3D Models animation playing speed!
Postby ~DJ~ » Wed Jul 29, 09 2:29 am
Hello!
I wanted to know that can we customize the playing animation speed?
because I want my 30 frame animation to play 'slow'...
The animation plays too quick, it should play a bit slow, so... any solutions?
Thanks in advance!
Postby clyzm » Wed Jul 29, 09 2:49 am
The RATE=<number> attachment at the end of animation sequences should solve that. You also need to do some math. For example, if you want an animation to play 1 second, and the number of frames in that sequence is 30, you put RATE=30.
So if you had 50 frames, and you put RATE=25, it would play in 2 seconds. So on and so forth.
Postby ~DJ~ » Wed Jul 29, 09 3:16 am
Thanks very much!
