Fix for UED2 hack for DeusEx
Postby Andrievskaya Veronika » Wed Nov 22, 06 8:30 am
DeusEx Meshes for UED2 hack for DX
Image Image Image
I have converted all DeusEx packages with meshes into Unreal format.
Using these converted packages you can view DeusEx meshes in UED2 hack For DX
like in UED1 from official DeusEx SDK. You can even view animations!
Also you can test/play your within UED2--this will work. And you can make
UED2 open maps with .dx extension instead .unr; just use patch
"Ued2_Unr_dx.EXE"
You will able to place weapons, decorations, etc. without leaving UED2.
Installation:
unzip archive to your UED2 folder (you should replace all files), then run UED2 and enjoy :)
NOTE: You should define paths in UED1, not in UED2. But you can place PathNodes and other navigation points in UED2 :)
NOTE2: If PlayLevel will not work, please tell me about this.
DOWNLOAD FROM DXALPHA.COM:
http://download.dxalpha.co.uk/DX1/editi ... for-DX.zip
edit:
UPDATE
To anyone who uses my fix for UED2 please download this little update:
http://download.dxalpha.co.uk/DX1/editi ... DX-upd.zip
Decorations HKBirdCage and HKMarketLight was not displayed in editor. Fixed.
How to install: unpack archive to your UED2 folder; replace existing files.
edit: now you can download update from DxAlpha.com
Last edited by Andrievskaya Veronika on Thu Jan 18, 07 9:09 am, edited 2 times in total.
Postby VodunLoas » Wed Nov 22, 06 10:22 am
Nice job! I'm sure it took a good bit of time and patience.
Postby Dae » Wed Nov 22, 06 4:55 pm
Dae recommends this thing.
Now UnrealEd2 has almost no disadvantages to SDK.
Sticky'd.
Postby Bob » Wed Nov 22, 06 5:36 pm
If this thing had a physical prescence.... I'd have sex with it.
Thanks.
Postby Dae » Wed Nov 22, 06 5:56 pm
All the Russians on other forum have already mentally raped it.
Postby ~ô¿ô~Nobody~ » Wed Nov 22, 06 7:52 pm
omg..
even Nobody could consider using it. :shock:
Postby Corruption » Sun Dec 03, 06 5:51 am
I'm using WINRAR to download it.. but i keep getting an error that says Unexpected end of Archive when i try to open it.. anybody know what's causing this?
* Teach a man to fish, you'll feed him for a day. Kill a man with a fish, you'll feed the fish for a month*
Corruption
Postby Dae » Sun Dec 03, 06 9:39 am
ShadowHunter wrote:I'm using WINRAR to download it.. but i keep getting an error that says Unexpected end of Archive when i try to open it.. anybody know what's causing this?
Try re-downloading.
Postby Andrievskaya Veronika » Mon Jan 15, 07 2:26 pm
http://veronika.3dn.ru/Fixed/_fix.7z
Edit: Added to first post
Last edited by Andrievskaya Veronika on Mon Jan 15, 07 3:20 pm, edited 1 time in total.
Postby MainMan » Mon Jan 15, 07 3:13 pm
Заодно запостируй это в первом сообщение, а то некоторые всю тему не читают.
Postby TheSheep » Tue Jan 16, 07 11:58 am
What did you use to convert them - some sort of reverse unr2de? It would be awesome to share that as well :D
TheSheep
Postby MainMan » Tue Jan 16, 07 12:19 pm
Hexy's deusexextractor I think.
Postby Andrievskaya Veronika » Thu Jan 18, 07 9:05 am
TheSheep wrote:What did you use to convert them - some sort of reverse unr2de? It would be awesome to share that as well :D
Hexy built special DeusExExtractorUTMod, it exports models into Unreal format. I can attach it if needed.
Postby {SKC}Commando » Sun Jan 13, 08 5:34 pm
Yeh good mod.
But i dont have UED2.
Where do i find it?
{SKC}Commando
Postby {SKC}Commando » Sun Jan 13, 08 11:12 pm
Never mind. i found it at:
www.deus-ex.net
Lol. :D
{SKC}Commando
Postby Kajanis » Wed Jan 30, 08 2:56 am
Download links are down! :(
Kajanis
Postby Dae » Wed Jan 30, 08 10:44 am
fixed
Postby [FTF]Freedom » Wed Jan 30, 08 5:03 pm
W00t.
Holsing my breath, trying to pluck up the courage to download it... I've been using UnrealEd for about 6 months and only now getting used to it.... but UED2 sounds slightly better...
[FTF]Freedom
Postby Andrievskaya Veronika » Sun Mar 02, 08 2:30 pm
If after loading (testing) map from UED2 you're don't see it, take my UnrealTournament.ini and place it into your UED2 folder, replacing existing one (don't forget to backup original fire first). This should solve problem.
Or you're can edit the UnrealTournament.ini file manually:
[Editor.EditorEngine]
UseSound=True
CacheSizeMegs=6
GridEnabled=True
SnapVertices=False
SnapDistance=10.000000
GridSize=(X=2.000000,Y=2.000000,Z=2.000000)
RotGridEnabled=True
RotGridSize=(Pitch=128,Yaw=128,Roll=128)
GameCommandLine=-log -hax0r
UnrealTournament.zip
(4.17 KiB) Downloaded 2501 times
update
Postby Andrievskaya Veronika » Thu Mar 20, 08 3:48 pm
I built a little update, because some actors were not displayed in the editor. Now that's fixed. Also the Van mesh has proper size now :)
Installation:
  • Install the previous update if it not installed (click to download).
  • Download the file below and unpack archive into your UED2 folder, overwrite files.
#2.rar
(320.9 KiB) Downloaded 2655 times
Last edited by Andrievskaya Veronika on Thu Mar 20, 08 3:57 pm, edited 2 times in total.
Error with this...
Postby jmrg2992 » Sun Dec 06, 09 10:43 pm
Hello there everybody well, i download the Ued2 editor and i replace on the System Folder of DX, now I download the pacth and it says Error.
Now when i run Unrealed2.exe appears this .Core.dll deleting garbage........ Deus Ex Package Not found, anyone can help me , I'm on the normal version of DX not the GOTY One
jmrg2992
Postby ~DJ~ » Mon Dec 07, 09 1:24 am
It shouldn't be on the system folder. You put a folder like "C:\DeusEx\UED2\" and paste everything there.. I.E Run the batch file there. Anyway, you'll have to install UED2 first then patch.. of course. :$
Postby Andrievskaya Veronika » Wed Dec 09, 09 5:19 am
jmrg2992
check this topic: http://www.dxalpha.com/forum/viewtopic.php?t=14876
DXEP has everything from this fix + some useful stuffs :)
Work
Postby jmrg2992 » Thu May 20, 10 8:19 pm
Pretty nice. well ill make it work thanks to your helps mates. but i got a liltte question. for example i desing one of my maps rigth . knowing . ill make some Airplanes models. there, so i should convert them to run it in Unreal Format ?. and if i convert my Packages models. then will open normally in the Deus Ex original System. thanks
jmrg2992
