Nephthys mod discussion
Postby Dae » Thu Dec 14, 06 9:55 pm
New (yet unreleased) Nephthys works even better than I expected. We've just installed it on one of most popular zero-aug servers ([ren]'s one) and despite its being harshly attacked (the message log is being spammed when I log in as admin in game), people still have amazing pings. That's so awesome. God bless you Zora :D
Postby Imperial » Thu Dec 14, 06 10:05 pm
when can we rub it in Dejavus face!?!
Postby Imperial » Thu Dec 14, 06 10:21 pm
to answer my own question not yet.
I guess that you are either still running tests, or the bots are attacing again, not being able to connect to ren server
Postby Mastakilla » Fri Dec 15, 06 12:02 pm
You can connect now.
And: YEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA HAVE IT DEJAVU MOTHERFUCKER... [/happyness][/erection]
Zora rocks. :P
Postby Imperial » Fri Dec 15, 06 9:01 pm
i have the NptServerQuery , or maybe i dont
Help!
Postby Imperial » Fri Dec 15, 06 9:17 pm
still some issues
attached latest server log
and also:
unreal console:
RJA Attack from: 189.136.251.198:63057 stopped, 3 incomplete connections within blah blah blah
ban that ip
attacking.log
(124 KiB) Downloaded 1823 times
Postby Imperial » Fri Dec 15, 06 9:30 pm
Warning: Nephthys: 2006/12/15 19:50:34: Missing 'Nephthys.NptServerQuery' in ServerActors
Warning: Nephthys: 2006/12/15 19:50:34: MaxPlayers(16)+MaxSpectators(0) exceeds ConnCountForDRJA(15) - increase ConnCountForDRJA!
and:
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 83.43.42.73:12689
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 91.127.35.128:53960
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 67.76.68.39:41090
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 72.240.127.99:53949
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 84.47.86.254:16003
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 84.58.148.196:59461
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 88.14.71.169:26905
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 91.127.35.128:43802
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 24.123.80.18:60335
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 62.101.49.131:36108
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 88.153.61.228:36151
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 83.43.42.73:12710
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 201.240.119.129:18064
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 69.153.51.126:61227
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 200.102.182.115:33148
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 83.31.146.101:1191
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 83.43.42.73:12721
Nephthys: 2006/12/15 20:28:50: Uplink query rejected from non-master server 194.79.73.198:20391
Nephthys: 2006/12/15 20:28:51: Uplink query rejected from non-master server 91.127.35.128:52959
Nephthys: 2006/12/15 20:28:51: Uplink query rejected from non-master server 80.78.146.34:53352
Nephthys: 2006/12/15 20:28:51: Uplink query rejected from non-master server 84.47.86.25:5423
Nephthys: 2006/12/15 20:28:51: NptServerQuery: DRUA attack started: 20 requests / 0.948242 seconds
Nephthys: 2006/12/15 20:28:53: RIJ attack from 88.5.234.4:62081 stopped, 3 incomplete connections within 0.816580 seconds, known as ''
Nephthys: 2006/12/15 20:29:09: RIJ attack from 88.118.179.119:18525 stopped, 3 incomplete connections within 17.208060 seconds, known as ''
Nephthys: 2006/12/15 20:29:09: RIJ attack from 200.102.182.109:55866 stopped, 3 incomplete connections within 17.943943 seconds, known as ''
Nephthys: 2006/12/15 20:29:09: RIJ attack from 72.240.127.99:53637 stopped, 3 incomplete connections within 0.252940 seconds, known as ''
Nephthys: 2006/12/15 20:29:09: RIJ attack from 83.8.70.207:52251 stopped, 3 incomplete connections within 0.371948 seconds, known as ''
Nephthys: 2006/12/15 20:29:09: RIJ attack from 82.67.88.31:30341 stopped, 3 incomplete c
Postby Imperial » Fri Dec 15, 06 10:06 pm
At first I thought sunnyside was still there because of skills, then I hosted server with and without skills, both worked.
