Simple question, not that hard
Postby clyzm » Mon Jan 28, 08 7:06 pm
How do I make a PlayerStart come equipped with selected inventory and items?
Kind of like in the first level of DX, player started with pistol, prod and medkit.
Postby Andrievskaya Veronika » Tue Jan 29, 08 4:13 am
Check DeusExPlayer.uc, function ResetPlayer
Override it in your own playerclass. This will work for SinglePlayer, i don't know what about MP.
Postby clyzm » Tue Jan 29, 08 4:19 am
function ResetPlayer(optional bool bTraining)
   local inventory anItem;
   local inventory nextItem;
   ResetPlayerToDefaults();
   // Reset Augmentations
   if (AugmentationSystem != None)
      AugmentationSystem.ResetAugmentations();
      AugmentationSystem.Destroy();
      AugmentationSystem = None;
   // Give the player a pistol and a prod
   if (!bTraining)
      anItem = Spawn(class'WeaponPistol');
      anItem.Frob(Self, None);
      anItem.bInObjectBelt = True;
      anItem = Spawn(class'WeaponProd');
      anItem = Spawn(class'MedKit');
Seems to only work when a "new game" is started. I want the player class to start with a certain inventory on a specific map. Is this possible?
Postby Andrievskaya Veronika » Tue Jan 29, 08 5:14 am
Call that function from MissionScript.
Something like this:
function FirstFrame()
   local DeusExPlayer AP;
Super.FirstFrame();
If (LocalURL=="NAMEOfTHEMap")
   AP=DeusExPlayer(GetPlayerPawn());
//   AP.GiveNewInventory();
                    ResetPlayer();
Or better: make a new function in your PlayerClass
function GiveNewInventory()
And call it from MissionScript.
p.s.: This is quick solution. I think there is some better way %)
Postby Legion » Tue Jan 29, 08 6:54 am
Andrievskaya Veronika wrote:Check DeusExPlayer.uc, function ResetPlayer
I think there's a way to do it in MP as well, but I think the only way to do it is to block certain weapons on the server.
Legion
Postby Dae » Tue Jan 29, 08 9:12 pm
Should work in both multiplayer and singleplayer.
Usage: compile the package with it, then place the actor the map, then set all items you want to give to the player. You may additionally change the collision of the trigger.
The trigger will give the player items specified only once.
GiveItemTrigger.uc
(853 Bytes) Downloaded 164 times
Postby clyzm » Tue Jan 29, 08 11:46 pm
Thanks all for your solutions. :D
