[RELEASE] Messagerv1 [UPDATE] v1.3
Postby Ayleth » Sat May 19, 07 7:07 pm
Ever wanted to have random or not-so-random messages appear from time to time on your server? Just like in the Beginners server? well no you can. This mod is completely serverside, no client dl needed. Simple to set up and once set up there is no need to touch it again except to change text.
-ChaosIncarnate
NOTE: Serverhosters: Please post here with referance to how you are using this mod. I need productive feedback so i may develope this farther.
Messager 1.3.zip
Version 1.3, includes readme, int file, config file, and source.
(8.22 KiB) Downloaded 818 times
¨‘°ºMåsåmµñ£º°‘¨
˙•●●ĊђασsΪηcǻяйαѓε●●•˙
jason.unger@gmail.com
Ayleth
Postby Kaiden » Sun May 20, 07 12:19 am
Cool, only thing is the download is .rar I noticed. Might be a problem along the line with some people not being able to open it. Just use standard .zip folders. ^_^. Nice mod though. :wink:
Postby Ayleth » Sun May 20, 07 1:22 am
In that case ive added a .zip version too.
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
Postby ~(JTB)-Vínníé~ » Sun May 20, 07 8:43 am
cool mod, i been wanting since i saw it on begginers server :)
~(JTB)-Vínníé~
Postby Alex » Sun May 20, 07 8:45 am
Does it loop the messages, or pick random ones, or can you choose yourself? I'd make it like that, that the host can choose how the messages are being picked.
Postby Ayleth » Sun May 20, 07 8:52 am
Alex, it does that. You can choose Sequential, Random or disabled. Delay is in config as well as if the messager makes logs for every message given.
~(JTB)-Vínníé~ wrote:cool mod, i been wanting since i saw it on begginers server
Thats where i got the idea :P
Ayleth
Postby Ayleth » Sun Jun 03, 07 8:32 am
[dblpost]
I have updated this mod due to some requests by Jon from DXMS.
There was a bug involving the timer not responding to the delay variable, the result of using a byte integer directly in the settimer command, without a typecast. Also, realtime changing of the timer is now available, not need to restart the map.
There are now MetaTags (for lack of better words?) that you insert into the text.
For example:
The current server time is now <time>.
becomes
The current server time is now 12:25PM.
at messagetime.
Commands include:
<time>
<day>
<month>
<year>
<curplayers> //returns the curremt amount of players on the server
<maxPlayers> //max players allowed by the server as set by admin.
<adminName> //returns the adminname as set in the server properties
<adminemail> //returns the adminemail as set in server properties
<servername> //returns the servername as set in server properties
multiple tags and repeated tags are supported within the same message, and lettercase doesn't matter.
Any other ideas for MetaTags would be appreciated.
Note: I am NOT renaming the various versions due to the fact that the mod is completely serverside and isn't downloaded. therefore, version conflicts should not be an issue. I WILL, tho, rename the zip archives, that of one has many versions, they can be told apart.
For coders:
I am thinking of adding a portion that makes a record of the highest scores, and when that person with the highest score kills, a message is broadcast to the p[layers.
IE Lenny and Bob are the only two on the server. Lenny has 5 kills, and Bob only two. Lenny Kills bob and message is sent. then bob kills larry until bob has more kills, then message is sent saying bob has newest high score. the same i want to do with streak.
The only thing, i don't know how to get the serveractor to realize that someone was killed. I tried an override in KilledBy, but that didn't work. should i just create MetaTags and have the message broadcast on a regular basis doing a check each broadcast?
UPDATED: Attachments
[/dblpost]
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
Postby Ayleth » Sun Jun 03, 07 10:49 am
WOW... quick triple post here. v1.2 is done. Added 4 new MetaTags relating to streak and score infos. also included customisable text for if there is noone who holds the titles yet.
UPDATED: Attachments.
I still need to figure out how to make a triggered message relating to someone getting killed. The current way is very messy and grammar becomes an issue on when someone holds the high score vs. when no one has any score.
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
Postby Spiderbot01 » Sun Jun 03, 07 10:57 am
Messager?
A mod that messages you as you play? :oops:
Postby Ayleth » Sun Jun 03, 07 11:17 am
lol yeh. good for if you want to send messages to the players ie contact info etc. good stuff ^^
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
Postby {17}Ales » Sun Jun 03, 07 11:41 am
And the constant messages to not ask for admin which foiled some n00bs plans.
{17}Ales
Postby Jon » Sun Jun 03, 07 11:58 am
One more thing; would it be possible to not display a message containing the Kills/Streak meta tags is no-one has those titles, rather than to replace the words?
Postby Ayleth » Mon Jun 04, 07 8:16 pm
well, that would be interesting. seeing as they are replaced bits of text, that would be wierd. but i could make kind of a switch tag, kinda like an if statement. if the string starts with this switch tag, and the other tag(s) are in the string and aren't containging anthign then choose different message. i'll look into it.
LOL @ Ales.
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
Postby Ayleth » Mon Jun 04, 07 10:04 pm
OK! 1.3 is out. Heres whats changed:
-new metatag: <HighStatsCheck>
>>if this tag is in a line, and that line contains other tags related to highstats, and there is no person with the title for those stats, the message is skipped and anoter one is displayed instead.
-random mode double message check
>> if tthe new message is the same as the last one, a new message is chosen and displayed instead.
-MessageWhenNoPlayers variable
>> if this var is set to true, messages will be sent on an empty server. Very useful alongside Logging set to true to be able to check your strings without having to enter the server.
NOTE: Please post here with referance to how you are using this mod. I need productive feedback so i may develope this farther.
¨‘°ºMåsåmµñ£º°‘¨
Ayleth
Postby Marder » Sun Nov 21, 10 6:22 pm
I think this mod's value is totally under-estimated by most clans/servers.
I've used it in the past and I think it really fills a current need on most servers in DXMP, with quieter servers and less experienced players around, this mod will be invaluable to us in giving admins some peace and quiet and also providing a better service to players.
We'll try to give more specific feedback once it's running again.
Thank you so much.
Marder
Postby Darma » Sun Nov 21, 10 7:09 pm
I know edh private is using it
Darma
Badass
Location: est l'action qui consiste à louer tout bien à une personne (Bail)
Postby ~DJ~ » Sun Nov 21, 10 7:24 pm
Darma wrote:I know edh private is using it
yeah not many though. It's a pretty decent mod if you host ALTFIRE or some other stuff, so you don't have to tell someone constantly about how to altfire.. etc.
