Ued2 error with CaroneElevatorSet
Postby Leenuks » Sun Nov 04, 07 3:54 am
Ued1 loads my map without this hickup.
When I load my map in Ued2 I get this error
From 'editor.log'
Log: New File, Existing Package (Package MyLevel, Package multiplay11)
Warning: Failed to load 'CaroneElevatorSet': Can't find file for package 'CaroneElevatorSet'
Warning: Failed to load 'C:\DeusEx\Maps\multiplay11.dx': Can't find file for package 'CaroneElevatorSet'
Warning: Failed loading package: Can't find file for package 'CaroneElevatorSet'
Ive opened my map in Ued2 before without this problem until today.
Im using version 1.5 of the elevator set.
Ive reinstalled Ued2 with no avail.
Any idea's.
Leenuks
Postby Kaiden » Sun Nov 04, 07 4:25 am
I'm guessing you have EditPackages=CaroneElevatorSet in your dx.ini? And your sure it's in /System, and is it the right file?
Postby Leenuks » Sun Nov 04, 07 4:33 am
Yes I do as it works in Ued1 without any problem.
I start Ued1 and open the map. Ued1 finds the elevator set.
From Ued1 editor.log 'Log: Loading: Package CaroneElevatorSet'
Not so with Ued2 as you can see from first post.
I even unzipped a fresh elevatorset ver 1.5 into my system directory.
Leenuks
Postby Leenuks » Sun Nov 04, 07 8:55 am
Ok I think I have found the problem. Ued2 is not loading the elevator set at all. When I look in the actor browser under 'Brush-Mover' the elevator set is not there.
In Ued1 its in the browser where it should be.
Probably an easy fix but im not sure how.
Leenuks
Postby Andrievskaya Veronika » Sun Nov 04, 07 9:07 am
Here is CaroneElevatorSet for UED2. Put it into your UED2 folder (NOT into DeusEx\System !)
CaroneElevatorSetForUED2.zip
(4.98 KiB) Downloaded 284 times
Last edited by Andrievskaya Veronika on Sun Nov 04, 07 9:10 am, edited 1 time in total.
Postby Leenuks » Sun Nov 04, 07 9:16 am
YES!!!! Thanking you so much.
Problem solved.
Leenuks
Postby Kaiden » Sun Nov 04, 07 5:19 pm
Hehe nice one. =D
