The WEIRDEST map error I have ever seen...
Postby [FGS]ShadowRunner » Thu Apr 17, 08 6:09 pm
I have seen a lot of error, I made over 60 maps, some of them very large.
But this one has me speechless, the editor's gremlins have triumphed.
This is AMTRACK map, I edited, had hollowed out the train, added better teepees/tents/wigwams and made a few small fixes and changes...
I rebuilt... then saw what u see...
There is no terrain in the 2D view, but u can see cleary in the 3D view, that a dirty great piece of grey terrain, not unlike Vandenberg terrain, has decided to arrive on the map, being even thoughtful enough to leave a road up to the hill...
how strange is that? Can't delete it cos it's not there in the 2D view.
Also you will notice that some "initial subtractions" are missing and the map at ground level has got smaller, burying the train outside the map. Only the subtracts from the train remain visible, outside the map...
A few things I just can not figure out.
My only guess is that because I used the bunker terrain brush from Area51 (the hilly ramp going down into the bunker), that somehow the terrain has gone wild...
I cant re-add the initial subtraction brushes, because they will just eat away anything already buried outside the map, will have to move everything off the map and put back the initial subtractions and then re-add what I can, and rebuild the rest...
[FGS]ShadowRunner
Postby Jon » Thu Apr 17, 08 7:01 pm
Remove the lofted brushes, rebuild, then re-attempt
Postby [FGS]ShadowRunner » Fri Apr 18, 08 10:51 am
lofted? you mean the brushes buried by missing initial subtractions?
Any idea why a dirty great mountain complete with access road, might suddenly appear in a map?
Also rebuilding doesn't remove the grey mountains so far...
Last edited by [FGS]ShadowRunner on Fri Apr 18, 08 10:52 am, edited 1 time in total.
[FGS]ShadowRunner
Postby ~Si[ß]eria~ » Fri Apr 18, 08 2:24 pm
Select all the brushes in the map apart from the ones that MIGHT be causing the problems. The copy the brushes to an empty map and rebuild. This usually solves my mapping problems. Also did you duplicate any brushes? If you happened to duplicate a BSP tree, that might be causing these problems.
~[ß]Síke~ Mess with the best, fuck the rest.
~Si[ß]eria~
