Maps and mods installer
Postby ~D[A]rren~ » Wed Jun 22, 05 2:02 pm
~[A]LTKJAY~ wrote:http://www.dxalpha.com/download/DX1/multiplayer/DXMP_Maps_&_Mods_Archive_Installer_v.101.exe
Should be working now, Darren is testing.
It works. 8)
JC
Postby James » Wed Jun 22, 05 2:11 pm
To the top post it goes.
The torrent is available here and here.
I will make the file available on FilePlanet if I can, but I haven't done that yet.
You will need a BitTorrent client (like Azureus or BitTornado) to get it.
Or you can download a direct link without using a torrent using these mirrors:
Final size: 315 MB (about a GB worth of files after extraction. The compression was really good)
What it does:
  • Installs 350+ Maps (including textures, music, sound, etc)
  • Installs the No-CD fix
  • Installs MTL patch
  • Installs Engine.dll that can play/record demorecs properly
  • Installs OpenGL rendering fix
  • Installs DXIPServer security fix
  • Backs up your DeusEx.ini and User.ini files
  • Installs Documentation (ReadMe, FAQ, Community links, Videos, etc)
  • Registers the deusex:// protocol so you can join servers from a link
  • Installs new splash screens
I hope you all like it. It took a long time to make. :)
-moop
Postby Trailmix » Thu Jun 23, 05 8:30 pm
I was wondering if you could provide a list of what maps require which packages (not like another version of the torrent) but it'd be useful when hosting a map. 8)
Trailmix
Postby Alistair » Sat Jun 25, 05 6:38 pm
Package's? The .utx's and .u's are placed in the correct folders :P
Postby Trailmix » Sat Jun 25, 05 11:05 pm
I don't think another installation of the DXMMAI to my server hosting version of Deus Ex is necessary. 8)
Trailmix
Postby moop » Sun Jun 26, 05 3:51 am
For now, the installer is a one-stop-shopping solution for the DX host who wants all the maps.
What it does not include is, as you've pointed out, Trailmix, a comprehensive list of precisely which packages are required by each map.
Right now I have a .zip file of every map, with its appropriate packages, but since I have not tested whether every map works with ONLY the packages included in the .zip I have (plus default DX packages), I was not willing to distribute them as individual .zip files. My goal was to release the installer in such a way that after extraction, no map was unable to be played (if you read the ReadMe files for some maps, they can still be played, but only after minor adjustments, like some TNAG/Altfire maps).
Okay, so with that background information, I can answer your real question, which is whether I can provide that list of which maps require which packages.
The short answer: Yes, I can.
The long answer: Yes I can but... I haven't done it yet, and I only have a partial list so far, AND there is no quick and easy way to do what you are asking other than to delete all non-default package files, and then extract the map file, then test the map by loading DX. Record any missing packages, if DX gives a "missing package" filename, add that file to the appropriate directory, making sure that it is the most recent version of that package file (Like NPhase.u has some old versions... fortunately, the newest version of NPhase.u is backwards-compatible), repeat the process of loading, detecting missing packages, adding the missing packages, and re-loading DX, until the map successfully loads. If you are missing a required package file for any map, write it down. Send me a list of any maps which require package files you don't have. Then, delete the map, and non-default package files which you added during testing. Repeat this process over three hundred and fifty times. Can you see now why I haven't done this? The amount of time, and sanity, required to do this, would be absurd.
