Alcohol
Postby ~DJ~ » Thu Jun 25, 09 6:32 pm
Maate,
Where I wroted "ACPlayer" do it "AcidPlayer"
ACPlayer is nothing, I just forgot to write "AcidPlayer"
Postby Snakey » Thu Jun 25, 09 6:42 pm
Aye aye, I'll give it a go once I've finished tampering with these textures
Postby ~DJ~ » Thu Jun 25, 09 6:44 pm
Yay. :P
Well, If you notice anything like that when you go and host a server/lan and you see that you can't jump, nor does your name shows at the score board, reply here.
Postby Snakey » Thu Jun 25, 09 7:11 pm
Will do!
Postby Snakey » Thu Jun 25, 09 11:30 pm
No cigar, the "Class" entry in User.ini reverts back to DeusEx.JCDentonMale and once again the pickup fails to do anything.
This brings me back to my prior query regarding the aforementioned line of code
Postby ~DJ~ » Fri Jun 26, 09 5:07 am
Change it from DefUser.ini too?
:O
and check all again in User.ini press CTRL+F and find MTL or JCDentonmale see if you missed anything...
At DeusEx.ini, make sure your default-game type is your, and the default gameinfo is your mod's too.
And then whenever you test, goto LAN and then select the gametype as DeathMatch.
Oh and.. if the error still occurs, post your INI here.
or
First try adding your package in "ServerPackages="
Postby Snakey » Fri Jun 26, 09 11:01 am
I did all of that, 'cept I tested it in Multiplayer game and not LAN, could that be why?
Postby Professor Layton » Fri Jun 26, 09 11:53 am
Shouldn't make any difference.
Postby Snakey » Fri Jun 26, 09 12:07 pm
In that case it doesn't work.
Just makes it change back to DeusEx.JCDentonMale instead of the MTL Player class.
Postby ~DJ~ » Fri Jun 26, 09 12:35 pm
Upload User.ini and DeusEx.ini here, or if you think its personal, you can PM me. :o
Postby Raiiiny » Fri Oct 09, 09 12:01 pm
i've done something similar to this.
actually changed the drug effects script from deusexplayer.uc into a pickup. was working on a rain mod. worked, except even after i got the texture to show, i couldn't make it translucent... than said **** it, not worth it lol.
lost the script or i'd give it to you.
i have my old one under this topic, but i had to change one small detail to get it to work, don't rememebr what it was. i may mess with it an i'll post the working script if i get time.
Our greatest glory
is not in never falling, but in rising
every time we fall.
Raiiiny
Postby ~DJ~ » Fri Oct 09, 09 12:41 pm
OH MY GAWD
I just remembered, it was a big mistake.
Snakeh, if you're still working on it.
I had this big huge mistake.. At your gameinfo, just extend your AcidGameInfo (or it was ACGameInfo) anyway, extend it to GameInfo rather than DeusExGameInfo, because extending at DXGI will be ubber failure :$
Postby Snakey » Sat Oct 10, 09 4:50 pm
Not still working it at the moment, but I'll give your idea a whirl once I get my Deus Ex disc back and let you know if it works :)
Postby ~DJ~ » Sat Oct 10, 09 6:54 pm
Okies, good luck. :$
Users browsing this forum: No registered users and 39 guests
