[QUESTION][REQUEST]View shake code
Postby Tonnochi » Thu Jan 17, 08 8:01 pm
Could someone tell me the code to make the view shake (like it does when you destroy a tri-hull weld point on the ship in SP) and could someone give me a bind code for it for the "F" key please.
Postby ~SaSQuAtCH~ » Thu Jan 17, 08 9:06 pm
RTKM_Volcano has that effect, I suggest you to try to find its creator and ask him to tell you the code if there's no other way.
Postby Allan » Thu Jan 17, 08 9:38 pm
You could look at the mission script for either that boat mission, or mission 15.
Postby Tonnochi » Thu Jan 17, 08 9:41 pm
Come on, this is a request for it, not how to do it.
Couldn't find it there anyway.
Postby Cozmo » Thu Jan 17, 08 10:44 pm
I think they were just EarthquakeTriggers in volcano. :?
Postby Kaiden » Fri Jan 18, 08 8:14 pm
Stop just thinking cause it has Request tag people are gonna drop what they're doing and do it - People make suggestions and you try and do it yourself. :roll:
Postby Tonnochi » Fri Jan 18, 08 8:47 pm
¤[ß2S]¤Cozmo wrote:I think they were just EarthquakeTriggers in volcano. :?
Is it actually possible to summon triggers?
Postby Cozmo » Fri Jan 18, 08 9:05 pm
Never tried, but they're still classes so it should work.
Edit: Summon ShakeTrigger
But it'll only shake for one second, so after that.
admin set shaketrigger shaketime #.000000
Or I could just code something for you. :?
player.ShakeView(shakeTime, shakeRollMagnitude, shakeVertMagnitude);
Postby Tonnochi » Fri Jan 18, 08 9:22 pm
I found out how, so I will summon a lot in a row.
Still need the bind coding for "F".
Postby Cozmo » Sat Jan 19, 08 12:19 am
Ok, with the bind this is closest you can get, mutator:
// MutatorShake - Cozmo
Class MutatorShake extends Mutator config(Mutator);
var() float shakeTime;
var() float shakeRollMagnitude;
var() float shakeVertMagnitude;
simulated function PostBeginPlay()
function Mutate (String S, PlayerPawn Player)
   if(mid(S, 0, 5) ~= "shake")
   if(mid(S, 0, 9) ~= "shakemore")
      shakeTime+=1;
   if(mid(S, 0, 9) ~= "shakeless")
      shakeTime-=1;
Not tested*
And in user.ini
F=mutate shake
And there's mutate shakemore and shakeless to alter shaketime. :)
Postby Tonnochi » Sat Jan 19, 08 3:11 am
Thank you, but I don't know where the hell to put that code.
Postby Kaiden » Sat Jan 19, 08 3:30 am
http://tack.planetdeusex.gamespy.com/Ho ... kages.html :wink:
Save that Code above as .uc in Notepad.
Postby Tonnochi » Sat Jan 19, 08 5:23 am
doesn't work. Assigned as exactly mutate shake and it doesn't work :(
Postby Kaiden » Sat Jan 19, 08 4:02 pm
Here is it compiled, I'm guessing you add EditPackages=Shake, and maybe ServerPackages=Shake, then try in game (After putting file in system folder)
Shake.u
Shake.u
(1.74 KiB) Downloaded 9158 times
Postby Alex » Sat Jan 19, 08 4:18 pm
Question, do you want this to work on your server only, or on all?
Postby Tonnochi » Sat Jan 19, 08 5:09 pm
Singleplayer.
Postby Batchy » Sat Jan 19, 08 5:15 pm
EditPackages=Shake
Batchy
Postby Tonnochi » Sat Jan 19, 08 5:23 pm
I did that.
Postby Kaiden » Sat Jan 19, 08 5:31 pm
Wouldn't it be like Mutategame.mutate shake or something? Like MM is.
Postby ~SaSQuAtCH~ » Sat Jan 19, 08 7:55 pm
Who cares if the same thing happens? :)
Postby Cozmo » Sat Jan 19, 08 11:23 pm
Oh I think I know; I didn't declare the shaketime variable in defaultproperties, so it's 0, ie: Not shaking :|
Postby Tonnochi » Sun Jan 20, 08 5:43 pm
That may have an effect.
Postby Cozmo » Sun Jan 20, 08 10:18 pm
Ok, updated. Add this to your ini as well as server packages.
ServerActors=ShakeMutator.MutatorShake
I don't know how mutators work in singleplayer, if at all, so if not, I'll code something else.
Postby Darma » Fri Aug 27, 10 6:48 pm
Sorry for reviving but to make a mutator works in singleplayer, you need to summon the class (ShakeMutator.MutatorShake) in the map or add it in the editor because ServerActors is used to summon them in multiplayer
Darma
Badass
Location: est l'action qui consiste à louer tout bien à une personne (Bail)
Postby ~DJ~ » Fri Aug 27, 10 7:16 pm
Alot of people know that already now.. :3
BUT YEAH THANKS
Postby Darma » Fri Aug 27, 10 11:35 pm
Yeah but because they were asking (*cough 2 years ago) I replyed (*cough* late)
Darma
Badass