I am, however, willing to release a Caveat-Emptor list of each zip's contents, and if you can get away with installing ONLY those files on top of a default-DX installation, and the map still works, then good. You probably got everything you needed to run the map.
I have also released this .zip files-only version of the entire archive to IchoTolot. I'm glad someone else has this so when I get hit by a bus that the community doesn't lose half the shit ever made for DX. :D
moop
Postby Trailmix » Sun Jun 26, 05 7:41 pm
That .zip thing would be fine. :)
Thanks for your time in making that uber long post and I second that I wouldn't want to make that whole mumbo jumbo list. :P
Trailmix
Postby moop » Sun Jun 26, 05 7:58 pm
Here's a list of most of the maps, sorted into their corresponding archive-folders. If you need the others (like Bandit's Maps, Tyrino's Maps, Party-Zone Maps, let me know, I'm feeling lazy right now. :D)
DXMP_007maps\DXMP_007_Base.dx
DXMP_007maps\DXMP_007_command_central.dx
DXMP_007maps\FLKeypad.u
DXMP_1v1\DXMP_1v1.dx
DXMP_30-06Migraine\DXMP_30-06Migraine.dx
DXMP_4Towers\DXMP_4Towers.dx
DXMP_8Red\ATDM.u
DXMP_8Red\ATDMicons.utx
DXMP_8Red\CaroneElevatorSet.u
DXMP_8Red\DXMP_8Red.dx
DXMP_8Red\ReadMe_CaroneElevatorSetv1.5.txt
DXMP_8Red\ReadMe_DXMP_8Red.txt
DXMP_Abandoned\DXMP_Abandoned.dx
DXMP_Abandoned\N64_DukeNukem.umx
DXMP_Abandoned\ReadMe_DXMP_Abandoned.txt
DXMP_Abandoned_City\DXMP_AbandonedCity.dx
DXMP_Abandoned_City\TrWalls.utx
DXMP_AbndCargohold\DXMP_abndcargohold.dx
DXMP_ABridgeTooFar V2\DXMP_ABridgeTooFar V2.dx
DXMP_AirfieldHeliBase_2000\DXMP_AirfieldHeliBase_2000.dx
DXMP_AirfieldHeliBase_2000\Helibase.utx
DXMP_AirfieldHeliBase_2000\Sclan.u
DXMP_AirfieldHeliBase_2001\DXMP_AirfieldHeliBase_2001.dx
DXMP_AirfieldHeliBase_2001\Helibase.utx
DXMP_AirfieldHeliBase_2001\Sclan.u
DXMP_Ai_\DXMP_Ai_.dx
DXMP_Ai_\Readme_DXMP_Ai_.txt
DXMP_AkiraReminiscence\bomb.u
DXMP_AkiraReminiscence\DXMP_AkiraReminiscence.dx
DXMP_AkiraReminiscence\NPhase.u
DXMP_AkiraReminiscence\ReadMe_DXMP_AkiraReminiscence.txt
DXMP_AkiraReminiscencev2\DXMP_AkiraReminiscenceV2.dx
DXMP_AkiraReminiscencev2\Mutation.utx
DXMP_AkiraReminiscencev2\NPhase.u
DXMP_AkiraReminiscencev2\ReadMe_DXMP_AkiraReminiscenceV2.txt
DXMP_Ambrosia_Mine\DXMP_Ambrosia_Mine.dx
DXMP_Archives_Beta\007Tex.utx
DXMP_Archives_Beta\DXMP_Archives_Beta.dx
DXMP_Arctic\DXMP_Arctic.dx
DXMP_Area51Bunker\DXMP_Area51Bunker.dx
DXMP_Area51TNAG\DXMP_Area51.dx
DXMP_Area51TNAG\Godown.umx
DXMP_Area51TNAG\Readme_DXMP_Area51TNAG.txt
DXMP_Area51tunnelsbeta\DXMP_Area51tunnelsbeta.dx
DXMP_Area52\DXMP_Area52.dx
DXMP_Arena\DXMP_Arena.dx
DXMP_Assault\DXMP_Assault.dx
DXMP_Assault\Pickles.utx
DXMP_Assault\VIndustrial.utx
DXMP_Atlantis\DXMP_Atlantis.dx
DXMP_Atlantis2\DXMP_Atlantis2.dx
DXMP_ATSniper\DXMP_ATSniper.dx
DXMP_Basketball\DXMP_Basketball.dx
DXMP_Basketball\ReadMe_DXMP_Basketball.txt
DXMP_Battlefield\Battlefield.utx
DXMP_Battlefield\CaroneElevatorSet.u
DXMP_Battlefield\DXMP_Battlefield.dx
DXMP_Battlefield\ReadMe_CaroneElevatorSetv1.5.txt
DXMP_Battlefield\ReadMe_DXMP_Battlefield.txt
