Purge texture from map.
Postby Leenuks » Wed May 14, 08 6:20 am
Hello
I have a texture that was imported. I cannot find the brush the texture is added to but I want to purge/remove the texture from my map completely.
The brush I had the texture on is now deleted but the texture still loads when my map is loaded. So I must have added it by accident to something else.
EDIT: What I have tried so far is putting the texture Im trying to get rid of on a fresh brush. Then selecting one side of the brush and pressing SHIFT+T to select all matching textures. I then change the texture to a new one, rebuild and save.
I have also changed every surface in the map to the same texture. The unwanted texture still exists. If I delete the texture package my map will not load. Its the only texture in use from my package.
Any ideas?
Thanks
Leenuks
Leenuks
Postby Andrievskaya Veronika » Wed May 14, 08 6:56 am
Type in the log window:
Texture cull
Postby Leenuks » Wed May 14, 08 7:02 am
Thanks so much :D , I knew it had to be something simple.
Got rid of 15 unused textures.
FIXED!
Leenuks
Postby Kronos » Thu Mar 25, 10 11:06 pm
Select texture and press Q :D
Kronos
