Alas, all hope is lost,
Postby bambi » Sat Feb 04, 12 3:23 am
I cannot hack Hejhuka's brilliant mod.
Yes, I'm typing about Hejhuka's hardcore mod. It is an amazing multiplayer mod, that provides the best bot ai, I've seen, great dual akimbo weapons, fast multiplayer action, and new gametypes, and I can't get it to work,
WHy? because he had to make it called DeusEx.u. So, anyone who tries to connect to server, will have a DeusEx.u version mismatch. So I tried to change all the package names to different ones and what not, but its' beyond my scope.
Poor, Nobody! This mod needs to be on servers, its awesome, please fix it.
bambi
Postby Hanover Fist » Sat Feb 04, 12 9:37 pm
I miss 5 Colormadness server
Hanover Fist
Postby ~ô¿ô~Nobody~ » Sun Feb 05, 12 12:28 am
The modification is embedded in DeusEx.u?
Pass me a copy of the required files and I see what I can do. :)
Postby bambi » Sun Feb 05, 12 3:36 am
thanks nobbody!
it's not embedded in DeusEx.u. IT is deusex.u! good luck,
http://sites.google.com/site/hejhujka/hejhujka%27sdeusexmods
bambi
Postby ~DJ~ » Sun Feb 05, 12 4:23 am
I thought of Hex editing and replacing all DeusEx to a suitable name.. but then I said 'meh.'
HOPE YOU WORK IT OUT NOBODY. ALSO HAVE TO DO WITH OTHER FILES I THINK AS WELL
Postby ~ô¿ô~Nobody~ » Mon Feb 06, 12 5:24 pm
So yeah.. I presumably ran against a tricky problem.
When renaming the mod and its internal dependency tree, I noticed the native binding of DeusEx.u to its DLL file..
I'll have to make a list of all native classes, followed by checking their code for differences to the original, trusting that there are no differences.. :-k
..A recompile might not be avoidable in the end..
Postby atrey65789 » Tue Feb 07, 12 1:37 am
Wait... So what are you trying to do exactly?
-A
atrey65789
Postby Mastakilla » Tue Feb 07, 12 1:46 am
The mod is normally just modified DeusEx.u, meaning if you host it player will get a version mismatch when they try to join unless they have the mod installed aswell, which would overwrite their original DeusEx.u and prevent them from joining any other server not using the mod, because they would get a version mismatch again. So they're trying to rename it so it can be hosted, without getting a version mismatch? Or something along those lines anyway
Postby atrey65789 » Tue Feb 07, 12 2:45 am
How bout tell your players that if you want to join, take the deusex.u file out of /system directory. lol
-A
atrey65789
Postby ~DJ~ » Tue Feb 07, 12 3:36 am
You can't run DX/DXMP if you take out DeusEx.u file out of System.
Postby ~ô¿ô~Nobody~ » Tue Feb 07, 12 11:42 am
atrey65789 wrote:Wait... So what are you trying to do exactly?
I'm trying to make the DX Hardcore mod independent from the DeusEx common files.
Kalman11 wrote:Renaming this package will work I think (I simply renamed it to DeusExHardcore.u, and it works in UnrealEd, without any DeusExHardcore.dll
It might work in the editor, but I think it will crash when loading it with DeusEx.. UNLESS.. the dependency to the dll is NOT acquired by the filename but by an internal reference.. this needs to be figured out.
Postby Kalman11 » Tue Feb 07, 12 11:56 am
Idk, I'll try it afternoon
My UED loads DeusEx.u and DeusExHardcore.u too
I read about dlls, and it said the dll's name must mtach exactly to the package name, or it won't find it
Kalman11
Postby ~ô¿ô~Nobody~ » Tue Feb 07, 12 12:00 pm
Kalman11 wrote:I read about dlls, and it said the dll's name must mtach exactly to the package name, or it won't find it
I fear this too.. it worth to proof it though..
