Apr 11, 07 9:15 pm
can somebody write one to equip a sniper rifle, scope it, fire it, and then return to another weapon?
Josh_Stargunner
Postby ~ô¿ô~Nobody~ » Wed Apr 11, 07 10:30 pm
This you could possibly use in SP.
In MP, due to replication, it's very unlikely, that this works.
Postby Professor Layton » Thu Apr 12, 07 1:07 pm
Definitely won't work in multiplayer, very slight chance it would work in SP.
Taking the weapon out does already take too long, so you'd have to start off with "ActivateBelt1/2/3|Onrelease" In multiplayer you cannot do scope and fire right after eachother, as the server somehow won't register the hit then, don't know if it's the case in SP.
Anyways, if it would even work, the bind would need to be stupidly long... Mainly due to the many "OnRelease" actions. Would it even work using several "Aliases" just for one bind? :S
Aliases[26]=(Command="ActivateBelt 2|Onrelease Togglescope",Alias=Snipe1)
Aliases[27]=(Command="Snipe1|Onrelease Parseleftclick",Alias=snipe2)
WhateverButton=Snipe2|Onrelease Activatebelt 1
Postby Josh_Stargunner » Thu Apr 12, 07 1:42 pm
okay, would it be possible to pull out the weapon and then scope it with nothing else done?
Josh_Stargunner
Postby Professor Layton » Thu Apr 12, 07 1:49 pm
Sure, Change X after Activatebelt, to the slot where you usually put your sniper rifle.
WhatEverButtonYouWant=Activatebelt X|Onrelease ToggleScope
You'll have to keep the button pressed down until the weapon is fully taken out, else it won't work.
Postby ~ô¿ô~Nobody~ » Thu Apr 12, 07 5:03 pm
Yes, the main problem with this is the animation time.
Animations are latent functions.
Postby Skinny Puppy » Fri Apr 13, 07 2:59 pm
Med bind doesn't work for me....
I set it to Numpad 1, and in DeusEx, i press it and it just does center view...
Heres my user.ini :)
User.ini
Goddard's User.ini
(12.94 KiB) Downloaded 1403 times
Skinny Puppy
Postby Professor Layton » Fri Apr 13, 07 3:31 pm
Try this.
User.ini
Ye m84734893789734894379, ur in m5893475938475489 clan lozl
(13 KiB) Downloaded 1290 times
Postby Skinny Puppy » Fri Apr 13, 07 4:00 pm
It's still going to center view...
Skinny Puppy
Postby Professor Layton » Fri Apr 13, 07 4:06 pm
Mmm.. lol. You have to put Num Lock on if you wanna use numpad of course. I see that End=Centerview, which is numpad1 button, if Num Lock is off. Put it on :P
Postby Psycho » Sat Apr 14, 07 11:59 pm
I use arrows. For some reason they don't work clix.
Postby Professor Layton » Sun Apr 15, 07 7:58 am
You mean the arrows on numpad don't work for you?
Postby ~M3GG4~ » Sun Apr 15, 07 8:34 am
Why cant i use binds if i am using Slimline?
Thanks
<center> Image </center>
<center>Deus Ex Soldiers
~M3GG4~
Postby Dae » Sun Apr 15, 07 9:13 am
{DXS}Destroyer wrote:Why cant i use binds if i am using Slimline?
Thanks
Edit user.ini then press File > Save As > defuser.ini, Replace existing file? - Yes.
Postby ~M3GG4~ » Sun Apr 15, 07 9:31 am
and will i then, be able to use binds?
~M3GG4~
Postby ~M3GG4~ » Sun Apr 15, 07 9:35 am
sorry to d-post, but my user ini is just called user, there is no .ini after it, should i fix that?
EDIT-- nope it hasnt worked.
~M3GG4~
Postby Dae » Sun Apr 15, 07 10:00 am
.ini is an extension of a file. Normally Windows doesn't display extensions of file types which it recognises. You may enable extensions in Folder options window (see it in menu in Windows Explorer).
Since you don't have extensions enabled I guess you should save user.ini as "defuser", not "defuser.ini".
Believe me, the solution I described works.
Postby ~M3GG4~ » Sun Apr 15, 07 1:11 pm
Hmm.. its still not working
I have done everything you said.?
~M3GG4~
Postby Professor Layton » Sun Apr 15, 07 1:48 pm
I believe you'll still have to save it as Defuser.ini, as the windows settings regarding whether extensions should be seen or not, doesn't affect Notepad.
You could alternatively just edit your defuser.ini, and save the changes there, as I don't see why you would have to edit your normal user.ini and then save it as defuser.ini