DXMP_Battlefield\UnTextures.utx
DXMP_BattleZone\BattleZone.utx
DXMP_BattleZone\CaroneElevatorSet.u
DXMP_BattleZone\DXMP_BattleZone.dx
DXMP_BattleZone\ReadMe_CaroneElevatorSetv1.5.txt
DXMP_BattleZone\ReadMe_DXMP_BattleZone.txt
DXMP_BattleZone\UnTextures.utx
DXMP_BigSteel\DTRCrate.u
DXMP_BigSteel\DXMP_BigSteel.dx
DXMP_BigSteel\Forever.umx
DXMP_BigSteel\kabong1.utx
DXMP_BigSteel\Readme_DXMP_BigSteel.txt
DXMP_BlackHawkCity\ATDM.u
DXMP_BlackHawkCity\ATDMicons.utx
DXMP_BlackHawkCity\DXMP_BlackHawkCity.dx
DXMP_BlackHawkCity\ReadMe_DXMP_BlackHawkCity.txt
DXMP_BlackHawkCity\stereo.utx
DXMP_Bloodball\BB.utx
DXMP_Bloodball\DXMP_Bloodball.dx
DXMP_Bloodball\HowTo_DXMP_Bloodball.txt
DXMP_Bloodball\ReadMe_DXMP_Bloodball.txt
DXMP_Bridge\DXMP_Bridge.dx
DXMP_Bridge\FM.u
DXMP_Bucktown\DXMP_Bucktown.dx
DXMP_Campground\dxmp_campground.dx
DXMP_Canyon_Base\Duff.utx
DXMP_Canyon_Base\DXMP_Canyon_Base.dx
DXMP_Canyon_Base_2\DXMP_Canyon_Base_2.dx
DXMP_CarPark\CarPark.utx
DXMP_CarPark\DXMP_CarPark.dx
DXMP_CarPark\ReadMe_DXMP_CarPark.txt
DXMP_Castle_Crypt_Beta3\CCSounds.uax
DXMP_Castle_Crypt_Beta3\DXMP_Castle_Crypt_BETA3.dx
DXMP_Castle_Crypt_Beta3\NanoTech.u
DXMP_Castle_Crypt_Beta3\NTBoards.utx
DXMP_Cathedral\DXMP_Cathedral.dx
DXMP_Chateau\DXMP_Chateau.dx
DXMP_Chateau\ReadMe_DXMP_Chateau.txt
DXMP_CityOfMarble\DXMP_CityOfMarble.dx
DXMP_CityOfMarble\Mutation.utx
DXMP_CityOfMarble\NPhase.u
DXMP_CityOfMarble\ReadMe_DXMP_CityOfMarble.txt
DXMP_Close_Quarters\DXMP_Close_Quarters.dx
DXMP_Close_Quarters2003\DXMP_Close_Quarters2003.dx
DXMP_CloudStrife's_Crazy_ZoneV3\DXMP_CloudStrife's_Crazy_ZoneV3.DX
DXMP_Condemned\DUFF.UTX
DXMP_Condemned\DUFF2.UTX
DXMP_Condemned\DUFF3.UTX
DXMP_Condemned\DXMP_Condemned.dx
DXMP_Condemned\KEYBOARD3.UTX
DXMP_Condemned\SSFUTURE.UTX
DXMP_Condemned\UnTextures.utx
DXMP_Confrontation\DXMP_Confrontation.dx
DXMP_Confrontation\MUTATION.utx
DXMP_Confrontation\NPhase.u
DXMP_Confrontation\ReadMe_DXMP_Confrontation.txt
DXMP_CountCastle\DXMP_CountCastle.dx
DXMP_CQ\DXMP_CQ.dx
DXMP_CQ\ReadMe_DXMP_CQ.txt
DXMP_Crazy_Roomz_1_and_2\DXMP_Crazy_Roomz_V1.dx
DXMP_Crazy_Roomz_1_and_2\DXMP_Crazy_Roomz_V2.dx
DXMP_Crazy_Roomz_3_and_4\DXMP_Crazy_Roomz_V3.dx
DXMP_Crazy_Roomz_3_and_4\DXMP_Crazy_Roomz_V4.dx
DXMP_Cross\DXMP_Cross.dx
DXMP_Cross\Lock.umx
DXMP_Cybris\DXMP_cybris.dx
DXMP_CybrisFacility\CybrisFacility
DXMP_CybrisFacility\CybrisFacility\DXMP_CybrisFacility.dx
DXMP_CybrisFacility\CybrisFacility\Readme_DXMP_CybrisFacility.txt
DXMP_Cyraxx\Boss_music.umx
DXMP_Cyraxx\CyraxxTex.utx
DXMP_Cyraxx\DXMP_Cyraxx.dx
DXMP_Damnationalley\Alley.utx
DXMP_Damnationalley\CarPark.utx
DXMP_Damnationalley\DXMP_DamnationAlley.dx
DXMP_Damnationalley\Readme_DXMP_DamnationAlley.txt
DXMP_DarkSkies_v101\DXMP_DarkSkies_101.dx
DXMP_DarkSkies_v101\ReadMe_DXMP_DarkSkies.txt
DXMP_DD_outpost\DXMP_DD_outpost.dx
DXMP_DD_outpost\ReadMe_DXMP_DD_Outpost.txt
DXMP_Dead-Eyes\DXMP_Dead-Eyes.dx
DXMP_Dead-Eyes\ReadMe_DXMP_Dead-Eyes.txt
DXMP_DeathMountain\DXMP_DeathMountain.dx
DXMP_DeathSwamp\DXMP_DeathSwamp.dx
DXMP_DeepBlue\DeepBlue_Music.umx
DXMP_DeepBlue\DXMP_Deepblue.dx
DXMP_Deep_Cave\DXMP_Deep_Cave.dx
DXMP_Deep_Cave2\ATDM.u
DXMP_Deep_Cave2\ATDMicons.utx
DXMP_Deep_Cave2\DXMP_deep_cave2.dx
DXMP_Deep_Cave2\ReadMe_DXMP_Deep_Cave2.txt
DXMP_Desolation\dxmp_desolation.dx
DXMP_Desolation\ReadMe_DXMP_desolation.txt
DXMP_DeusExHQ\DXMP_DeusExHQ.dx
DXMP_DevilsBackbone\DXMP_DevilsBackbone.dx