Postby Kalman11 » Tue Feb 07, 12 12:14 pm
I think this article was about dlls, maybe I read that here (I can't check it now, I'm at school and it's blocked)
Kalman11
Postby James » Tue Feb 07, 12 12:14 pm
I suggest calling the final version of this lil project something like ArenaHardcore or HardcoreArena.
Postby ~ô¿ô~Nobody~ » Tue Feb 07, 12 12:23 pm
I'm fine with that but the package name itself needs to have the same length as DeusEx, otherwise changing the internal dependencies of the other packages will be tricky.
That's why I chose DXHCMP... or if the Arena is mandatory in your eyes.. HCARMP or DXHCAR or DXARHC :?
Postby Kalman11 » Tue Feb 07, 12 12:24 pm
OMG, so long names lol
Simply DXHC
Kalman11
Postby ~ô¿ô~Nobody~ » Tue Feb 07, 12 12:27 pm
length(DXHC) != length(DeusEx)   ! ! !
Postby atrey65789 » Tue Feb 07, 12 12:53 pm
There ya go... so we've come to a conclusion with the name! lol
-A
atrey65789
Postby James » Tue Feb 07, 12 12:57 pm
DXHC for map names yeah, but what about the name of the actual mod? :O
Mind, DXHC is sorta different.
Postby atrey65789 » Tue Feb 07, 12 12:58 pm
Is there anyway we can contact the ACTUAL mod creator and ask him?
-A
atrey65789
Postby bambi » Tue Feb 07, 12 11:28 pm
does it work in multioplayer now?
bambi
Postby atrey65789 » Wed Feb 08, 12 12:31 am
I dont think so... Still tryin to find a way for it to work.
-A
atrey65789
Postby atrey65789 » Wed Feb 08, 12 1:03 am
Wait... I got the stuff loaded up in Unrealed... now Is there anyway to change the multiplayer settings to where when you go on the server, everything ( UI, etc.) will be ran off of that Deusex.u file?
-A
atrey65789
Postby ~DJ~ » Wed Feb 08, 12 3:11 am
~ô¿ô~Nobody~ wrote:I'm fine with that but the package name itself needs to have the same length as DeusEx, otherwise changing the internal dependencies of the other packages will be tricky.
DeusEx;
ArenaX
GUISE?
Postby Kalman11 » Wed Feb 08, 12 6:09 am
Ok, so I tested it ingame and it gives me an error "Can't bind to native class DeusExHardcore.DeusExPlayer", then I tried to rename DeusEx.dll to DeusExHardcore.dll, but it says "Assertion failed: !GAutoRegister [File:D:\prj\Clean\Core\Src\UnObj.cpp] [Line:1322]"
Kalman11
Postby James » Wed Feb 08, 12 9:29 am
DJ, Arena... X? Wow, Arena Xtreme / Ten / Ex is such an un-fitful name.
The name of the mod itself should be a nod to the originals but different so you can tell the 3 apart. Remember to keep it simple DXHCARXTRM10 proposers.
Postby atrey65789 » Wed Feb 08, 12 1:00 pm
Try naming INI and INT file that name.
-A
atrey65789
Postby Kalman11 » Wed Feb 08, 12 3:10 pm
Not the INI or the INT files are the problem
Log: Log file open, 02/08/12 15:00:26
Init: Detected: Microsoft Windows NT 6.1 (Build: 7601)
Init: Version: 1100
Init: Command line:
Init: Base directory: D:\Játékok\DeusEx\System\
Init: Character set: Unicode
Log: Bound to Engine.dll
Log: Bound to Core.dll
Log: Bound to Window.dll
Init: Computer: JOHNNYPC
Init: User: Johnny
Init: Memory total: Phys=2069812K Pagef=4194303K Virt=2097024K
Init: CPU Speed=1995.074581 MHz
Init: CPU Page size=4096, Processors=2
Init: CPU Detected: PentiumPro-class processor (GenuineIntel)
Localization: No localization: DXHC.General.Start (int)
Log: Bound to DeusExHardcore.dll
Log: Bound to DeusEx.dll
Log: Bound to Extension.dll
Log: Bound to ConSys.dll
Critical: appError called:
Critical: Assertion failed: !GAutoRegister [File:D:\prj\Clean\Core\Src\UnObj.cpp] [Line: 1322]
Critical: Windows GetLastError: A mvelet sikeresen befejezdött. (0)
Critical: UObject::ProcessRegistrants
Critical: UPackage::BindPackage
Critical: UPackage::UPackage
Critical: UObject::CreatePackage
Critical: UObject::ResolveName
Critical: UObject::StaticLoadObject
Critical: (Core.Class None.DeusExHardcore.DeusExGameEngine NULL)
Critical: UObject::StaticLoadClass
Critical: InitEngine
Exit: Exiting.
