Test Zone development thread
Postby Dae » Fri Jan 11, 08 5:32 pm
Updated: 06.02.07.
Bugs:
  1. Scoreboard: players are listed in a random order.
  2. Gametype: the map doesn't restart when the timer reaches 0:00.
  3. Many BSP holes -> solution in "to do 2".
  4. Basketball:
    1. Baskets stop working suddenly -> more information required.
    2. Balls still jump out of the basket.
    3. Sometimes it doesn't score, or it scores after the ball didn't hit the net.
    4. If a ball hits you when you're holding another ball, you can throw it out.
    5. Basketballs don't disappear when thrown out from the court to water.
  5. Tubular bells don't swing.
  6. The incomplete description of the box gun.
  7. Can't make horizontal lines with the box gun.
To do:
  1. Drums.
  2. Replace brush-based nets with models.
  3. Piano needs more notes.
  4. Set bMeshEnviroMap for the metal bar mesh.
  5. Change the skin of BarIron.
  6. Weapon crafting system.
  7. Traditional Desert Eagle, as it is a FunLine map.
Suggestions: (soon to be moved to the "to do" list)
  1. Colored boxes (by Gishank).
Postby Baleout » Fri Jan 11, 08 5:56 pm
Problems:
1) I would have thought the unlimited box size was easily fixable =/
2) You could make a texture/brush that can't have boxes spawned on?
3) A max amount of boxes on the server (1500?) When it reaches this, either the oldest ones get deleted as more are spawned, or you cannot spawn more until you delete some
4) Infinite bio / automaticaly drops player after 10 seconds / ADS item / way of escaping (e.g. tap jump), + rockets that you can hear coming better, and dont home in as well (slower turning)
Also, when you are captured with the hostage gun, you can still use weapons. You could then capture the person who captured you, causing the funny flying bug and killing one or both of you.
AND to stop the speed aug + hostage gun killing, make the gun drop the hostage if it is put away.
Postby ~UnwAnteD~ » Fri Jan 11, 08 7:05 pm
A net and playing surface for the basketball court
~UnwAnteD~
Postby Baleout » Sat Jan 12, 08 5:30 pm
Oh yeah. Make the basketball walls higher, longer and with 2 baskets as well. =)
Postby Baleout » Mon Jan 14, 08 11:15 pm
Problem:
Sometimes, when making tall stairs or a tower, you fall through any further blocks that you make on the tower, forcing you to stop or start again.
Postby Alex » Mon Jan 14, 08 11:22 pm
Baleout wrote:Problem:
Is fixed already, in next V
Postby Allan » Tue Jan 15, 08 12:03 am
Well, if I could find some piano note noises on the interbutts, I'd have a crack at making the playable piano.
Windows, windows, and more windows again by the looks of it... :P
Postby Baleout » Tue Jan 15, 08 2:23 pm
You could get piano notes from programs like Sibelius?
Postby Dae » Tue Jan 15, 08 2:32 pm
It's easier for me to get sound samples from the flash games, like these:
http://numbera.com/musictheory/piano.aspx
http://www.apronus.com/music/flashpiano.htm
http://www.guitarweek.com/piano/flash-piano.php
But I don't know which sounds better, and are they any good :)
Postby Alex » Tue Jan 15, 08 2:41 pm
They are more like electronic piano's than real piano's, to be honest.
Postby Kaiden » Tue Jan 15, 08 3:34 pm
Lol playing jingle bells on that is awesome.
Postby Baleout » Tue Jan 15, 08 4:26 pm
I played jingle bells on the bells in the Test zone =D
Postby Allan » Tue Jan 15, 08 8:53 pm
Ok, progress on the piano:
I've got some sounds from some Win95 program called 'Sweet Little Piano', so I should be able to fiddle with them for a bit.
Working on butchering something like Keypad to get the buttons into a window. :)
Postby Baleout » Tue Jan 15, 08 11:32 pm
Hey, maybe you could play with your computer keyboard as well as clicking? Maybe the top number row could play notes? =P
Would the sounds still be heard by people around you if it was in a window though?
Postby Allan » Tue Jan 15, 08 11:44 pm
Baleout wrote:Hey, maybe you could play with your computer keyboard as well as clicking? Maybe the top number row could play notes? =P
I could get it to call the PlaySounds through the piano as opposed to the buttons, so mabye. :)
Oh, and there's 12 notes to an octave (A, A#, B, C, C#, D, D#, E, F, F#, G, G#), and 10 number keys.
QWERTYUIOP[] could work though.
Postby Dae » Thu Jan 17, 08 2:24 pm
Relatively big update is coming within 1 hour.
Postby clyzm » Thu Jan 17, 08 2:42 pm
Dae[A] wrote:Relatively big update is coming within 1 hour.
What update?
Postby Kaiden » Thu Jan 17, 08 3:01 pm
Look in an hour! :D
Postby clyzm » Thu Jan 17, 08 3:03 pm
~[A]Kaiden~ wrote:Look in an hour! :D
I can't wait that long!
Postby Kaiden » Thu Jan 17, 08 3:08 pm
Only 16 minutes!
Postby Dae » Thu Jan 17, 08 3:15 pm
Yeh almost, added some sounds etc
Postby Kaiden » Thu Jan 17, 08 4:44 pm
I can play jingle bells better on the bells than Dae, I win.
Postby Baleout » Thu Jan 17, 08 5:28 pm
Dae has a vid of me doing it better than you ever could. >=o
Plus I was the first who played it on ze bells.
I win >=o
Postby Survive. » Thu Jan 17, 08 5:43 pm
Mhe, I will have to check what the updates are :)
Survive.
Postby Alex » Thu Jan 17, 08 6:19 pm
Baleout wrote:Dae has a vid of me doing it better than you ever could. >=o
I win >=o
I was the first to make everyone deaf by playing some hard rock/terror/whatever remix on the bells. Because of me the bells have been adjusted so they are no longer loud.
I win.
Postby Baleout » Thu Jan 17, 08 6:37 pm
I came up with the idea for a piano?
I win? =/
Postby Kaiden » Thu Jan 17, 08 6:45 pm
[A] made it, [A] wins.
Postby Baleout » Thu Jan 17, 08 6:48 pm
Damn you Kaidne!
I win? <=D
Postby Kaiden » Thu Jan 17, 08 7:29 pm
No cause you spell my name wrong on purpose, failout.
Postby clyzm » Thu Jan 17, 08 8:12 pm
A few suggestions:
* Make the Basketball court into 4 zones, 1 is for one point, 2 is for two points, 3 is for 3 points, and 4 is the out of bounds area where if you shoot you cannot get points.
* Add some custom modeled weapons
* Drivable vehicles (like Alex said), possibly helicopter
* The tubular bells are completely black for some reason... :S
* Maybe add 1 more "information" to the bell that describes how to play Jingle Bells.
Users browsing this forum: No registered users and 100 guests
