keypad code in funline.ini
Postby rpmg » Mon Jan 16, 06 7:25 pm
hi,what do i do in funline.ini to set code do you know?
Thanks,RPMG.
rpmg
rpmg
Postby Rödewijk » Mon Jan 16, 06 7:32 pm
post this in Technical issues :arrow:
Postby Dae » Mon Jan 16, 06 7:58 pm
What version of FLKeypad?
Postby IchoTolot » Mon Jan 16, 06 8:41 pm
IchoTolot
<i>Very</i> Friendly Clown
Location: Quad 1,0,0 - 3th Planet - 50.6909 North - 11.5947 South
Postby rpmg » Mon Jan 16, 06 9:35 pm
no that thread is ruined.off topic as well.
Could you remove it daedulus?
I have flkeypad3,
but keypad2 is on as well,in folder,should that make any difference?
rpmg
rpmg
Postby ~ô¿ô~Nobody~ » Mon Jan 16, 06 10:04 pm
of course there's a BIG difference
FLKeypad2 -> hackable
FLKeypad3 -> unhackable
with hackable i mean that one could get the keypad code without someone told him the code
with FLKeypad3 this isn't possible anymore..
so.. a code applied to a FLKeypad3 can just be gotten by opening the map in the unreal editor and looking for the code
..if you protect the map against opening with the editor (points to MapProtectionTool, copyright [GODZ]Nobody (now [A]Nobody))
then the keypad code isN't getable anymore at all
in the case you just wanna add a common MPKeypad you can use the FLKeypad2
Postby Dae » Tue Jan 17, 06 10:02 pm
As for FLKeypad2, open (or create a new one) FunLine.ini file and put these lines into it
[FLKeypad2.ProKeypad]
newcode=654321
Unfortunately I don't remember variables for FLKeypad3 :(
Postby rpmg » Tue Jan 17, 06 10:19 pm
i wanna use flkeypad2,but that doesnt work.
Whats wrong with it. BTW daedulus,there IS a bug in my game, how do i remove it?
rpmg
rpmg
Postby bazza » Fri Feb 10, 06 9:55 am
i want to put a key pad in funline unlimitedparty 3 for the shop doors, but i don't know how, can you please help me [A]Daedalus
Bazza J
bazza
Postby Dae » Fri Feb 10, 06 11:22 am
Spawn keypads, set their tags to doors and it's done. No need to edit the map.
Postby bazza » Fri Feb 10, 06 11:24 am
i don't know how 2 spawn keypads
Bazza J
bazza
Postby Gishank » Fri Feb 10, 06 11:59 am
Look, in game become admin and summon a keypad.
Summon DeusEx.KeyPad1
Then type...
AdminSet KeyPad1 Event <Door Tag>
I think.
Or open SDK make a keypad next to the door and make the door locked and make the keypads code (E.G 1234). Then make the tag summing simple like KeyPad1. Then last but not least Set the event of the keypad to the doors tag. and save load up the game and vola.
Postby Alex » Fri Feb 10, 06 3:19 pm
Ever thought of the fact he needs an MP Keypad, not SP?
Postby Gishank » Fri Feb 10, 06 3:43 pm
DOH!!!!
Well he should already have FLKeypad anyways.
Postby ~ô¿ô~Nobody~ » Fri Feb 10, 06 4:36 pm
~[A]Daedalus~ wrote:As for FLKeypad2, open (or create a new one) FunLine.ini file and put these lines into it
newcode=654321
the FLKeypad3 is handled differently..
there you assign the codes to them in the editor
if you host a server you can set in the server settings which Mode the keypads shall use
so either they use their code assigned in the editor or they use a code out of the avaiable keypadTags/keypadCodes list which you can fill over the server settings
EDIT:
there in attachment is the FLKeypad3
you can change the keypad stuff in the Advanced Options of your dedicated server
so.. right click at the DX server symbol in the task tray
there Advanced Options
there all is setable in the FunLine section
however, you can also easily manage that /keypadEvents/keypadCodes lists as admin in the game
if you have some FLKeypad3 in the map and you want to change the keycode temporarily just target it and type in the console (removing say first)
a example
mutate keypad.add 5824
this programs the target keypad to the code 5824
if you want to change the code just target it again and to the same command with another code (it will overwrite the already existing entry in the list)
in the case you want to remove a temporarily programmed code again, target the keypad and type
mutate keypad.remove
this will remove the entry out of the list again
FLKeypad3.zip
the uber secure and featureful Version 3 of the FLKeypad
(8.98 KiB) Downloaded 327 times
