Unreal Engine Direct3D 10 renderer
Postby Dae » Fri Aug 07, 09 6:18 pm
http://kentie.net/article/d3d10drv
(link found by m00nlighter from PlanetDeusEx.ru)
Could someone test it out please?
Postby Mr. Tastix » Fri Aug 07, 09 6:24 pm
What should we be looking for exactly?
Postby clyzm » Fri Aug 07, 09 6:58 pm
Highest available settings - LodBias -10, AA 16, AF 16, Alpha Masking etc.
Tested out with high poly weapons. Results: Clearer, sharper, way better than DirectX 8 and OpenGL and performs very smooth.
All the textures in the weapons are higher than 256 x 256 - and they seem to have no quality loss or resizings! This is apparent in the 3rd screenshot - the assault gun retains its original quality, while the other guns are much sharper. LOD loss doesn't seem to show (with other DirectX, a part of the gun would seem "broken off" if viewed from a distance)
Nice find.
EDIT: More screenshots. The first is a demonstration of the world textures and sharpness:
The second one is a comparison of OpenGL and DirectX 10. The comparison was made using an aim-down view of a weapon. The difference is very clear.
OpenGL:
DirectX 10:
Postby ~DJ~ » Sat Aug 08, 09 5:23 am
Nice. :D
But, I am having problems..
General protection fault EVERY single time I launch DX with that render..
Help? :/
Postby ~[ß]Lost~ » Sat Aug 08, 09 1:10 pm
~DJ~ wrote:Nice. :D
Help? :/
You running Vista or not?
Sike
clanb.deus-ex.net
~[ß]Lost~
Postby ~DJ~ » Sun Aug 09, 09 8:54 am
Vista, yeah, Vista.
Postby ~SaSQuAtCH~ » Mon Aug 10, 09 7:14 pm
Does your video card support DX10?
Postby Gishank » Mon Aug 10, 09 7:53 pm
Wow - That's quite impressive. I'm going to try and download and give it a go after giving it a virus scan. (I don't trust anything this good to be true D=)
Postby ~DJ~ » Mon Aug 10, 09 8:22 pm
~SaSQuAtCH~ wrote:Does your video card support DX10?
Postby {17}agentsmith » Wed Nov 04, 09 2:48 am
which of the 8 versions did you guys use?
I tried installing, DX went laggy and when I found the advanced options it said the renderer had failed to load and gave me no options. Any ideas why that is? it looks like its in the right place,
{17}agentsmith
Postby Aidan » Wed Nov 04, 09 4:16 am
Wow. Quite a difference =D
Postby DxPlayer » Sun Jan 10, 10 12:59 am
You have DirectX 10 installed, but that does not means your video card supports it. What is your video card?
{DxP}Alex
DxPlayer
Postby Wasted. » Sun Jan 10, 10 1:07 am
by reviving this you made me think klop was back.
prick ffs get my hopes up n that
Wasted.
Postby ~DJ~ » Sun Jan 10, 10 6:26 am
yeh, that problem was fixed 1 year ago.
Postby DxPlayer » Sun Jan 10, 10 2:03 pm
dickz I didnt notice the post date. :|
DxPlayer
Postby James » Thu Mar 18, 10 8:10 pm
I thought I posted in these threads.
Problem with this it isn't true graphical improvements, everything looks oiled up and in plastic wrap.
Postby MainMan » Thu Mar 18, 10 8:12 pm
That's not this one - that's the ENBSeries which makes everything look as if it has a huge condom stretched over it
Postby James » Thu Mar 18, 10 8:13 pm
Oh right. Yeah I hate that one. Is this the same one used in 2027 because I liked the look of that one.
Postby MainMan » Thu Mar 18, 10 8:14 pm
Nah, 2027 is ENB as well. Hopefully I'll be able to turn it off and play 0ld sk00l though
Postby AdamJensen » Wed Oct 17, 12 1:18 am
Clyzm. That weapons you showed in this screenshots, I really need them.
AdamJensen
Postby clyzm » Wed Oct 17, 12 1:49 am
For what?
Here it is, regardless: http://zalil.ru/33860855
There's additional weapons in there. To aim with the M4 just press the switch ammo key.
Postby AdamJensen » Wed Oct 17, 12 8:54 am
Well, just needed them for my playthrough of Deus Ex Singleplayer.
Thanks.
AdamJensen
Postby Marder » Wed Oct 17, 12 10:00 am
Clyzm Hi,
I suspect Mr Jensen might be our chief tester on the Hengsha project. The server will have weps from Clyzmsmod and some of the single packages you gave me previously. We've credited you of course and there's an opportunity to blog or be interviewed about your work, for the Eidos Montreal site.
http://www.moddb.com/mods/deus-ex-multi ... revolution
not sure if any screenies have weps yet, but I think the weps can be seen in the video.
Marder
Return to Deus Ex
