Anti-Water Bug Source
Postby Batchy » Sun Dec 16, 07 7:54 am
// Batch's Anti-WaterBug, Thanks to JimBowen For the help
class antiWaterBug extends Mutator; // any actor class will do here, but using Actor clutters up the tree
function Timer()
   local pawn p;
   for(p=Level.PawnList;p!=None;p=p.nextPawn)
      if (p.isA('DeusExPlayer') && p.region.zone.isA('WaterZone')&&DeusexPlayer(P).inHand.isA('DeusExWeapon')
         && DeusExWeapon(DeusExPlayer(P).inHand).EnviroEffective==ENVEFF_Air)
         DeusExPlayer(P).inHand=None;
function PreBeginPlay()
   setTimer(0.01,true);
Batchy
Postby ~ô¿ô~Nobody~ » Sun Dec 16, 07 12:19 pm
At least you didn't use the AllActors iterator function.
Checking that 100 times a second is not required and just causes lag.
Postby Batchy » Sun Dec 16, 07 11:24 pm
Well if you recommend something that would help it, Please post it :)
Batchy
Postby ~ô¿ô~Nobody~ » Fri Dec 21, 07 11:09 pm
setTimer(0.5,true);
Postby Dae » Thu Jan 17, 08 12:39 am
thx
helped with some code (TzBasketBallZone to be precise :))
Postby Dae » Thu Jan 17, 08 2:58 pm
Looks like
inHand=None;
works only on the server and the client still sees the weapon (and that makes an odd bug)
PutInHand(None);
works better
Postby Batchy » Thu Jan 17, 08 3:00 pm
Ill put that in the new version, Thanks
Batchy
