Unreal Editor 1112 fm Fix for Windows 7
Postby WCCC » Mon Apr 12, 10 5:15 am
:D well I just got a new computer for my birthday, and as to be expected it runs on windows 7. I instaleld DX on it and found out that normal DX runs 100% fine, but the Unreal Editor from the SDK 1112 fm is broken! it needs a file that no longer exists on windows 7 and probably not on vista either, so I wrote down the name of the component, expecting it to be one of many needed, and pulled it off of my mom's computer which runs on XP. I did this to find out that it's the ONLY component needed to be installed for Unreal Ed 1112fm to work on windows 7! And I figured I'd share this AWESOME fix with you guys, if you know anyone who has this problem on windows 7 try linking them this topic and rejoice in celebration! If it still doesn't work try running it in Window XP SP (service pack) 3 mode, because I do that in addition to using this .DLL, you simply place this single .DLL file in your C:\WINDOWS\system32 folder and boot up unreal ed 1112fm, and it should work!
UnrealEditor1112fmFix.zip
THANKS A SH*T-TON BILL GATES FOR CLUSER F*CKING OLDER SOFTWARE!
(687.79 KiB) Downloaded 1870 times
WCCC
Postby ~DJ~ » Mon Apr 12, 10 12:20 pm
so ur saying dat u dint knew about this?
tis is also on vista
Postby WCCC » Mon Apr 12, 10 12:57 pm
~DJ~ wrote:so ur saying dat u dint knew about this?
so the fix was already available you're saying? also so clarification and non locat grammars would be nice.
WCCC
Postby ~DJ~ » Mon Apr 12, 10 11:21 pm
http://dxalpha.com/forum/viewtopic.php? ... nreal++fix
That contained the DLLs also.. so liek.. since hotlinkfiles is down.. I guess I don't have it anymoar :$
Postby WCCC » Tue Apr 13, 10 11:24 pm
well that is rather handy stuff, however that is NOT what i am doing here. what you are doing is making it so you have the files needed to use unreal ed 1112 fm that would not be present had you not used the disc. what I am getting at, is that there are files necessary for operation of unreal ed 1112fm that you can't get even with the disc installation, they are files that are found naturally in all windows versions before windows 7, and possibly before vista.
We are doing two completely different types of maintenance here, but do you still have the names of the .DLL's needed for unreal ed that ARE found on the deus ex disc? would be rather halpful for a future of fully functional DX that never needs a cd again.
WCCC
Postby The RZA » Tue Oct 08, 13 2:31 pm
i just tried this. put the file into my system32 folder and i still get the same error. what else do i have to do?
The RZA
Postby The RZA » Tue Oct 08, 13 2:57 pm
ok i fixed it. put the dll file into my dx system folder. fixed the problem right up.
The RZA
Postby Mastakilla » Tue Oct 08, 13 3:37 pm
I didn't know you had an interest in unrealed, or is this a new development :P
Postby The RZA » Wed Oct 09, 13 7:40 am
i used to do it a long time ago before i quit playing. i edited a few weapons too lol. too bad i dont remember how to do any of it anymore.
The RZA
Postby ProtoType » Thu Jan 30, 14 2:02 am
go use unrealed 2.0 much more stable
ProtoType
