DXAG progress!
DXAG progress!
Postby clyzm » Tue Jan 24, 06 1:05 am
Hey Ben, I textured teh shotty, whatcha think:
Edit:
I made the M79 as an extra as well :0
Postby MrBlackDX » Tue Jan 24, 06 3:08 pm
nice!
Anyone know if its possible to code a gun to have primary ammo as buckshot (shotgun rounds) and then secondary ammo as 20mm?
The M79 will have a clip of 1 with total rounds 20 (buckshot - twice as powerful as the sawn-off shotgun hopefully), and when you pick up 20mm (although the 20mm ammo will eventually be renamed '40mm') you can load that in for say every 4 rounds of 20 mm, will go 1 clip with 3 spare
The double barrel shotgun will have a 2 round clip of 12 gauge buckshot, and spare ammo of say 10 clips (20 rounds)
The double barrel will be 2 consecutive semi-automatic rounds of shot, instead of the old doom/quake style of firing both rounds at the same time, which is physically impossible
Postby Gishank » Tue Jan 24, 06 5:48 pm
Ok i have had a crack at em and they are kool meshes BTW.
You know me on msn so i will tell you it then.
Postby Wasted » Tue Jan 24, 06 7:06 pm
Well an assault shotgun bullet fire wouldnt be bad, is it possible to make a sound?
p.s. klop whats wiht the re after ur name?
Postby Gishank » Tue Jan 24, 06 7:09 pm
Cos they need to get rid of that fake acount before i change back or i will go down with it.
Postby clyzm » Tue Jan 24, 06 10:49 pm
MrBlack wrote:nice!
Erm ... correct me if I'm wrong, but isn't the M79 a grenade launcher only?
Postby MainMan » Tue Jan 24, 06 10:53 pm
personally, i think this would go well on my new DXAG_Landerneau, since that is set in a WWII village in france.
Postby Spiderbot01 » Tue Jan 24, 06 11:06 pm
Im pretty sure the M79 wasnt used during WW2...
Postby clyzm » Tue Jan 24, 06 11:09 pm
~MainMan~ wrote:personally, i think this would go well on my new DXAG_Landerneau, since that is set in a WWII village in france.
It would yeah, and an MP40.
I still need to work on the textures a bit more, and I hafta work on animations as well. ;p
Postby MainMan » Tue Jan 24, 06 11:10 pm
[Z]_Spiderbot01_[Z] wrote:Im pretty sure the M79 wasnt used during WW2...
No, it wasn't, but I was referring to the idea in general, not specific guns.
Postby MrBlackDX » Wed Jan 25, 06 12:15 am
cataclyzm wrote:Erm ... correct me if I'm wrong, but isn't the M79 a grenade launcher only?
Ive read some stuff that because during Vietnam (where the M79 was predominant) instead of carrying a sidearm, soldiers questioned the army about a 40mm buckshot round, which then came into circulation, to provide close combat firepower and launched grenade firepower
Postby Gishank » Wed Jan 25, 06 5:40 pm
Hey cata, when you have finished the meshes and are in dx format send em to me please so i can give em to the weapons.
The M79 is still a bit Fed up.
Postby Mastakilla » Wed Jan 25, 06 8:16 pm
Yeah give them to the KlopMeister, he knows what to do with them :]
Claim them as his own =P
Nice meshes btw.
Postby Gishank » Thu Jan 26, 06 4:11 pm
Bitch! I wouldn't do that i am Doing it out of the goodness of my heart for DXAG.
Postby clyzm » Thu Jan 26, 06 10:35 pm
<~>K}Ã?Ã?<~> wrote:b$#!@! I wouldn't do that i am Doing it out of the goodness of my heart for DXAG.
I think it's safer you sent me the code ...
Postby MainMan » Thu Jan 26, 06 10:48 pm
MrBlack has sent me the code for the double barrel shotgun, I have made it so you can select single firing (in clips of 2), or shoot both barrels at once, but with a longer time to reload.
Postby Cozmo » Fri Jan 27, 06 3:28 pm
is this "altfire" command or is it just different ammotype?
just being nosey... =]
Postby MrBlackDX » Fri Jan 27, 06 3:38 pm
~Cozmo~ wrote:is this "altfire" command or is it just different ammotype?
probably different ammo type
Postby ~ô¿ô~Nobody~ » Fri Jan 27, 06 3:41 pm
actually altfire exists in the base code for DX too it's just never used
Postby MrBlackDX » Fri Jan 27, 06 3:44 pm
~[A]Nobody~ wrote:actually altfire exists in the base code for DX too it's just never used
except on the mod, altfire
im willing to use altfire since i know the bind
Postby Gishank » Fri Jan 27, 06 3:52 pm
Then what was the point in me making the gun if it was going to be re-edited ??
WOW WHOA HOLY LIZARDS OF MACRON!
Postby bambi » Fri Jan 27, 06 4:04 pm
WOW THIS SOUNDS AWESOME!!! THESE LOOK LIKE REAL GUNS AND NOT WEIRD MACHINE GUNS THAT WON'T KILLL YOU EVEN IF YOU EMPTY A WHOLE CLIP IN THEIR FACE. YEAAA!!! WILL THERE BE FLASHBANGS TOO? :lol: :shock: :lol: :shock: :lol: :shock: :lol: :shock: :lol: :arrow: :!:
bambi
Postby MainMan » Fri Jan 27, 06 5:32 pm
neither, you're both wrong. It overrides the change ammo key, so when i press it, it sets bDouble to either true or false. When you fire, it checks whether you are in double mode or not, and fires accordingly.
Postby Gishank » Fri Jan 27, 06 5:42 pm
Nice idea mainman. 8)
Postby Alex » Fri Jan 27, 06 5:45 pm
MainMan, look in the buckshot ammo type (I thought), it shows how you can set what kind of shells it should drop, and if possible, make it drop 2 shells when fired in bDouble mode.
Postby Allan » Fri Jan 27, 06 5:53 pm
*This is also true for ammo762mm, ammo10mm, and prehaps ammoSabot.* Liking the ideas guys :D (Me wishes that i could make L33T meshes in Milkshape...)
Postby Gishank » Fri Jan 27, 06 6:05 pm
Allan your ammo's are the same as the original dx ones, well all the ones i have looked at are.
Postby Wasted » Fri Jan 27, 06 9:49 pm
The buckshot idea is good, I think that from what Ive seen of the map mainman made (when i tested it) It will tie in quite well, I cant wait till its put up.
Postby Gishank » Sat Jan 28, 06 9:59 am
BTW Mr.Black i pmed you the PS20 DXAG version to you....
Postby Wasted » Sat Jan 28, 06 10:56 am
Sounbds cool, but if ur gonna get no room to pick up weps, and u cant drop them, why use a single fire?
