[TOOL] DX Telnet Admin
Postby ~ô¿ô~Nobody~ » Tue Aug 01, 06 11:36 pm
Ok.. FINALLY
This is the first release of the Telnet mod for DX, made by my humble self
:lol:
It was already running for several months on my SG server, but now i publish it for the public use on any DX server.
The readme should explain everything. If there are question left, just ask.
DXTelnetAdmin.zip
Version 205
(34.25 KiB) Downloaded 2065 times
Postby KillerZ » Wed Aug 02, 06 12:06 am
Thank you!
( I have a small hunch that I know you thourgh MSN )
KillerZ
Postby Gishank » Wed Aug 02, 06 9:35 am
:D It's finnaly released :D Great work nobody :D
Postby Jon » Wed Aug 02, 06 11:18 am
unless you got up at 7:00 in the morning to set up that client along with your server, i suggest that you actually test it before congratulating him - it would be much more worthwhile
Postby Gishank » Wed Aug 02, 06 11:52 am
But i did test it before i posted that ;) The only problem is that if you do the testcolors command it stays as a blue background and you can't change it back, well i didn't find a way.
Postby ~ô¿ô~Nobody~ » Wed Aug 02, 06 12:32 pm
Well, i tested it for some months now.. while always adding new stuff. (At the end the MD5 password encryption)
But feel free to report any existing bugs.
Postby Kaiden » Wed Aug 02, 06 3:37 pm
Ah good, I thought it would be released eventually.
Telnets a useful mod. Especially if you just want to give you low-level power to people rather than giving them full Server-Admin.
Re: [RELEASE] DX Telnet Admin
Postby Alistair » Thu Aug 03, 06 5:47 pm
~[A]Noodles~ wrote:Ok.. FINALLY
:lol:
Shit, Nice one! I'll work on a Linux built
Postby ~ô¿ô~Nobody~ » Fri Aug 18, 06 8:27 pm
linux build?
aren't unreal packages platform independent?
@all: any suggestions/problems?
Postby DarkKnight » Fri Aug 18, 06 9:22 pm
~[A]Noodles~ wrote:linux build?
Your mod will work so long as it only calls UT methods.
Anything that uses no-standard methods, will need to be re-released under Linux. :)
(This is if you used something like C++, but UCScript is totally platform independant.)
Postby ~ô¿ô~Nobody~ » Fri Aug 18, 06 9:46 pm
Well.. that's one of the big advantages to the DXServerAdmin mod
It's UC based only. No additional libraries. It uses the TCPlink class of the IPDrv package, which should be part of the linux version as well.
Edit: er.. oh noes..
there doesn't exist a linux version of DX.. so.. it wouldn't matter anyways.. would it?
Postby DarkKnight » Fri Aug 18, 06 10:38 pm
~[A]Noodles~ wrote:Well.. that's one of the big advantages to the DXServerAdmin mod
If it's all UT based - not in the least. :)
Postby Imperial » Sun Oct 15, 06 5:58 pm
Network error: Connection refused.
That's the error message I get when i try to use telenet. I have yet to setup an account.
Postby ~ô¿ô~Nobody~ » Sun Oct 15, 06 6:03 pm
if all settings are default, you need to connect to your server over the IP
with protocol Telnet and port 50023
If you get a network error, it cannot find a telnet server at the specified IP on the specified port.
A cause can be that you forgot to add the telnet-listen actor to ServerActors
Postby {17}Ales » Sun Oct 15, 06 6:58 pm
~[A]Nobody~ wrote:if all settings are default, you need to connect to your server over the IP
Yea and ya gotta open those ports on your router for others to visit. 8)
{17}Ales
Postby Imperial » Fri Oct 20, 06 6:04 pm
Im using putty to do it and I have connected over my ip.
I also have that serveractor.
Postby Imperial » Sun Nov 12, 06 3:20 pm
I have done all this with no progress, and it is apprearing blank for me and after 20 seconds it times out. I haven't a router either.
Postby Kaiden » Sun Nov 12, 06 6:22 pm
Er.. Make sure your connecting to the Right IP :)
Once your hosting a server, then connect to Telnet. Also go to run>>type Cmd to get the command promt and type ipconfig then connect to what ever your IP address**.** is there.
Postby Imperial » Sun Nov 12, 06 8:21 pm
ah! Got it! At last! Thanks Kaid :D
Postby ~ô¿ô~Nobody~ » Sun Nov 12, 06 8:27 pm
You really tried to connect with your external IP? :shock:
hmm, sorry, there i couldn't help you.. i'd never get the idea to connect to my local server over my external IP. :oops:
Postby Imperial » Sun Nov 12, 06 9:08 pm
I hadn't a clue :oops:
Postby -=BrotherBear=- » Thu Aug 30, 07 1:20 am
thanks Kaiden.. i was trying to use my external ip o.o as u can tell it didnt work so well >_>
but not is awesome..
now i mgoing to bed...
*sleepy*
-=BrotherBear=-
Postby Kaiden » Thu Aug 30, 07 1:24 am
Lol, I posted that kind of a while ago, but no problem!
Return to alpha laboratories