Uninitialized: Log file closed, 02/08/12 15:00:35
This is my log file
[URL]
Protocol=deusex
ProtocolDescription=Deus Ex Protocol
Name=Player
Map=Index.dx
LocalMap=DX.dx
Host=
Portal=
MapExt=dx
SaveExt=dxs
Port=7790
Class=DeusExHardcore.JCDentonMale
[FirstRun]
FirstRun=1100
[Engine.Engine]
GameRenderDevice=D3DDrv.D3DRenderDevice
AudioDevice=Galaxy.GalaxyAudioSubsystem
NetworkDevice=IpDrv.TcpNetDriver
DemoRecordingDevice=Engine.DemoRecDriver
Console=Engine.Console
Language=int
GameEngine=DeusExHardcore.DeusExGameEngine
EditorEngine=Editor.EditorEngine
WindowedRenderDevice=SoftDrv.SoftwareRenderDevice
RenderDevice=GlideDrv.GlideRenderDevice
DefaultGame=DeusExHardcore.DeusExGameInfo
DefaultServerGame=DeusExHardcore.DeathMatchGame
ViewportManager=WinDrv.WindowsClient
Render=Render.Render
Input=Extension.InputExt
Canvas=Engine.Canvas
Root=DeusExHardcore.DeusExRootWindow
CdPath=
[Core.System]
PurgeCacheDays=30
SavePath=..\Hardcore\Save
CachePath=..\Hardcore\Cache
CacheExt=.uxx
Paths=..\Hardcore\System\*.u
Paths=..\System\*.u
Paths=..\Hardcore\Maps\*.dx
Paths=..\Maps\*.dx
Paths=..\Textures\*.utx
Paths=..\Sounds\*.uax
Paths=..\Hardcore\Music\*.umx
Paths=..\Music\*.umx
Suppress=DevLoad
Suppress=DevSave
Suppress=DevNetTraffic
Suppress=DevGarbage
Suppress=DevKill
Suppress=DevReplace
Suppress=DevSound
Suppress=DevCompile
Suppress=DevBind
Suppress=DevBsp
[DeusExHardcore.DeusExGameEngine]
CacheSizeMegs=4
UseSound=True
ServerActors=IpDrv.UdpBeacon
ServerActors=IpServer.UdpServerQuery
ServerActors=IpServer.UdpServerUplink MasterServerAddress=master0.gamespy.com MasterServerPort=27900
ServerActors=IpServer.UdpServerUplink MasterServerAddress=master.epicgames.com MasterServerPort=27900
ServerActors=IpServer.UdpServerUplink MasterServerAddress=master.fragaholic.com MasterServerPort=27900
[WinDrv.WindowsClient]
WindowedViewportX=640
WindowedViewportY=480
WindowedColorBits=16
FullscreenViewportX=640
FullscreenViewportY=480
FullscreenColorBits=16
Brightness=0.600000
MipFactor=1.000000
UseDirectDraw=True
UseJoystick=False
CaptureMouse=True
StartupFullscreen=True
CurvedSurfaces=False
ScreenFlashes=True
NoLighting=False
SlowVideoBuffering=False
DeadZoneXYZ=True
DeadZoneRUV=False
InvertVertical=False
ScaleXYZ=1000.000000
ScaleRUV=2000.000000
SkinDetail=High
TextureDetail=High
Decals=True
MinDesiredFrameRate=35.0
[Engine.Player]
ConfiguredInternetSpeed=2600
ConfiguredLanSpeed=20000
[Galaxy.GalaxyAudioSubsystem]
UseDirectSound=True
UseFilter=True
UseSurround=False
UseStereo=True
UseCDMusic=False
UseDigitalMusic=True
UseSpatial=False