DXMP_DevilsBackbone\ReadMe_DXMP_DevilsBackbone.txt
DXMP_DevilsBackbone\Run.umx
DXMP_DiocitiyusBeta3\Diocitiyus.utx
DXMP_DiocitiyusBeta3\DXMP_DiocitiyusBeta3.dx
DXMP_Discombobulation\DXMP_Discombobulation.dx
DXMP_Dissero\DisseroMod.u
DXMP_Dissero\DXMP_Dissero.dx
DXMP_Dissero\ReadMe_DXMP_Dissero.txt
DXMP_Dockside\DXMP_Dockside.dx
DXMP_DownShip\DXMP_DownShip.dx
DXMP_DragonShrine\DXMP_DragonShrine.dx
DXMP_Duality\DXMP_Duality2005.dx
DXMP_Duality\MUTATION.utx
DXMP_Duality\NPhase.u
DXMP_Duality\ReadMe_DXMP_Duality.txt
DXMP_Duel\Course.umx
DXMP_Duel\DoorsMod.uax
DXMP_Duel\DXMP_Duel.dx
DXMP_Duel\face.utx
DXMP_Duel\LavaRoom.utx
DXMP_DXMorpheusTNAG\DXMP_DXMorpheus.dx
DXMP_DXMorpheusTNAG\Morpheus.utx
DXMP_DXMorpheusTNAG\ReadMe_DXMP_DXMorpheus.txt
DXMP_DXMorpheusTNAG\SaveMe.umx
DXMP_East_LA\DXMP_EAST_LA.dx
DXMP_East_LA\LA.utx
DXMP_Eclipse\DXMP_Eclipse.dx
DXMP_Eclipse\MUTATION.utx
DXMP_Eclipse\NPhase.u
DXMP_Eclipse\ReadMe_DXMP_Eclipse.txt
DXMP_EnemyAtTheGates\DXMP_EnemyAtTheGates.dx
DXMP_Evolution_Beta1\dxmp_evolution_beta1.dx
DXMP_Exile\DXMP_eXiLe.dx
DXMP_Exile\ReadMe_DXMP_eXiLe.txt
DXMP_Exile\TCNdk.utx
DXMP_FantasticDeathAbyss\DXMP_FantasticDeathAbyss.dx
DXMP_FantasticDeathAbyss\MUTATION.utx
DXMP_FantasticDeathAbyss\NPhase.u
DXMP_FantasticDeathAbyss\ReadMe_DXMP_FantasticDeathAbyss.txt
DXMP_Fightclub_TeamExtreme\CaroneElevatorSet.u
DXMP_Fightclub_TeamExtreme\DXMP_FightClub_TeamExtreme.dx
DXMP_Fightclub_TeamExtreme\FC.utx
DXMP_Fightclub_TeamExtreme\HowTo_DXMP_Fightclub_TeamExtreme.txt
DXMP_Fightclub_TeamExtreme\ReadMe_CaroneElevatorSetv1.5.txt
DXMP_Fightclub_TeamExtreme\ReadMe_DXMP_Fightclub_TeamExtreme.txt
DXMP_Fightinsky3\dxmp_fightinsky3.dx
DXMP_Fight_Club\DXMP_Fight_Club.dx
DXMP_Fight_Club\FC.utx
DXMP_ForBlood&Honor\DXMP_ForBlood&Honor.dx
DXMP_ForBlood&Honor\ReadMe_DXMP_ForBlood&Honor.txt
DXMP_Frequency\DXMP_Frequency.dx
DXMP_Frequency\IIS_Frequency.utx
DXMP_Frequency\Insurgent.utx
DXMP_Frequency\ReadMe_DXMP_Frequency.txt
DXMP_Glitter\DXMP_Glitter.dx
DXMP_Glitter\MUTATION.utx
DXMP_Glitter\NPhase.u
DXMP_Glitter\ReadMe_DXMP_Glitter.txt
DXMP_GravelPit\DXMP_GravelPit.dx
DXMP_GravityForts\DXMP_GravityForts.dx
DXMP_GrayVessel\DXMP_GrayVessel.dx
DXMP_G_E-corp\DXMP_G_E-corp.dx
DXMP_G_LostArea\DXMP_G_LostArea.dx
DXMP_HangarStorage\DXMP_HangarStorage.dx
DXMP_HedgeFields\DXMP_HedgeFields.dx
DXMP_HedgeFields\HedgeFields_Music.umx
DXMP_Helibase\DXMP_Helibase.dx
DXMP_Hells_Kitchen\DXMP_Hells_Kitchen.dx
DXMP_HighWire\DXMP_HighWire.dx
DXMP_High_Dive\DXMP_High_Dive.dx
DXMP_Hotel\DXMP_Hotel.dx
DXMP_Housearrest\DXMP_HouseArrest.dx
DXMP_Housearrest\HouseArrrest_Music.umx
DXMP_Housearrest\OldGrandadsTexs.utx
DXMP_Housearrest\ReadMe_DXMP_HouseArrest.txt
DXMP_HouseOfPain\ATDM.u
DXMP_HouseOfPain\ATDMicons.utx
DXMP_HouseOfPain\DXMP_HouseOfPain.dx
DXMP_HouseOfPain\ReadMe_DXMP_HouseOfPain.txt
DXMP_HouseOfPain_2\ATDM.u
DXMP_HouseOfPain_2\ATDMicons.utx
DXMP_HouseOfPain_2\DXMP_HouseOfPain_2.dx
DXMP_HouseOfPain_2\ReadMe_DXMP_HouseOfPain_2.txt
DXMP_HTortureCastle\DXMP_HTortureCastle.dx
DXMP_Hydro\DXMP_Hydro.dx
DXMP_Hydro\ReadMe_DXMP_Hydro.txt
DXMP_Infiltration\DXMP_Infiltration.dx
DXMP_Infiltration\ReadMe_DXMP_Infiltation.txt
DXMP_Islands\DXMP_Islands.dx
DXMP_Italy\DXMP_Italy.dx
DXMP_Italy\ReadMe_DXMP_Italy.txt
DXMP_JaggedEnclosure_Beta1\&#937.u
DXMP_JaggedEnclosure_Beta1\Cannonade.umx
DXMP_JaggedEnclosure_Beta1\DXMP_JaggedEnclosure_Beta1.dx
DXMP_JaggedEnclosure_Beta1\LavaRoom.utx