I have removed geps, plasmas, and flamthrowers,
and I can say that 0aug, once you follow those instructions works!
Postby Zora » Fri Dec 15, 06 10:14 pm
Turkey wrote:Change these settings:
Advanced Options -> Nephthys -> Attacks -> RJA -> ConnCountForRJA = 50
Advanced Options -> Nephthys -> Attacks -> RJA -> TimeDeltaForRJA = 1
for timedelta, just delte zero, so it leaves 1 and all 0s.
No!
This is far off any reasonable values. If you set RJA and DRJA settings to the same values then RJA settings get useless (you won't have any RJA detection any more).
If you already messed around with it, better set it to
AutoBanBitsRJA = 8
ConnCountForRJA = 10
TimeDeltaForRJA = 10
(or slightly higher ConnCountForRJA but only if you see unnecessary RJA attack detections).
Zora
Zora
Nephthys developer
Postby Imperial » Fri Dec 15, 06 10:16 pm
woops sorry!
My bad.. :oops:
THANK YOU ZORA!!
ZET WORKS!
Postby Cozmo » Sat Dec 16, 06 2:09 am
I still can't connect to the non aug servers. :( But at least others can. :roll:
Postby Professor Layton » Sat Dec 16, 06 4:02 pm
I'm experienceing a weird issue with the ren server and with my own server, I can just host both of them without problems and everyone can join during the first game, but once it changes maps, no one seems to be able to join :S The logs also do not show any sign of the people who are trying to join, yet it still shows the IP's that are trying to attack.
Is it possible that "Nephthys: 2006/12/16 15:03:53: DRJA attack detected: 12 new connections within 0.966494 seconds" has something to do with it? (Once again, the attacks still go on, yet no one seems to be able to join)
Postby Zora » Sat Dec 16, 06 5:37 pm
Clix wrote:Is it possible that "Nephthys: 2006/12/16 15:03:53: DRJA attack detected: 12 new connections within 0.966494 seconds" has something to do with it?
Zora wrote:Very important after upgrade from any older version:
Advanced Options -> Nephthys -> Attacks -> DRJA -> ConnCountForDRJA = 50
Advanced Options -> Nephthys -> Attacks -> DRJA -> TimeDeltaForDRJA = 1
Please also read the other important note!
Zora
Zora
Nephthys developer
Postby Siva » Sat Dec 16, 06 6:15 pm
Double Click install file plz.
Postby Professor Layton » Sat Dec 16, 06 6:20 pm
Ah I should read the topic properly in the future then xD Anyway, it works now, I've tried it out with a few players, so great work Zora :D
Postby Alex » Sat Dec 16, 06 8:16 pm
It's a great thing Zora! Many thanks, but I have 1 request. Could you make it like that, that the server hoster can decide if he wants the "Query Rejected" message in his server console? Because then we can just enjoy peace in our console, while being attacked.
EDIT: Stupid me. Already possible. - I think
Postby Allan » Sun Dec 17, 06 3:26 pm
Allan's Server Log Running MMImTyping110 wrote:Init: WinSock: version 2.2 (2.2), MaxSocks=0, MaxUdp=0
Init: WinSock: Socket queue 131072 / 131072
Init: WinSock: I am sara-jb1irxusw7 (82.25.139.211)
DevNet: TcpNetDriver on port 7790
Log: Server Package: SuperMod
Log: Server Package: AllanTeleporter
Log: Loading: Package AllanTeleporter
Log: Server Package: MMImTyping110
Log: Loading: Package MMImTyping110
Log: Spawning: IpDrv.UdpBeacon
Log: Spawning: Nephthys.NptServerQuery
Log: Loading: Package Nephthys
Log: Spawning: Nephthys.NptServerUplink
Log: Spawning: MMImTyping110
Warning: Failed to load 'NULL': Can't resolve package name
Warning: Failed to load 'Class None.MMImTyping110': Can't resolve package name
Warning: Can't resolve package name
Critical: appError called:
Critical: Can't resolve package name
Critical: Windows GetLastError: The system cannot find the file specified. (2)
Ok, I have just installed Nephtys mod, and had no prior versions installed.
