Need help on simple modding!!!!
Postby Jonny_12 » Fri Aug 05, 05 2:10 pm
How do you rotate an actor on the 3D map???
I can't find my deusex.ini file for making datacubes, its not in my system folder.
Yeah I no my email is gay I just can't be botherd making a new one.
Jonny_12
Re: Need help on simple modding!!!!
Postby Marouku » Fri Aug 05, 05 2:26 pm
Jonny_12 wrote:How do you rotate an actor on the 3D map???
I havent used UnrealED for a while but I think you hold CTRL+LMOUSE and move the mouse
Marouku
Postby Jonny_12 » Fri Aug 05, 05 2:39 pm
I tried that and that just makes them move back and forth or side to side
I cant rotate
Jonny_12
Postby Alex » Fri Aug 05, 05 3:05 pm
You have 4 windows, one is 3d, the other 2 2d, the one above the 3d one, is an window which shows the map from above (Map Overhead), use that window, and use Ctrl+Right Mouse button.
Postby Jonny_12 » Fri Aug 05, 05 4:41 pm
Thanks I'll do that. But do you know where my deusex.ini is I cant find it in my system folder
Jonny_12
Postby Marouku » Fri Aug 05, 05 4:47 pm
Jonny_12 wrote:Thanks I'll do that. But do you know where my deusex.ini is I cant find it in my system folder
C:\DeusEx\System
It's in there....its the only notepad document named DeusEx
Marouku
Postby Alistair » Fri Aug 05, 05 6:51 pm
Y :?: :?: :?: :?: :?: :?: :?: :?: :?:
Postby Jonny_12 » Fri Aug 05, 05 8:57 pm
coz u need it to make datacubes and packages.
Jonny_12
Postby Jonny_12 » Fri Aug 05, 05 9:48 pm
I opened up the deusex in notepad but it dosent have a EditPackages bit for making packages it looks like a bunch of log files
Jonny_12
Postby Dae » Sat Aug 06, 05 8:25 am
You opened deusex.log and not deusex.ini
I recommend you enabling extensions in Windows.
Postby Alistair » Sat Aug 06, 05 8:27 am
Jonny_12 wrote:coz u need it to make datacubes and packages.
I was messing around with you :P
