Tapis Roulant effect
Postby or 1=1 » Tue Apr 22, 08 5:29 pm
http://www.carnielli.com/images/fitness/Tapis%20Roulant%20CTP102%20aperto_big.jpg
Now, I want to make a zone that works likes a Tapis Roulant ^
Example:
Click ^
The player is walking,he enters in the zone that push it to the left
I've tried changing proprieties of teh ZoneInfo class but it works only when the player jumps although I set the gravity to 1 or the ground friction to 0.00000001
Any Ideas ?
Cheap Bitch
or 1=1
Postby Leenuks » Thu Apr 24, 08 2:50 am
I have a zone in a map Im working on with the same problem. It only works if the player jumps while in the zone.
You could try and set another zoneinfo with a slight uplift in gravity then the player may move in the direction you need.
Leenuks
Postby Dae » Thu Apr 24, 08 1:01 pm
I've used that in [A] Patres in that tunnel with the cross. Just open the map and see :)
Postby or 1=1 » Thu Apr 24, 08 8:05 pm
I can't download it, the url can't be found etc...
May you upload it here please ?
Cheap Bitch
or 1=1
Postby Professor Layton » Fri Apr 25, 08 12:08 am
Postby or 1=1 » Fri Apr 25, 08 12:57 pm
Many thanks.
Cheap Bitch
or 1=1
