[RELEASE] Masamune's Admintool Source
Postby Ayleth » Sun Mar 11, 07 10:00 am
As i hope that there are others interested to see how i have done things in my tool, and also seeing as im developing a new, window driven versio, i am providing the source, fully working (except for 1 mode, TempAdmin, which i cant be assed to fix in this edition [edit]: fixed :P) and not changed. If you DO plan to use my code, feel free, just please respect my work by adding credits to me where you release it, and tell me how you use the code.. i may be able to help with the coding, or be able to explain how something works. Not that im a 1337 c0d3r, or even a medium coder, but just to help in the ways i can.
Here it is.
If you want to recompile this and use it on your server, do so, but please don't ask me how to install it! If you know how to compile etc, you should knwo how to create .Int files, and read the source to know how to install.
thanks!
AdminTool.zip
Tool v.2.1 BugFixed, and pruned from AutoAdmin. (Actual Servable Mod)
(9.83 KiB) Downloaded 321 times
Admintool Source.zip
v.2.1 Source.
(5.68 KiB) Downloaded 293 times
AdminTool.int
Repaired .int file
(268 Bytes) Downloaded 304 times
¨‘°ºMåsåmµñ£º°‘¨
˙•●●ĊђασsΪηcǻяйαѓε●●•˙
jason.unger@gmail.com
Ayleth
Postby The RZA » Sun Mar 11, 07 9:15 pm
heh, finally done? cool, nice work. 8)
The RZA
Postby Ayleth » Sun Mar 11, 07 9:34 pm
yeah, basically this version is done. Version 3, tho... I will basically have to Recode almost everything from scratch.
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
Postby Ayleth » Sun Mar 25, 07 1:15 am
--Updated to v.2.1
Bug fixes:
-Temp admin fixed.
-Modeswitcher sometimes jammed. Fixed.
Changes:
-Removed AutoAdmin from package, now available as seperate mod.
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
Postby Ayleth » Fri Apr 06, 07 6:04 pm
[UPDATE]
Someone came to me saying that they couldn't expand the Preferances of the admin tool as i described in the readme...
I have submitted a new .int file, as there was an incorrect referance in it.
Sorry for the bug, and ENJOY!
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