UseReverb=True
Use3dHardware=False
LowSoundQuality=False
ReverseStereo=False
Latency=40
OutputRate=44100Hz
EffectsChannels=16
DopplerSpeed=6500.000000
MusicVolume=153
SoundVolume=204
SpeechVolume=255
AmbientFactor=0.700000
[IpDrv.TcpNetDriver]
AllowDownloads=True
ConnectionTimeout=15.0
InitialConnectTimeout=500.0
AckTimeout=1.0
KeepAliveTime=1.0
MaxClientRate=20000
SimLatency=0
RelevantTimeout=5.0
SpawnPrioritySeconds=1.0
ServerTravelPause=4.0
NetServerMaxTickRate=20
LanServerMaxTickRate=35
StaticUpdateRate=12
DynamicUpdateRate=40
[IpDrv.TcpipConnection]
SimPacketLoss=0
SimLatency=0
[IpServer.UdpServerQuery]
GameName=deusex
[IpDrv.UdpBeacon]
DoBeacon=True
BeaconTime=0.50
BeaconTimeout=5.0
BeaconPort=7776
BeaconProduct=DeusEx
[SoftDrv.SoftwareRenderDevice]
Translucency=True
VolumetricLighting=True
ShinySurfaces=False
Coronas=False
HighDetailActors=True
HighResTextureSmooth=True
LowResTextureSmooth=False
FastTranslucency=True
[GlideDrv.GlideRenderDevice]
Translucency=True
ShinySurfaces=True
Coronas=True
DetailBias=-1.500000
RefreshRate=100Hz
DetailTextures=True
FastUglyRefresh=False
ScreenSmoothing=True
Resolution=Default
[MetalDrv.MetalRenderDevice]
Translucency=True
ShinySurfaces=True
Coronas=True
DetailTextures=True
[OpenGLDrv.OpenGLRenderDevice]
Translucency=True
ShinySurfaces=True
Coronas=True
DetailTextures=True
UseTNT=1
MinDepthBits=16
MaxLogUOverV=8
MaxLogVOverU=8
UseMultiTexture=1
UsePalette=1
UseAlphaPalette=0
ShareLists=0
AlwaysMipmap=0
DoPrecache=0
UseTrilinear=False
MaxAnisotropy=0
SupportsLazyTextures=0
[D3DDrv.D3DRenderDevice]
Translucency=True
ShinySurfaces=True
Coronas=True
UseMipmapping=True
UseTrilinear=False
UseMultitexture=True
UsePageFlipping=True
UsePalettes=True
UseFullscreen=True
UseGammaCorrection=True
DetailTextures=True
Use3dfx=False
UseTripleBuffering=True
UsePrecache=False
Use32BitTextures=False
DescFlags=1
dwDeviceId=10674
dwVendorId=32902
UseVertexFog=False
UseAGPTextures=False
UseVideoMemoryVB=False
UseVSync=False
Description=Intel(R) Q35 Express Chipset Family
[SglDrv.SglRenderDevice]
Translucency=True
VolumetricLighting=False
ShinySurfaces=False
Coronas=True
HighDetailActors=False
ColorDepth=16
DetailTextures=False
TextureDetailBias=Near
VertexLighting=False
[Editor.EditorEngine]
UseSound=True
CacheSizeMegs=6
GridEnabled=True
SnapVertices=True
SnapDistance=10.000000
GridSize=(X=16.000000,Y=16.000000,Z=16.000000)
RotGridEnabled=True
RotGridSize=(Pitch=1024,Yaw=1024,Roll=1024)
GameCommandLine=-log
FovAngleDegrees=90.000000
GodMode=True
AutoSave=False
AutoSaveTimeMinutes=5