Any ideas why it's doing this?
Thanks in advance...
Postby Alex » Sun Dec 17, 06 3:27 pm
Thats a mistake you made :) You added ServerActors=MMImTyping110
Try reinstalling your own mod ;)
Postby Allan » Sun Dec 17, 06 4:37 pm
Whoops... So it is! xD Damn, I feel like such an idiot...
Great mod Zora! :D
Postby Mastakilla » Sun Dec 17, 06 6:18 pm
Zora is my hero! :lol:
Chuck Norris would've saved us eventually though.
Postby ~ScArFaCe~ » Sun Dec 17, 06 7:23 pm
gar im still having problems.
i installed nephthys 1.4 and i changed the settings to:
Zora wrote:Advanced Options -> Nephthys -> Attacks -> DRJA -> ConnCountForDRJA = 50
Zora wrote:AutoBanBitsRJA = 8
I did both of them and im still gettin this attack spam in unreal console.
help needed plz :cry:
ScArFaCe
Sig by Baleout
~ScArFaCe~
Postby ~ô¿ô~Nobody~ » Sun Dec 17, 06 8:18 pm
Sure you still get console spam. But you can use the server again. :)
Postby Alex » Sun Dec 17, 06 8:20 pm
~[A]Nobody~ wrote:Sure you still get console spam. But you can use the server again. :)
Hah! I don't get any console spam. At least, not yesterday. Today, I cannot host because of router problems.
Postby ~ô¿ô~Nobody~ » Sun Dec 17, 06 8:23 pm
Good, then you don't have any server problems either. :lol:
@Supercrazy:
That spam is thrown out, if Nephthys recognizes the attacks from all that IPs.
Sooner or later the spam will decrease because Nephthys banned almost all IPs.
Postby Kaiden » Sun Dec 17, 06 8:48 pm
Or I think there is a setting to have "DRJA Ban in silent" or something, which avoids all the spam??? My server didn't really get attacked anyway, but now its not at-all since I got v4.0 so it must be working! :)
Postby ~ScArFaCe~ » Sun Dec 17, 06 10:29 pm
~[A]Nobody~ wrote:That spam is thrown out, if Nephthys recognizes the attacks from all that IPs.
ooo so thts why the attacks suddenly stopped lol. thx 4 posting anyway :D
ScArFaCe
Sig by Baleout
~ScArFaCe~
Postby Cereal » Mon Dec 18, 06 1:53 am
So essentially this fixes the problem DXMP was faced with?
What?
Cereal
Postby synthetic » Mon Dec 18, 06 6:38 pm
whats funny is that zora posts detailed list of the protection features and installation that will be known to dejavu shortly after zoras post where as dejavu isnt so willing to post his attack features. Go zora go! : )
Postby Dae » Mon Dec 18, 06 7:16 pm
forumer wrote:whats funny is that zora posts detailed list of the protection features and installation that will be known to dejavu shortly after zoras post where as dejavu isnt so willing to post his attack features. Go zora go! : )
It becomes obvious how do dejavu's attacks work after you once launch a 0aug server.
Postby synthetic » Mon Dec 18, 06 7:44 pm
I assumed it isnt too difficult for some people to figure out how exactly he carries it out, but nevertheless the guy treats it as more or less hidden secret, if Im not mistaken.
If I'd look at the server log Id understand Im being "attacked" by many joining IPs and thats about it, it doesnt explain a single thing to me, and sorry but I dont really think everybody in online community can figure out what exactly is causing this connection spam or how to defend against that. Youd have to have a bit of knowledge for that, perhaps basic knowledge for some :p Im certain quite several here know a lot about that so I just look silly, but be open minded! :D
Users browsing this forum: No registered users and 207 guests
