Mutator Help
Mutator Help
Postby MainMan » Fri Jan 06, 06 11:52 pm
Ok I need some help with making a mutator. I've never made one before, but i think the one I need is pretty easy to make. I need it to delete all multitools (including ones on respawned players), and instead spawn another class (credit card in my case).
Thanks.
Postby Dae » Sat Jan 07, 06 10:27 am
class SomeMutator extends Mutator config(Mutators);
function PostBeginPlay()
   local Multitool M;
   foreach AllActors(Class'Multitool',M)
        if ( M != None )
           Spawn(Class'{ADD YOUR CLASS NAME HERE}',,,M.Location,M.Rotation);
           M.Destroy();
This code will replace all multitools which lie on the ground, but not those which are given to the player when he respawns. Items which are given to the player when he respawns are unfortunately declared in DeusExPlayer and they're not even variables. I have some ideas about how to replace them too without overriding player class, but none of them are good enough. Maybe you could think of something better.
After you've done your mutator, add it to ServerPackages and ServerActors in DeusEx.ini, like this:
ServerPackages=PackageName
ServerActors=PackageName.MutatorClass
Postby MainMan » Sat Jan 07, 06 10:40 am
what about the weapon selector mutator, that can get rid of all multitools, even on the player.
EDIT: How about if you put your code in Function Tick(Float Deltatime)?
Postby Dae » Sat Jan 07, 06 11:00 am
We don't have a source of mPack1.u unfortunately :(
And Tick isn't the best way, because
1. it may lag
2. there will be some time when a player will be able to drop multitool out
Postby ~ô¿ô~Nobody~ » Sat Jan 07, 06 12:02 pm
you don't need to add it to serverpackages.. since the mutator just works on the server anyways :wink:
btw... what about decompiling mpack1?
EDIT: why that difficult with that tick function
just use function ModifyPlayer(Pawn Other)
of the mutator.. it always gets called after a player respawns
so.. you can right remove the multitool after respawning
Postby MainMan » Sat Jan 07, 06 12:07 pm
where do i need to add it then? in the map itself?
Postby ~ô¿ô~Nobody~ » Sat Jan 07, 06 12:15 pm
the mutator needs to be placed in the map and needs to be registred in the mutator list..
auto spawning the mutator is done by
..how dae already said
just serverpackages aren't required
Postby MainMan » Sat Jan 07, 06 12:21 pm
~[A]Nobody~ wrote:needs to be registred in the mutator list
How do I do this?
EDIT: nevermind it worked.
Here's the code I used, in case anyone else needs to use it:
class MMRPGSpawn extends Mutator config(Mutators);
   local Multitool M;
   local MMRPGCreditcard C;
   local DeusExPlayer Player;
   if (Other.IsA('DeusExPlayer'))
      Player = DeusExPlayer(Other);
         if ( M.Owner == Player )
            C = Spawn(Class'MMRPGCreditCard',,,M.Location,M.Rotation);
            M.Destroy();
            C.Frob(Player,none);
            C.bInObjectBelt = True;
            if(C.Owner != Player)
               C.Destroy();
Postby Dae » Sat Jan 07, 06 1:55 pm
Thanks MainMan (for the code) and Nobody (for helping MainMan). :gj:
