fallen-into-a-box bug
Moderator: Ded
Postby galocza » Sun Oct 16, 11 5:22 pm
hi,
im not sure where to post this, so it will be here:
at mt weather after taking the elevator to the lower level (spiderbots area) i managed to fall into a box.
im not sure if it is an important enough bug to fix it (your average player doesnt jump around on boxes for fun) but here it is, a screenshot pack describing where it occurred:
http://www.sendspace.com/file/dicw0r
first three show the way to the problematic area (culprit is in the lower left corner of shot #3), the remaining eight are taken from the box at different angles.
this was the only bug i found at almost at the end of the mod, so kudos.
great mod btw, but i guess you already knew that 8).
cheers,
g
galocza
Postby galocza » Sun Oct 16, 11 7:47 pm
...and i managed to stuck again. mt weather, silo, 1st floor.
http://www.sendspace.com/file/pdui1z
galocza
Postby Ded » Sun Oct 16, 11 9:01 pm
galocza wrote:...and i managed to stuck again. mt weather, silo, 1st floor.
You can get out of there by activating your legs aug.
Follow 2027 at Twitter
Ded
Project 2027
Postby galocza » Sun Oct 16, 11 9:39 pm
thanks.
damn, i did that but i tried to jump and popped up and down 8).
never would have guessed that i just had to walk forward.
may i ask an another question?
im trying the omar ending. i killed vladimir, i opened the thanatos cave but when i try to walk to cyclops/cyclope the ai kills me remotely. i tried to run (legs aug again) to cyclops to start the dialogue sequence and get help removing the virus but i cannot seem to get there in time. i start the conversation but in the end still die. what am i missing?
galocza
Postby Ded » Sun Oct 16, 11 10:01 pm
Spend some bioenergy and you won't die.
Ded
Project 2027
Return to Project 2027
