:( My mouth hurts.
:( My mouth hurts.
Postby Siva » Wed Apr 25, 07 10:06 am
In the back of my mouth, there is this weird shaped area of gum, that whenever I touch it with food, or my tongue, Its like someone stabbed me in the mouth, it hurts that bad.
I don't think its a wisdom tooth, they don't come until much later.. If it is another one, I thought I was done with that.
Or should I go to the dentist. /shudder.
Postby ~{17}~JIN~ » Wed Apr 25, 07 1:35 pm
sorry your mouthie hurts :P
~{17}~JIN~
DarkVader
Postby {17}~Rob~ » Wed Apr 25, 07 2:12 pm
Dentist - go - now.
{17}~Rob~
Postby ~{17}~JIN~ » Wed Apr 25, 07 2:42 pm
salt and water usually helps... use it like mouthwash... =) Makes your gum stronger.
~{17}~JIN~
DarkVader
Postby Mastakilla » Wed Apr 25, 07 3:42 pm
Pain in your mouth is the worst you can get. imo.
I knew we shouldn't make out this much.
Postby ~M3GG4~ » Wed Apr 25, 07 4:12 pm
yea, if its at the back of your gums, like behind your teeth, its broken gum, most probally a wisdom tooth. :)
I have 4 of them and they hurt like hell at first...and for more after that !!
Rufl, also use salt and water...if you want your gums to fucking sting so much you take out all your teeth, otherwise don't .
LoL 8)
<center> Image </center>
<center>Deus Ex Soldiers
~M3GG4~
Postby MrBlackDX » Wed Apr 25, 07 4:36 pm
If it doesn't pass in a week go to the dentist
Postby ~M3GG4~ » Wed Apr 25, 07 5:46 pm
..or,in addition, come back here, if pain persists, ill direct you through some painless..ish techniques to wrench out them wisdom teeth.
~M3GG4~
Postby Spiderbot01 » Wed Apr 25, 07 5:56 pm
I havn't been to the dentist nigh on seven years, last time the dentist tells ME i need braces.
Postby Cyrus » Wed Apr 25, 07 6:15 pm
too bad you didn't listen m8. :(
THANKS KEITH
Cyrus
Commander of IRELAND
Postby MrBlackDX » Wed Apr 25, 07 9:25 pm
When things are bad you go to the dentist no question.
Like when your teeth are fucked up from drinking a lot
Yeah I know, I should let it go
ORLY?
Postby Alex » Wed Apr 25, 07 9:31 pm
{DXS}Destroyer wrote:..or,in addition, come back here, if pain persists, ill direct you through some painless..ish techniques to wrench out them wisdom teeth.
Why would you want that? I got wisdom teeth. They hurt when they are coming up, or however you say it in English, but that's logical, after that - I don't feel a thing.
Postby ~M3GG4~ » Wed Apr 25, 07 10:07 pm
I was joking. :D
Yea, just go to the Dentist.
~M3GG4~
Postby Siva » Fri Apr 27, 07 2:40 pm
I've got one on the other side now.
Damn you mouth, damn you to helllll ;(
Re: :( My mouth hurts.
Postby Chococat » Fri Apr 27, 07 5:45 pm
XII//:Protocol wrote:In the back of my mouth, there is this weird shaped area of gum, that whenever I touch it with food, or my tongue, Its like someone stabbed me in the mouth, it hurts that bad.
When your wisdom teef come through, they'll be so fucking painful you won't be able to move your jaw. (I've broken 7 bones, and wisdom teef coming through your jaw are pretty much the worst bone-feeling pain ever)
Catatatata wrote:I havn't been to the dentist nigh on seven years, last time the dentist tells ME i need braces.
7 years? Eewww.. I absolutely hate the dentists but I need perfect teeth
Postby Siva » Fri Apr 27, 07 10:40 pm
Mum sez that when hers came through, it didn't hurt that much. So I am praying to all 123 gods that it doesn't hurt too much.
Postby Chococat » Sat Apr 28, 07 5:04 pm
Most of you are prolly too young to have had wisdom teeth come through yet, but you'll know when they happen. I didn't even know what wisdom teeth were til they came through, I just thought we had baby teeth and then the second set of teeth. :(
Postby synthetic » Sat Apr 28, 07 8:18 pm
well im 20 and no wisdom teeth problems so far. My mate who is 4 days older had to have his removed. He told me the bleeding was so bad and sudden that the doctors seemed to panic, then they sewed a sponge in his gum. There were worries that he might start bleeding in the army suddenly, and that doesnt really stop that easily, but seems like it healed in time.
Postby MrBlackDX » Mon Apr 30, 07 7:50 pm
my wisdom teeth came through fine
Except one seems to have deteriorated a lot since i cant reach the fucker with my brush
Postby Big Daddy » Tue May 01, 07 7:23 pm
[IO]Razr[IO] wrote:salt and water usually helps... use it like mouthwash... =) Makes your gum stronger.
No, it corrodes your teeth because it is acidic. It disinfects mouth alsors.
