MTL Feature
MTL Feature
Postby System » Fri Jan 05, 07 5:28 am
I can't find the documentation on a particular feature of MTL.
Smuggler coded in a way to set your augs from a text file via a mutator command he added in mtl.
So you could press a key and get your augs changed depending on what style you wanted to play. Anyone have the command and syntax?
System
Postby Dae » Fri Jan 05, 07 10:49 am
Copy/paste from HQ forum:
Ricci wrote:open up notepad paste these in(or edit them) and save it as .txt then put it in your system folder. While in game if you want to change your augs you type exec *filename*.txt or bind it through your user.ini. If you have it binded it only works if u are alive if u die u need to type it in order for it to work.
Name: Bal.txt <--stands for ballistic
BindAug 0 AugSpeed
BindAug 1 AugBallistic
BindAug 2 AugDefense
BindAug 3 AugHealing
BindAug 4 AugCloak
BindAug 5 AugShield
BindAug 6 AugEMP
BindAug 7 AugStealth
Bindaug 8 AugAqualung
BindAug -1
Name: Bal1.txt <this time with vision.
BindAug 0 AugSpeed
BindAug 4 AugVision
BindAug 5 AugShield
BindAug 6 AugEMP
BindAug -1
Name: Ad.txt <-- had the name originaly ads.txt but for some reason it would always open up that txt when i joined a game so i had to change the name.
BindAug 0 AugSpeed
BindAug 1 AugDefense
BindAug 2 AugHealing
BindAug 3 AugBallistic
BindAug 4 AugCloak
BindAug 5 AugShield
BindAug 6 AugEMP
BindAug 7 AugAqualung
Bindaug 8 AugStealth
BindAug -1
BindAug 0 AugSpeed
BindAug 4 AugVision
BindAug 5 AugShield
BindAug 6 AugEMP
BindAug -1
BindAug 0 AugSpeed
BindAug 1 AugCloak
BindAug 4 AugHealing
BindAug 5 AugShield
BindAug 6 AugEMP
BindAug -1
BindAug 0 AugSpeed
BindAug 1 AugVision
BindAug 2 AugBallistic
BindAug 3 AugDefense
BindAug 5 AugShield
BindAug 6 AugEMP
BindAug -1
BindAug 0 AugSpeed
BindAug 1 AugTarget
BindAug 4 AugCloak
BindAug 5 AugShield
BindAug 6 AugEMP
BindAug -1
BindAug 0 AugSpeed
BindAug 1 AugShield
BindAug 5 AugCloak
BindAug 6 AugEMP
BindAug -1
_________________
-Ricci
Postby System » Fri Jan 05, 07 2:38 pm
Thanks, that's exactly what I was looking for.
I was forgetting the BindAug -1
System
Postby TBD » Sat Jan 06, 07 5:15 pm
what does this "BindAug -1" part do?
TBD
Postby Splitter » Sat Jan 06, 07 6:39 pm
Are there any more hidden things like this in MTL that most of us don't know about? I remember a few things being posted in the [A] HQ board like this but they were mostly the same too. Did Smuggler hide anything else : p
»§plíttèr/§plícè«
» ÐÇsß « » eNigma² «
Getting TK'd since 24/11/03
Splitter
Postby TBD » Sun Jan 07, 07 5:51 pm
i use this method too without the bindaug -1 part and it works too?
TBD
Postby TBD » Mon Jan 08, 07 4:28 pm
k found it out myself, just saves the aug settings you prefered
TBD
Postby James » Mon Jan 08, 07 4:34 pm
Kinda unrelated but I'd be hopeless without Pressure Release.
(Thanks pre-2005 Jeoh)
Users browsing this forum: No registered users and 93 guests