DXMP_JaggedEnclosure_Beta1\OmegaTex.utx
DXMP_JaggedEnclosure_Beta1\TerrainTex.utx
DXMP_Jailbreak\DXMP_Jailbreak.dx
DXMP_Jailbreak\ReadMe_DXMP_Jailbreak.txt
DXMP_JunkYard\Duff.utx
DXMP_JunkYard\DXMP_JunkYard.dx
DXMP_KarkianAssault\DXMP_KarkianAssault.dx
DXMP_KarkianAssault\Reproducer.u
DXMP_Kyoukai\DXMP_kyoukai.dx
DXMP_Ladder-Park_D\DXMP_Ladder-Park_D.dx
DXMP_Ladder-Park_N\DXMP_Ladder-Park_N.dx
DXMP_Lamwarz\DXMP_Lamwarz.dx
DXMP_LibertyIsland\DXMP_LibertyIsland.dx
DXMP_Lostcity\DXMP_LostCity.dx
DXMP_Lostcity\ReadMe_DXMP_LostCity.txt
DXMP_LuigiNuke's_ClubResort\DXMP_LuigiNuke's_ClubResort.dx
DXMP_Mantracomplex\DXMP_Mantracomplex.dx
DXMP_Mantravista\DXMP_Mantravista.dx
DXMP_Mantravista\Mantravista.utx
DXMP_Mantravista\ReadMe_DXMP_Mantravista.txt
DXMP_Marina\DXMP_Marina.dx
DXMP_Maze\DXMP_Maze.dx
DXMP_Maze\Mm.u
DXMP_MCI(v0-95)\DXMP_MCI(v0-95).dx
DXMP_Mcramos\DXMP_Mcramos.dx
DXMP_Mcramos\ReadMe_DXMP_Mcramos.txt
DXMP_Mega-CatCompany_4th_Lab\DXMP_Mega-CatCompany_4th_Lab.dx
DXMP_MJ12\DXMP_MJ12.dx
DXMP_MJ12\ReadMe_DXMP_MJ12.txt
DXMP_MooKs_UnlimitedParty-2\DXMP_MooKs_UnlimitedParty-2.dx
DXMP_Moon\DXMP_Moon.dx
DXMP_Morbias\DXMP_Morbias.dx
DXMP_Morbias]I[\DXMP_morbias]I[.dx
DXMP_Motor_Inn\DXMP_Motor_Inn.dx
DXMP_Mountain2\DXMP_mountain2.dx
DXMP_NEOCRON_Beta1\NeocronTex.utx
DXMP_NEOCRON_Beta1\NEOCRON_Beta1.dx
DXMP_NightclubTNAG\DXMP_NightClub.dx
DXMP_NightclubTNAG\ReadMe_DXMP_NightClub.txt
DXMP_Nightmare\DXMP_Nightmare.dx
DXMP_Nightmare\MUTATION.utx
DXMP_Nightmare\NPhase.u
DXMP_Nightmare\ReadMe_DXMP_Nightmare.txt
DXMP_Nightwatch\DXMP_Nightwatch.dx
DXMP_Nightwatch\Mantravista.utx
DXMP_Nightwatch\ReadMe_DXMP_Nightwatch.txt
DXMP_NMW2\DXMP_NMW2.dx
DXMP_NMW2\ReadMe_DXMP_NMW2.txt
DXMP_Noob_Info\DXMP_Noob_Info.dx
DXMP_Noob_Info\NewbieInfo (2).utx
DXMP_Noob_Info\NewbieInfo.utx
DXMP_NoWayOut\DXMP_NoWayOut.dx
DXMP_NoWayOut\eXtreme-players.nfo
DXMP_NSF_houseSE\DXMP_NSF_HouseSE.dx
DXMP_NSF_houseSE\ReadMe_DXMP_NSF_HouseSE.txt
DXMP_Nucleus\CaroneElevatorSet.u
DXMP_Nucleus\DTRCrate.u
DXMP_Nucleus\DXMP_Nucleus.dx
DXMP_Nucleus\Nucleus.utx
DXMP_Nucleus\ReadMe_CaroneElevatorSetv1.5.txt
DXMP_Nucleus\ReadMe_DXMP_Nucleus.txt
DXMP_Nucleus\UnTextures.utx
DXMP_NYC-Streets\DXMP_NYC-Streets.dx
DXMP_NYCBar\DXMP_NYCBar.dx
DXMP_Oilrig\DXMP_Oilrig.dx
DXMP_OneDay\DXMP_OneDay.dx
DXMP_OneDay\FutureTex.utx
DXMP_OneDay\mistylk.umx
DXMP_Onslaught\DXMP_Onslaught2005.dx
DXMP_Onslaught\MUTATION.utx
DXMP_Onslaught\NPhase.u
DXMP_Onslaught\ReadMe_DXMP_Onslaught.txt
DXMP_OperationZero_Beta\DXMP_OperationZero_Beta.dx
DXMP_Opposing_Worlds\DXMP_Opposing_Worlds.dx
DXMP_Orbital\DXMP_Orbital.dx
DXMP_Orbital\ReadMe_DXMP_Orbital.txt
DXMP_Orius\DXMP_Orius.dx
DXMP_Orius\MPBots.u
DXMP_Orius\ReadMe_DXMP_Orius.txt
DXMP_Orius\Trail_of_Blood.umx
DXMP_Orius\UnTextures.utx
DXMP_Osgood\bibocorp.utx
DXMP_Osgood\DXMP_Osgood.dx
DXMP_Outpost\DXMP_Outpost.dx
DXMP_Outpost\ReadMe_DXMP_Outpost.txt
DXMP_Outpost\UnTextures.utx
DXMP_Palace_Beta4\DXMP_Palace_Beta4.dx
DXMP_Palace_Beta4\Foregone.umx
DXMP_Palace_Beta4\GreatFire.utx
DXMP_Paradise\DXMP_Paradise.dx
DXMP_Paris\DXMP_Paris.dx
DXMP_ParisClub2\DXMP_ParisClub2.dx
DXMP_PIBLobbyRF2\DXMP_PIB_Lobby(RF2).dx
DXMP_PIBLobbyRF2\ReadMe_DXMP_PIB_Lobby(RF2).txt
DXMP_PitOfDoom\DXMP_PitOfDoom.dx
DXMP_PlutroleumIncBeta3\DXMP_PlutroleumIncBeta3.dx
DXMP_Proteus(beta2_final)\DXMP_Proteus(beta2_final).dx
DXMP_Proteus(beta2_final)\monologue.umx
DXMP_Pure_Evil\DXMP_Pure_Evil.dx
DXMP_Pure_Evil\ReadMe_DXMP_Pure_Evil.txt
