DXJM_Basment_Flood Honest opinions needed
Postby -HDD21- » Sun May 20, 12 3:20 pm
Hello guys, I have been inspired by DXMS_Iceworld and have been working on a map which is similar in size (the size and the way in which cover is not very plentiful outside of spawn areas or around spawn areas. It is okay for augged and zero augged, but not heavy weapons, which have not been added, I do reccomend zero-aug The map has also been designed in a way in which the cloak aug is near enough rendered useless, due to the flooded water. The spawn areas are in sealed rooms, I intend to make the doors only openable on the inside to aid in preventing spawnkilling. The doors out of the spawnrooms are not 'DeusExMovers'
they are normal movers which open by bumping into them.
I also like the basment theme, hence it being a basment and not an 'arena'. Of course the exit is blocked-off.
I have some screenshots of the actual map, and also of the map in the editor 3D window, (no I have NOT made the map using purely the 3D window, I personally cannot do that :O It is at a nice 192kb so far, however I need the opinions of players who are skilled at the game, to say there needs more space to fight in, moving the spawns further away from each other, etc etc.
I need critisisms as well as complements, I would like this map to be perfected for the gameplay experience I am trying to acheve for it.
I need honest opinions, I will supply an unprotected copy of the map on PM request, I only protect the hosted ones to keep them out of DOGNY's hands because I would not put it past him to steal any map and there is nothing worse than watching someone else take credit for what you have done!
I had the map hosted earlier with quite a good battle going on, although I am hungover and it made me even more poo at fighting than I usually am! my first test before hand attracted a few players also but had someone spamming for admin and swearing so had to warn them.
http://www.filefactory.com/file/16vt13w ... nshots_zip
http://www.filefactory.com/file/6wkldri ... od_Beta_dx
-HDD21-
Postby RedDynasty » Sun May 20, 12 5:10 pm
well images would be nice and the links are broken, but it seems like a good idea
RedDynasty
Postby Kalman11 » Mon May 21, 12 4:58 am
Working links from FGS forum:
It looks good, but needs more spawns rooms, proper weapon boards (as chinny mentioned), and some details (maybe you should set small wavy on the water's surface, add some light source (because the light comes from nowhere)
Kalman11