AutoSaveIndex=6
C_WorldBox=(R=0,G=0,B=107,A=0)
C_GroundPlane=(R=0,G=0,B=63,A=0)
C_GroundHighlight=(R=0,G=0,B=127,A=0)
C_BrushWire=(R=255,G=63,B=63,A=0)
C_Pivot=(R=0,G=255,B=0,A=0)
C_Select=(R=0,G=0,B=127,A=0)
C_AddWire=(R=127,G=127,B=255,A=0)
C_SubtractWire=(R=255,G=192,B=63,A=0)
C_GreyWire=(R=163,G=163,B=163,A=0)
C_Invalid=(R=163,G=163,B=163,A=0)
C_ActorWire=(R=127,G=63,B=0,A=0)
C_ActorHiWire=(R=255,G=127,B=0,A=0)
C_White=(R=255,G=255,B=255,A=0)
C_SemiSolidWire=(R=127,G=255,B=0,A=0)
C_NonSolidWire=(R=63,G=192,B=32,A=0)
C_WireGridAxis=(R=119,G=119,B=119,A=0)
C_ActorArrow=(R=163,G=0,B=0,A=0)
C_ScaleBox=(R=151,G=67,B=11,A=0)
C_ScaleBoxHi=(R=223,G=149,B=157,A=0)
C_Mover=(R=255,G=0,B=255,A=0)
C_OrthoBackground=(R=163,G=163,B=163,A=0)
C_Current=(R=0,G=0,B=0,A=0)
C_BrushVertex=(R=0,G=0,B=0,A=0)
C_BrushSnap=(R=0,G=0,B=0,A=0)
C_Black=(R=0,G=0,B=0,A=0)
C_Mask=(R=0,G=0,B=0,A=0)
C_WireBackground=(R=0,G=0,B=0,A=0)
C_ZoneWire=(R=0,G=0,B=0,A=0)
EditPackages=Core
EditPackages=Engine
EditPackages=Editor
EditPackages=Fire
EditPackages=IpDrv
EditPackages=Extension
EditPackages=DeusExUI
EditPackages=ConSys
EditPackages=DeusExConversations
EditPackages=DeusExSounds
EditPackages=DeusExItems
EditPackages=DeusExDeco
EditPackages=DeusExCharacters
EditPackages=DeusExText
EditPackages=DeusExHardcore
EditPackages=IpServer
[DeusExHardcore.DeusExGameInfo]
bNoMonsters=False
bHumansOnly=False
bCoopWeaponMode=False
bClassicDeathmessages=False
[Engine.GameInfo]
bLowGore=False
[Engine.DemoRecDriver]
DemoSpectatorClass=UnrealShare.UnrealSpectator
MaxClientRate=25000
AckTimeout=1.0
KeepAliveTime=1.0
SimLatency=0
RelevantTimeout=5.0
NetServerMaxTickRate=60
LanServerMaxTickRate=60
[DeusExHardcore.MenuScreenJoinGame]
[Engine.GameReplicationInfo]
ServerName=
ShortName=
[IpServer.UdpBeacon]
[WindowPositions]
GameLog=(X=200,Y=200,XL=512,YL=256)
ConfigPageSafeMode=(X=5,Y=96,XL=516,YL=280)
WizardDialog=(X=375,Y=272,XL=530,YL=439)
And this is my DXHC.ini
This is the problem:
DeusExHardcore hasn't got DeusExGameEngine, but if I set the GameEngine to DeusEx.DeusExGameEngine, I get this error: Autoregistered Class DeusEx.ParticleIterator already exists
It will be hard to make it work IMO, but maybe Nobody can make it :) (he can do everything)[/code]
Kalman11
Postby ~DJ~ » Wed Feb 08, 12 7:35 pm
James wrote:DJ, Arena... X? Wow, Arena Xtreme / Ten / [bold]Ex[/bold]
FINE.. :cry: was proposing 'Ex' though!
..Kalman, DXHC doesn't fit DeusEx's characters. So there's no point to discuss that D:
Users browsing this forum: No registered users and 8 guests