DXMP_Pure_Evil\StarWars.u
DXMP_Pyramid\DXMP_Pyramid.dx
DXMP_Pyramid2\DTRCrate.u
DXMP_Pyramid2\DXMP_pyramid2.dx
DXMP_Pyramid2\PyramidTextures.utx
DXMP_Pyramid2\ReadMe_DXMP_Pyramid2.txt
DXMP_Pyramid2\Tactical.u
DXMP_RatteryPark\Daft.u
DXMP_RatteryPark\DXMP_RatteryPark.dx
DXMP_ReactorBase\DXMP_ReactorBase.dx
DXMP_ReactorBase\ReadMe_DXMP_ReactorBase.txt
DXMP_ReactorBase\Tactical.u
DXMP_Recruitment\DXMP_Recruitment.dx
DXMP_Redemption\DXMP_Redemption.dx
DXMP_Redemption\ReadMe_DXMP_Redemption.txt
DXMP_Redemption\TCNdk_DBB.utx
DXMP_Redemption\TCNdk_DBBTex.utx
DXMP_Redemption\TCNDK_Red.utx
DXMP_Redemption\TCNDK_Red2.utx
DXMP_Redwood\DXMP_Redwood.dx
DXMP_Redwood\ReadMe_DXMP_Redwood.txt
DXMP_Redwood\Redwood.utx
DXMP_Ring\DXMP_Ring.dx
DXMP_Ruins_Pistol\DXMP_Ruins_Pistol.dx
DXMP_Ruins_Sword\DXMP_Ruins_Sword.dx
DXMP_Sahara\DXMP_Sahara.dx
DXMP_SalDali\DXMP_SalDali.dx
DXMP_Sanctuary\DXMP_Sanctuary.dx
DXMP_Sanctuary\NASigs7.utx
DXMP_Sanctuary\ReadMe_DXMP_Sanctuary.txt
DXMP_Sanctuary\UnTextures.utx
DXMP_Sewers\Dxmp_Sewers.dx
DXMP_Silo\DXMP_Silo.dx
DXMP_Silo_Light\DXMP_Silo_Light.dx
DXMP_Simplicity\DXMP_Simplicity.dx
DXMP_SkyfortressV2\DXMP_SkyFortressV2.dx
DXMP_SkyfortressV2\MUTATION.utx
DXMP_SkyfortressV2\NPhase.u
DXMP_SkyfortressV2\ReadMe_DXMP_SkyFortressV2.txt
DXMP_Skyline\DXMP_Skyline.dx
DXMP_SlaughterHouse\DXMP_SlaughterHouse.dx
DXMP_Smuggler2\DXMP_Smuggler2.dx
DXMP_Smuggler2011\DXMP_Smuggler2011.dx
DXMP_Smuggler2011\MOD_DTR_respawn_tnt_crate.zip
DXMP_SmugglerTNAG\DXMP_SmugglerTNAG.dx
DXMP_Smuggler_Light\DXMP_Smuggler_Light.dx
DXMP_Smuggles\DXMP_Smuggles.dx
DXMP_Smuggles\ReadMe_DXMP_Smuggles.txt
DXMP_Smuggles\TCN.utx
DXMP_Smuggles2\DXMP_Smuggles2_revisited.dx
DXMP_Smuggles2\ReadMe_DXMP_Smuggles2.txt
DXMP_Smuggles2\Smuggles2.utx
DXMP_Smuggles2\Tux.u
DXMP_Smughack3\dxmp_smughack3.dx
DXMP_Sniper\DXMP_Sniper.dx
DXMP_Sniper2\DXMP_Sniper2.dx
DXMP_Sniper2\Thehqmod.u
DXMP_Sniperschool\DXMP_Sniperschool.dx
DXMP_SniperSchoolV3\boompigeon.zip
DXMP_SniperSchoolV3\DXMP_SniperschoolV3.dx
DXMP_SniperSchoolV3\ReadMe_DXMP_SniperSchoolV3.txt
DXMP_SpaceshipTNAG\DXMP_SpaceShip.dx
DXMP_SpaceshipTNAG\ReadMe_DXMP_SpaceShip.txt
DXMP_SparMagic2\DXMP_Spar_Magic2.dx
DXMP_SparMagic2\LowWeapons.u
DXMP_Spherical\DXMP_Spherical.dx
DXMP_Stepping_Stones\DXMP_Stepping_Stones.dx
DXMP_StrongHold\DXMP_StrongHold_Beta.dx
DXMP_StrongHold\ReadMe_DXMP_StrongHold.txt
DXMP_Suicide\DXMP_Suicide.dx
DXMP_Supremacy\DXMP_Supremacy.dx
DXMP_Swamps_courtyard\DXMP_Swamps_courtyard.dx
DXMP_Swamps_courtyard\ReadMe_DXMP_Swamps_Courtyard.txt
DXMP_SwampTunnel_Final\DXMP_SwampTunnel_Final.dx
DXMP_SwordFight\DXMP_SwordFight.dx
DXMP_TeamForts\DXMP_TeamForts.dx
DXMP_TGMC\DXMP_TheGentleMensClub.dx
DXMP_TGMC\Najnaj.utx
DXMP_TGMC2\Cool.utx
DXMP_TGMC2\DXMP_TheGentleMensClub2.dx
DXMP_TheAtomicHell\DXMP_TheAtomicHell.dx
DXMP_TheAtomicHell\MUTATION.utx
DXMP_TheAtomicHell\NPhase.u
DXMP_TheAtomicHell\ReadMe_DXMP_TheAtomicHell.txt
DXMP_TheAtomicHellv2\DXMP_TheAtomicHellV2.dx
DXMP_TheAtomicHellv2\MUTATION.utx
DXMP_TheAtomicHellv2\NPhase.u
DXMP_TheAtomicHellv2\ReadMe_DXMP_TheAtomicHellv2.txt
DXMP_TheFort\DXMP_TheFort.Dx
DXMP_TheFort\ReadMe_DXMP_TheFort.txt
DXMP_TheManor\DXMP_TheManor.dx
DXMP_TheManor\Stone.utx
DXMP_TheManor\Syme.utx
DXMP_TheManor2\DXMP_TheManor2.dx
DXMP_TheManor2\Stone.utx
DXMP_TheManor2\Syme.utx
DXMP_TheManor5\DXMP_TheManor5.dx
DXMP_TheManor5\Stone.utx
DXMP_TheManor5\Syme.utx
DXMP_TheMatrix\CyanMatrix.u
