[Solved @ Dae] Failed to load 'Level None.MyLevel'
Postby ~Sandro~ » Fri Oct 21, 05 6:45 pm
how about someone hellp me!
~Sandro~
Postby ~Sandro~ » Fri Oct 21, 05 7:01 pm
here's log :
Warning: Failed to load 'Level None.MyLevel': Failed to find object 'Level None.MyLevel'
~Sandro~
Postby Dae » Fri Oct 21, 05 7:11 pm
Uhmm send me the map :o
you know my mailbox
Postby ~Sandro~ » Fri Oct 21, 05 7:16 pm
k thanks a lot !!!!!!!! :D :D :D
~Sandro~
Postby Dae » Fri Oct 21, 05 7:26 pm
The map works perfectly fine for me. Please, restart the editor and try again.
+ What editor to you use?
Postby ~Sandro~ » Fri Oct 21, 05 7:28 pm
unrealed, it works when i launch it from unreal ed but not from Deus ex.....
~Sandro~
Postby Gishank » Fri Oct 21, 05 7:29 pm
Hmm Dae he could be getting the same problem i was getting which u couldn't fix
Postby Dae » Fri Oct 21, 05 7:40 pm
Sandro, the problem isn't something unusual - you made a mistake while calling packages. For Unreal engine in .zip you sent me there are two files called "Ha" (no matter what is their extension) and Unreal engine tries to load one with .u (and you get that error).
Never call packages with the same names! Is it name.utx or name.u or name.uax or name.dx, it doesn't matter for the engine.
So, just rename your map to something different :)
Postby ~Sandro~ » Fri Oct 21, 05 7:42 pm
cool thanks dae !!!!!!!!!!!!!!!!!!!!!!!!!!!! 2nd time you help me, thanks a lot!
~Sandro~
Postby Dae » Fri Oct 21, 05 7:54 pm
My names Dae :wink:
Feel free to ask again :)
