How Do I Copy Stuff In UnrealEd?
Postby Shinobi » Thu Sep 27, 07 6:52 pm
Hi all.
Gosh this is like my 3rd question in as many days.... =/
Anyway, I'm fiddling with Smuggler at the moment, and for one of my ideas for an edit, I actually need to COPY the whole smuggler map, and place it adjacent to the original map.
Ill rephrase coz that made no sense. What I need is to be able to make 2 smuggler's lairs, next to each other, in the same map file.
I've tried select all and copy, but it doesn't seem to work.
Can anyone tell me how I could do this? Thanks.
Postby ~¤Hit[+]Män¤~ » Thu Sep 27, 07 7:04 pm
you gotta surround the entire map with the builder brush then select all & copy 8)
Asus Blitz Formula
q6600 G0 revision
2gb of kingston hyper x ram pc 6400 800mhz
hd 2600 xt 512mg x2 crossfire
silverstone psu
Dell Ultrasharp 30"
~¤Hit[+]Män¤~
Postby Alex » Thu Sep 27, 07 7:07 pm
First, right click on any brush, and select "Select All"
Then, go to "Edit" and select "Copy"
After that, go to "Edit" and select "Paste"
The result should look like the following image. As you can see, the brushes do not match, use Ctrl + LeftMouse button to move the 'new' Smuggler onto the spot where the original Smuggler is.
Then it should look like this image. Enlarge one of the sideviews, and move the 'new' Smuggler up, using Ctrl + LeftMouse.
And there! That's it. As you can see, I added a black arrow, which points to a grey brush. Delete that brush, and then rebuild.
Postby Shinobi » Thu Sep 27, 07 11:30 pm
Thank you very much.
Brilliant with the screenshots, too.
This mite be a silly question, but does the deletion of that grey brush have something to do with why the whole "new" smuggler was a giant BSP hole when I rebuilt? Coz I didn't know about deleting it.
Or maybe I just did it wrong.
Anyhoo - can't thank ya enough. Cheers!
Postby Alex » Fri Sep 28, 07 7:45 am
The grey brush is a copy of the red brush, and yes, it fucks things up, and sometimes (not sure though) creates BSP holes.
Postby ~ô¿ô~Nobody~ » Fri Sep 28, 07 10:47 pm
Simply don't copy the red one then.
Postby Shinobi » Sat Sep 29, 07 9:36 am
Heh, I like ur style.
Thanks for all help guys, anyway. I've done what I wanted now.
Postby Alex » Sat Sep 29, 07 9:53 am
~[A]Nobody~ wrote:Simply don't copy the red one then.
Or delete the copied one afterwards? ;)
Postby Shinobi » Sat Sep 29, 07 11:27 am
Oh god 'ere we go...
:p
I wanted to copy a map coz... well - you ever played a map called Duality2005?
My plan was to add a warp zone to the vent in Smuggler, and host it for fun, and sorta make it so that when plauyers go thru the "mirror in the vent" they end up in a duplicate smuggler, with a few interesting differences from the original smuggler.
It worked, too!
Postby ~ô¿ô~Nobody~ » Sat Sep 29, 07 11:27 am
Yes, but nobody knows, what this dodgy brush has already done to the map before you delete it! :o
Postby Alex » Sat Sep 29, 07 11:29 am
~[A]Nobody~ wrote:Yes, but nobody knows, what this dodgy brush has already done to the map before you delete it! :o
It does nothing, really. I once had it in a 29MB map, it created some BSP holes, I deleted it, no BSP holes at all.
Postby Shinobi » Sat Sep 29, 07 9:04 pm
wow - 29megabytes worth of potential BSP holes....