DXMP_TheMatrix\DXMP_MatrixNYC.dx
DXMP_TheMatrix\DXMP_Spar.dx
DXMP_TheMatrix\DXMP_TheMatrix.dx
DXMP_TheMatrix\Thehq1.utx
DXMP_TheNewDeathAbyss\DXMP_TheNewDeathAbyss2005.dx
DXMP_TheNewDeathAbyss\MUTATION.utx
DXMP_TheNewDeathAbyss\NPhase.u
DXMP_TheNewDeathAbyss\ReadMe_DXMP_TheNewDeathAbyss.txt
DXMP_TheTower\DXMP_TheTower.dx
DXMP_TheTower\ReadMe_DXMP_TheTower.txt
DXMP_TheTower\TowersStone.utx
DXMP_TheTower\TowersVillage.utx
DXMP_TheTower\TowersWood.utx
DXMP_The_Great_Escape\DXMP_The_Great_Escape.dx
DXMP_The_Great_Escape\ReadMe_DXMP_The_Great_Escape.txt
DXMP_The_Hunting\DxMp_The_Hunting.dx
DXMP_The_Hunting\Forever.umx
DXMP_The_Hunting\ReadMe_DXMP_The_Hunting.txt
DXMP_ThreatofDangerSTL\DXMP_ThreatOfDangerSTL.dx
DXMP_ThreatofDangerSTL\ReadMe_DXMP_ThreatOfDangerSTL.txt
DXMP_Thuggler\DXMP_Thuggler.dx
DXMP_Titanium\DXMP_Titanium.dx
DXMP_Titanium\TITAN.utx
DXMP_Titanium\Titanium_Music.umx
DXMP_ToiletHouse\DXMP_ToiletHouse.dx
DXMP_Tong\DXMP_Tong.dx
DXMP_Tonochi\DXMP_Tonochi.dx
DXMP_TortureCastle\DXMP_TortureCastle_v1.dx
DXMP_TortureCastle\DXMP_TortureCastle_v2.dx
DXMP_TortureCastle\DXMP_TortureCastle_v3.dx
DXMP_Towers\DXMP_Towers.dx
DXMP_Towers\FacesTextures.utx
DXMP_Towers\ReadMe_DXMP_Towers.txt
DXMP_Towers_2\DXMP_Towers_2.dx
DXMP_Towers_2\ReadMe_DXMP_Towers_2.txt
DXMP_Towers_2\SFO_Textures.utx
DXMP_Towers_3\DXMP_Towers_3.dx
DXMP_Towers_3ir\DXMP_Towers_3ir.dx
DXMP_Towers_3ir\ReadMe_DXMP_Towers_3ir.txt
DXMP_Tribute_Park\DXMP_Tribute_Park.dx
DXMP_Triple6City\DXMP_Triple6City.dx
DXMP_TunnelNetwork\DXMP_TunnelNetwork.dx
DXMP_TwoTowers\DXMP_TwoTowers.dx
DXMP_UBoatDock\DXMP_UBoatDock.dx
DXMP_UBoatDock\ReadMe_DXMP_UBoatDock.txt
DXMP_UltimateFighting\btj.utx
DXMP_UltimateFighting\DXMP_UltimateFighting.dx
DXMP_UltimateFighting\ReadMe_DXMP_UltimateFighting.txt
DXMP_Underground\DXMP_Underground.dx
DXMP_Villa\DXMP_Villa.dx
DXMP_VoidCrib\DXMP_VoidCrib.dx
DXMP_VoidCrib\sigs.utx
DXMP_VoidCrib\TrWalls.utx
DXMP_Vortex\DXMP_Vortex.dx
DXMP_Vortex\leftleakinmod
DXMP_Vortex\ReadMe_DXMP_Vortex.txt
DXMP_Vortex\ufo beam
DXMP_Vortex\leftleakinmod\leftleakin.u
DXMP_Vortex\leftleakinmod\ReadMe_Leftleakinmod.txt
DXMP_Vortex\ufo beam\ufobeam.u
DXMP_Wacked\DXMP_Wacked.dx
DXMP_Warhead\DXMP_Warhead.dx
DXMP_Warhead\ReadMe_DXMP_Warhead.txt
DXMP_Warhead\WarheadTex.utx
DXMP_Warzone\DXMP_Warzone.dx
DXMP_WasteLand\DXMP_WasteLand.dx
DXMP_WaterStation\DXMP_WaterStation.dx
DXMP_WaterStation_Light\DXMP_WaterStation_Light.dx
DXMP_Water_Treatment\Dxmp_Water_Treatment.dx
DXMP_Water_Treatment\ReadMe_DXMP_Water_Treatment.txt
DXMP_WestAsia3\DXMP_WestAsia3.dx
DXMP_Wild_West\DXMP_Wild_West.dx
DXMP_Yokatami\DXMP_Yokatami.dx
DXMP_Yokatami\ReadMe_DXMP_Yokatami.txt
DXMP_Zan-Goh\DXMP_Zan-Goh.dx
DXMP_[CG]_CardboardDeathmatch\CBDM.utx
DXMP_[CG]_CardboardDeathmatch\DXMP_[CG]_CardboardDeathmatch.dx
DXMP_[DF]_mall\DarkForce1.int
DXMP_[DF]_mall\DarkForce1.u
DXMP_[DF]_mall\DXMP_[DF]_Mall.dx
DXMP_[DF]_mall\ReadMe_DXMP_[DF]_Mall.txt
DXMP_[DF]_party\DXMP_[DF]_PaRtY.dx
DXMP_[DF]_party\ReadMe_DXMP_[DF]_PaRtY.txt
DXSG_RingTransporterPKG_V2\Aphrodesiac.umx
DXSG_RingTransporterPKG_V2\DXSG_Area51Bunker_V2.dx
DXSG_RingTransporterPKG_V2\ReadMe_DXSG_RingTransporterPKG_V2.txt
DXSG_RingTransporterPKG_V2\SG_Mod.u
DXSG_RingTransporterPKG_V2\SG_STUFF.u
moop
Postby Leenuks » Fri Aug 05, 05 9:04 am
Hi
I downloaded moops archive only to find at the end it says Deus ex is not installed :(
Im on dialup so u can guess how i feel...
Any ideas...
Two fish in a tank.. one fish turns to the other and says.. ill drive .. u man the guns!
Leenuks
Postby Dae » Fri Aug 05, 05 9:22 am
Leenuks wrote:Hi
Any ideas...
It seems like moop's archiver doesn't work if there is no special key about DX in Windows' register. Author's mistake.
I get a little 'patch' for you, just hold on :)
Postby ~D[A]rren~ » Fri Aug 05, 05 9:35 am
Dae's going to make his own little one aren't you. :P 8)
JC
Postby Alex » Fri Aug 05, 05 9:56 am
Leenuks wrote:Hi
Any ideas...
Got the same message....
Postby Dae » Fri Aug 05, 05 11:21 am
Here is tha patch (c) Zonder:
http://zonderstudio.nm.ru/more/DX-reg.rar
Unpack .key file, open it in text editor, find path there and write your path to Deus Ex dir.
In few days there will be a real, .exe program that makes it without these preparations.
Postby Leenuks » Fri Aug 05, 05 1:30 pm
Hi
Your DX-reg.rar file is corrupt?
It has a crc error.. then quits...
Leenuks
Postby Bob » Fri Aug 05, 05 1:37 pm
An error message?
Postby Dae » Fri Aug 05, 05 6:40 pm
Leenuks wrote:Hi
Click 'repair' in WinRAR.
Or download this
DX-reg.zip
in zip
(340 Bytes) Downloaded 3569 times
Postby Leenuks » Sun Aug 07, 05 2:10 pm
I have winace 2.5 and repair is grey'd out...... oh well.....
even linux wont pull the file out... so go figure
Fedora core 3 btw....
:cry:
the above post must not have showed properly... and the download wasnt there soo here goes again
Jus an update... file will not open in notepad.... used hexedit to view and the info is already in the registry.... weird...
Leenuks
Postby moop » Mon Aug 08, 05 2:52 pm
Hiya Leenucks. The Archive Installer is designed to run on windows, unfortunately. I do have a registry fixer here, but the Installer is designed to check for registry keys.
If you want to run it on linux, I'm not sure that's possible, but I can provide a zipped archive of all the files it includes, and I help you to manually tweak your settings file.
PM me if you're interested.
moop
Postby Leenuks » Tue Aug 09, 05 9:51 am
Hi
Well u see i have dx running on both linux and windows... and it is in windows 98se that the proggy says that dx is not installed..
havent tried installing it in linux...
Im installing xp on another drive.. and ill test it there... only installing cause of 3dsmax 7 .. it wants xp dammit...
thx ppl for your help anyways
Oh yeah i new i had seen the fix sumwhere.. but i couldnt access your site for sum reason... thx moop
Leenuks
Postby Dae » Tue Aug 23, 05 3:12 pm
Someone please reupload it on dxalpha.com.
It says archive is broken.
Postby James » Tue Aug 23, 05 3:14 pm
Again?
Postby Dae » Tue Aug 23, 05 9:29 pm
Again as 'reupload it again' or again as 'its broken again'? 8)
Postby James » Tue Aug 23, 05 9:36 pm
Broken, its the most breakful file EVA!1one
Postby IchoTolot » Wed Aug 24, 05 5:15 am
IchoTolot
<i>Very</i> Friendly Clown
Location: Quad 1,0,0 - 3th Planet - 50.6909 North - 11.5947 South
Postby Alistair » Wed Aug 24, 05 7:18 am
Leenuks wrote:I have winace 2.5 and repair is grey'd out...... oh well.....
:cry:
You should use Wine, dunno about fedra core 4, try typing MC into the control and click on your zip file and press F2 and choose your option.
Postby czaja1026 » Tue Feb 28, 06 8:44 pm
REUPLOAD IT !!
in all 3 links it says : cannot find page or
/file.x?id=/deusexgaming.com/thesheep/mapandmodarchiveinstaller-101..exe
The page you have requested is not valid
... and btw:
where i can download EASY deus ex map edtor (not unreal ed , it is too hard for me ;) )
czaja1026
Postby ~ô¿ô~Nobody~ » Tue Feb 28, 06 9:58 pm
ROFL
there is nothing else than UED.. if you can't handle it you're lost
Postby Bob » Tue Feb 28, 06 10:04 pm
Try one of the links on this page:
http://dxmp.apeximages.org/
Postby czaja1026 » Tue Apr 04, 06 10:50 am
heh I HATE VERSION MISMATCH FROM YOUR MOD AND MAPS INSTALLER !!
Eleminate it with:
altfire
MPBots
others i forgot due disk faulire and buy other new ;)
edit:
who want get gmail ?
PM me with mails ;)
sending invits ! :mrgreen:
czaja1026
Postby Imperial » Mon Jan 29, 07 4:45 pm
Someone have a link to this. One that works please.
All these don't :o HArd to beleive but anyway lol
